Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 03:45AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 06:52AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 07:49AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 09:45AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 11:02AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 11:45AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 11:59AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 04:54PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 05:13PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 07:37PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 02, 2015 09:26PM |
evetanlm
Follow this picture wire fix on mine migbot prusa and it work.
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 12:38AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 01:21AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 01:54AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 05:43AM |
jmkslave
I bought my first printer 2 weeks ago and have it built. I was about to calibrate the extruder when I found that the heat bed will only heat up to 44 degrees.
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 12:25PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 12:31PM |
andreaseh
Right, so I have a problem - after assembly, I connected the power cable. It worked fine at first, with some small calibrations needed. So I unpowered the printer, because I had to cut some cables a little as well, and did this, but was very careful to put everything back into the same place, following the diagram from the google drive linked here. When I reconnected the power the next day, I noticed a burning smell, and unplugged the power cable, which was very hot. I swapped the cable, and now my printer is unresponsive, and my x axis is not working, although I've tried different motors. The Y and Z axis also move very slowly at times. Did I mess up my motherboard, and if so, how can I fix this? I've tried asking Leo, no response yet.
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 01:02PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 03, 2015 06:26PM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 03:40AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 06:14AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 06:19AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 06:25AM |
evetanlm
the extruder reverse way.
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 06:40AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 06:43AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 07:11AM |
evetanlm
i'm using repetier-host
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 07:17AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 11:06AM |
Re: Migbot Prusa i3 Unofficial Support Thread June 04, 2015 06:26PM |
