y motors move faster the the y motors May 24, 2018 10:39AM |
Re: y motors move faster the the y motors May 24, 2018 07:31PM |
Re: y motors move faster the the y motors May 24, 2018 08:17PM |
First thanks for the reply TrakyanQuote
Trakyan
The accelerations are probably set differently, although it's usually the Y axis with a lower acceleration not the X. That or different pulley diameters causing different linear travel speeds for the same RPM. What problem is this causing?
Re: y motors move faster the the y motors May 25, 2018 01:56AM |
Re: y motors move faster the the y motors May 25, 2018 06:35PM |
Re: y motors move faster the the y motors May 25, 2018 11:07PM |
i didn't print any thing yet but when i tried to set home to the x stepper its works fine but for the y stepper it didn't work till i lower the speed and the federate a lotQuote
Trakyan
The default accelerations are usually different, especially on an i3. Is this causing print problems or just an observation?
Re: y motors move faster the the y motors May 25, 2018 11:14PM |
yes o_lampe i tried to swap the x y connectors and the same problemQuote
o_lampe
Maybe the microstep jumpers aren't registered from the controller? Bad contact or cold solder/cracked PCB traces?
What if you swap XY-stepper connectors? Or use E0 and Z-ports for a change.
Re: y motors move faster the the y motors May 25, 2018 11:16PM |
Re: y motors move faster the the y motors May 25, 2018 11:23PM |
all things are goodQuote
Trakyan
Check to see if movement on your y axis is smooth and the rails aren't binding or have excess friction, that could be a problem.
