Homegrown reprap only prints for a while, then "jams" August 08, 2017 12:39PM |
Re: Homegrown reprap only prints for a while, then "jams" August 08, 2017 01:12PM |
Re: Homegrown reprap only prints for a while, then "jams" August 08, 2017 03:10PM |
Roberts_Clif
Yes the PTFE can become distorted cause your delima, Have had several filament throat Barrel PTFE liners go bad.
Been told that if you change from PLA to ABA and back to PLA the different materials leaves a residue this causes the filament to get stuck in the Nozzle.
When replacing the throat Barrel make sure the barrel is screwed in far enough so when you screw the nozzle in it rest on the barrel,
as a gap between the two will lead to a similar problem.
Re: Homegrown reprap only prints for a while, then "jams" August 08, 2017 07:50PM |
Re: Homegrown reprap only prints for a while, then "jams" August 09, 2017 04:23AM |
I just replace it with a new block they only couple of $ of ali.Quote
dlc
I was warned ahead of time about the "gap between heat-break and nozzle" blockage, so I checked that out too - This block is so huge that there is a space in the center that each end butts up against to make that seal certain. But the threads are crappy on the heat block so I use Teflon plumbers tape to try to seal that.
Re: Homegrown reprap only prints for a while, then "jams" August 09, 2017 10:05AM |
Re: Homegrown reprap only prints for a while, then "jams" August 09, 2017 01:42PM |
Re: Homegrown reprap only prints for a while, then "jams" August 09, 2017 08:13PM |
Re: Homegrown reprap only prints for a while, then "jams" August 10, 2017 10:05AM |
Re: Homegrown reprap only prints for a while, then "jams" August 14, 2017 06:53AM |
the 280C came from the notion, had to tighten up some degrees above what you gonna use the hotend at, so if you at 260 with abs 280 doesnt seem to bad you mind if I ever quote those four steps you explained it so much better than me.Quote
frank
As per @Jinx, you need to assemble the hotend while it is hot. I don't think it needs to be at 280C though... I just do it at normal printing temperature.
Re: Homegrown reprap only prints for a while, then "jams" August 14, 2017 06:01PM |
jinx
frank
congrats Dlc on solving it and happy printing.
Re: Homegrown reprap only prints for a while, then "jams" August 15, 2017 04:02AM |
jinx
