Re: My first printer Geeetech i3 Pro (review so far) June 11, 2015 07:01AM |
Re: My first printer Geeetech i3 Pro (review so far) June 11, 2015 08:43PM |
Re: My first printer Geeetech i3 Pro (review so far) June 17, 2015 07:24PM |
Re: My first printer Geeetech i3 Pro (review so far) June 17, 2015 09:14PM |
Re: My first printer Geeetech i3 Pro (review so far) June 17, 2015 11:31PM |
Re: My first printer Geeetech i3 Pro (review so far) June 17, 2015 11:58PM |
KahosTch
Hello! Good Night gentlemens, im from Mexico, and y have puchased this printer, exactly i have the C version (Dual Extruder), but i have some problems... and i want to know if you can helpme.
THIS IS THE PROBLEM.
I have a model (this: [www.myminifactory.com] ) and my Filament and Printf Configs. I have mi G-Code, and everything looks fine.
I start to print, but some minutes after, the printer start to go more and more low, and finally the printer stops and i cant to make it continue.
This happens when i try to printf from the PC, i use the Repetier-Host V0.90D, and Slic3r 1.1.7
Some extra Info:
When the printer stops, generally appears in Manual Control something like "waiting X comandos"
Or sometimes when i click the "Emergency Stop" button appears one window that say something like "The port COM-XX dosnt look to be connected, please verify... "
And another times i hear that sound that windows make when you connect or disconnect some device
Please, some help here, tanks in advice!
PS: Sorry for my bad english
Re: My first printer Geeetech i3 Pro (review so far) June 18, 2015 02:17AM |
Re: My first printer Geeetech i3 Pro (review so far) June 18, 2015 02:50AM |
Re: My first printer Geeetech i3 Pro (review so far) June 18, 2015 10:51AM |
Re: My first printer Geeetech i3 Pro (review so far) June 19, 2015 09:56AM |
sarf2k4
KahosTch
I only change the cable, and that dosnt work.
I will try with Pronterface and report.
Thank you!
I forgot to request the i3c extruder mount from you, think you can share it here? I wanna have it just in case I might wanna mod it or something and for collection
Re: My first printer Geeetech i3 Pro (review so far) June 19, 2015 09:57PM |
Re: My first printer Geeetech i3 Pro (review so far) June 20, 2015 04:32AM |
Laopa
Hi
Looking at your printer, are you sure the 2 extruders are mounted correctly?
I will have flip them 180 deg to have the fan cool the heat blocker and not the back of the motors.
Check that again first. I have checked and yes, but if you read comments, some guys say it is useless also.
When you heat the filament, the nozzle became hot, but if you not cool the guide over the heat block, then the heat will go up and up and your melted filament will be too high.
Your liquid plastic is too high and you can control nothing.
I am not sure how to help you, or buy 2x E3D and mount them as bowden.
Or flip the motor if possible, cut the front plastic, and make a fan support to blow air on the top of the heat block and not on them.
Re: My first printer Geeetech i3 Pro (review so far) June 22, 2015 02:06AM |
Re: My first printer Geeetech i3 Pro (review so far) June 26, 2015 10:21AM |
Re: My first printer Geeetech i3 Pro (review so far) July 16, 2015 04:57PM |
Re: My first printer Geeetech i3 Pro (review so far) July 18, 2015 09:35PM |
Re: My first printer Geeetech i3 Pro (review so far) October 19, 2015 12:39AM |
Re: My first printer Geeetech i3 Pro (review so far) October 19, 2015 08:41AM |
Re: My first printer Geeetech i3 Pro (review so far) November 28, 2015 01:28PM |
Re: My first printer Geeetech i3 Pro (review so far) November 29, 2015 11:44PM |
Re: My first printer Geeetech i3 Pro (review so far) December 02, 2015 05:07AM |
Re: My first printer Geeetech i3 Pro (review so far) December 30, 2015 09:04AM |
Re: My first printer Geeetech i3 Pro (review so far) May 21, 2016 01:19PM |
Re: My first printer Geeetech i3 Pro (review so far) June 08, 2016 03:53PM |
Re: My first printer Geeetech i3 Pro (review so far) June 10, 2016 01:08PM |
Re: My first printer Geeetech i3 Pro (review so far) June 27, 2016 07:53PM |
alessandro01
Hello guys, I'm Italian and I have a problem with my printer. It stamp so bad I attach an image can you help me? Thanks
Re: My first printer Geeetech i3 Pro (review so far) July 27, 2016 11:36PM |
Re: My first printer Geeetech i3 Pro (review so far) August 02, 2016 01:09PM |
Re: My first printer Geeetech i3 Pro (review so far) May 03, 2017 06:11AM |
