Power supply required for prusa mk2
September 13, 2020 04:27PM
Is a 12 volts 16.6 ampere power supply enough for prusa mk2. I have connected 5 stepper motors, 2 endstops, 2 thermistors, a heated bed, cooling fan and a hot end
Re: Power supply required for prusa mk2
September 13, 2020 07:42PM
If its a non cheap power supply . yes
You need 16 amps minimum. Bed of 11amp + 5 amp for everything else
But If the power supply is from a less reputable/cheap supplier sadly they tell fibs about how much current they can provide, so you need need a 20 or 30 amp to get 16.
I would go for a 20 anyways, Gives a little head room.
September 13, 2020 09:31PM
What would happen if i make all the connections and use a 16.6 amp power supply, lets assume its a cheap power supply?
September 13, 2020 10:09PM
when the current draw exceeds what the supply can handle and if it has safety feature it will shutdown with an overload.
If it doesn't have safety features It might blow up!
Or the voltage might just drop .. making heatup of the bed or the hotend slow and potentially unreliable moves as the steppers need the power and cant get it.
Edited 2 time(s). Last edit at 09/13/2020 10:12PM by Dust.
October 12, 2020 10:09AM
xenialouna
at the point when the current draw surpasses what the flexibly can deal with and in the event that it has security highlight it will closure with an over-burden.
To sum this all up it "crowbars"
October 12, 2020 01:50PM
Shank man
xenialouna
I suspect xenialouna to be a spam account judging by the previous post the person edited.
http://www.marinusdebeer.nl/
October 12, 2020 08:10PM
I agree seems to be a spam bot. Please nuke them!
October 13, 2020 07:01PM
Dust
Aaaaand it's gone smiling smiley
