Cartesian printer goes to X/Y max and prints a blob May 22, 2019 10:10AM |
Re: Cartesian printer goes to X/Y max and prints a blob May 23, 2019 02:27PM |
Re: Cartesian printer goes to X/Y max and prints a blob May 23, 2019 02:36PM |
imqqmi
Is it possible to upload a fresh new firmware? Maybe the flash memory was partially reset or damaged? Reset the storage eeprom as well.
If it works manually controling the x and y axis it may be a different problem. Do you have some old gcode that worked previously? If so, try to find the problem aree by copying the old to new fils line by line and testing the gcode.
Other than that, yep I agree to replace the board. If it does the same thing, you'll at least have a backup board to rules things out.
Re: Cartesian printer goes to X/Y max and prints a blob May 26, 2019 11:40PM |
