Wall Delta Printer August 17, 2020 03:59PM |
Re: Wall Delta Printer August 17, 2020 04:21PM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: Wall Delta Printer August 17, 2020 06:25PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Wall Delta Printer August 17, 2020 08:51PM |
Re: Wall Delta Printer August 18, 2020 02:08AM |
Re: Wall Delta Printer August 18, 2020 02:57AM |
Re: Wall Delta Printer August 18, 2020 03:51AM |
Re: Wall Delta Printer August 18, 2020 10:05AM |
VDX
... from 5:20min you can see the "wobbliness" of this type of kinematics -- so here it's all for "stiffness" or high precision bearings ... so not really suited for high resolution/precision applications in the DIY-range.
But, with good (expensive) components, such systems are used for CNC-milling too
Re: Wall Delta Printer August 26, 2020 10:03PM |
I've been messing around with designs for a "wall SCARA" and I do think it's a better bet than delta. I'm hoping to keep the business end all up near the ceiling, with cantilever bed lowering down as it prints. And if possible, have the bed fold down when not in use to even further reduce the protrusion distance. One of the challenges is the elbow running into the wall. My first design has the bed rotated 25 degrees around the vertical axis to make room, at the cost of one bed corner sticking out farther from the wall. I was hoping to be able to do it super minimalist by using a single SBR12 rail as both the bed support and the axis for the arm (which guarantees that the direction of Z motion is normal to the arm's plane of motion), with a ballscrew to drive the bed up and down the rail as well as preventing the bed rotating around the rail. But unfortunately the machined ends of cheap Chinese ballscrews are not absolutely concentric with the screw thread, so it actually forces the bed to rotate around the rail by a small amount throughout each revolution of the screw, so it would produce ripples in the print which increase in amplitude as you get farther from the rail.Quote
VDX
... another viable conept with a "sideways" kinematic with low footprint and "foldable" arms is a SCARA or better a "parallel SCARA" (for higher accuracy and stiffness).
Here is a good sample of a "parallel" - [www.youtube.com]
... or here, a DIY type - [www.youtube.com]
Re: Wall Delta Printer August 28, 2020 09:46AM |
