E3D v6 3.0mm Direct get stuck October 20, 2016 03:57PM |
Re: E3D v6 3.0mm Direct get stuck October 20, 2016 04:30PM |
Re: E3D v6 3.0mm Direct get stuck October 20, 2016 04:36PM |
Re: E3D v6 3.0mm Direct get stuck October 20, 2016 04:47PM |
Re: E3D v6 3.0mm Direct get stuck October 21, 2016 08:32AM |
Re: E3D v6 3.0mm Direct get stuck October 28, 2016 04:00PM |
Re: E3D v6 3.0mm Direct get stuck October 28, 2016 04:49PM |
sidhabo
Only thing I can figure is that I used nozzle size 0.5 at the beginning ... then changed it to 0.4 when I realized ... could that provoke geting stuck ???
Re: E3D v6 3.0mm Direct get stuck October 29, 2016 01:56AM |
Yes, maybe that was the reason. Been running now some 20 hours and no problemQuote
FA-MAS
sidhabo
If you're saying Cura was set to use a 0.5 nozzle when you physically had a 0.4 installed, that could potentially cause it. Trying to push more filament out of a smaller hole could cause excessive back pressure and jam it up.
