A new noob, a new struggle with making a RepRap December 14, 2010 05:38PM |
Re: A new noob, a new struggle with making a RepRap December 15, 2010 03:55AM |
BlenderGuy
1. When I plug in the serial cable from the USB to TTL, the power does not turn on the motherboard v 1.2
5. ...The VCC is not connected to the third pin on the serial connector on the left hand side of the motherboard which is VCC on the serial cable.
BlenderGuy
There is a set of 4 pins in the top right hand of the motherboard. They have the names VCC GND SDA and SCL. I could not find out what these were for.
BlenderGuy
Small Questions
None of these were specific in the instructions
1. Can I use Cat-5 cables to connect the motors to the motherboard?
2. Can I use Cat-5 to connect the position sensors to the motor controllers?
3. Do I need to modify the motherboard such as removing the Cat-5 and the 2x10 pin connectors?
BlenderGuy
1. In the instructions as to how to set up the USB to TTL board, it would have been helpful to note that the voltage needed was 5V. This was not included in the instructions and I had to search through the forums to find out.
BlenderGuy
Could the wiring diagram in the USB to TTL serial cable have colours? That threw me off for a while.
BlenderGuy
3. Could there be a wiring diagram where there is a picture of each board with the respective wires coming from them? This would have like a picture of the motor controller with the serial cable with a label MOTHERBOARD. I still do not know how this should look like exactly in the end
BlenderGuy
3. When I send commands to the extruder board, it does not respond and, instead, the Arduino states that the board is not connected. I found out that there is a "hold down the reset button and click" sort of of deal, but it did not work for me.
Re: A new noob, a new struggle with making a RepRap December 16, 2010 01:53PM |
Re: A new noob, a new struggle with making a RepRap December 16, 2010 02:37PM |
BlenderGuy
Re: A new noob, a new struggle with making a RepRap December 16, 2010 03:28PM |
Re: A new noob, a new struggle with making a RepRap December 17, 2010 03:06AM |
Re: A new noob, a new struggle with making a RepRap December 18, 2010 05:19AM |
Re: A new noob, a new struggle with making a RepRap December 18, 2010 02:20PM |
Re: A new noob, a new struggle with making a RepRap December 18, 2010 04:41PM |
Re: A new noob, a new struggle with making a RepRap December 18, 2010 05:10PM |
Re: A new noob, a new struggle with making a RepRap December 18, 2010 07:33PM |
Re: A new noob, a new struggle with making a RepRap December 24, 2010 01:38PM |
Re: A new noob, a new struggle with making a RepRap December 24, 2010 06:58PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: A new noob, a new struggle with making a RepRap December 26, 2010 11:38AM |
Re: A new noob, a new struggle with making a RepRap December 26, 2010 02:54PM |
Re: A new noob, a new struggle with making a RepRap December 26, 2010 04:33PM |
Re: A new noob, a new struggle with making a RepRap December 31, 2010 10:41PM |
Re: A new noob, a new struggle with making a RepRap January 02, 2011 05:02AM |
Re: A new noob, a new struggle with making a RepRap January 07, 2011 12:08PM |
Re: A new noob, a new struggle with making a RepRap January 13, 2011 04:05PM |
Re: A new noob, a new struggle with making a RepRap January 17, 2011 11:44PM |
Re: A new noob, a new struggle with making a RepRap January 18, 2011 02:08AM |
BlenderGuy
Extruder.cpp: In function 'void setup()':
Extruder:35: error: 'Serial' was not declared in this scope
Extruder.cpp: In member function 'bool intercom::talk()':
intercom:55: error: 'Serial' was not declared in this scope
Extruder.cpp: In member function 'void intercom::tick()':
intercom:176: error: 'Serial' was not declared in this scope
intercom:210: error: 'Serial' was not declared in this scope
Makerbot
* Fully assembled, pre-programmed board-- no soldering or AVR programmer required!
Re: A new noob, a new struggle with making a RepRap February 08, 2011 07:57PM |
Re: A new noob, a new struggle with making a RepRap February 08, 2011 08:24PM |
Re: A new noob, a new struggle with making a RepRap May 15, 2011 05:41PM |
