Re: Migbot Prusa i3 Unofficial Support Thread January 14, 2016 10:09AM |
Ax
Sounds like the Steps/MM are off. If it's oval then it's either the Steps or the Slicer. Before trying the Steps, try a different slicer, if you're using Cura, then try Slic3r or something along those lines.. As for the Y Carriage, yeah, it flexes like hell, I have 3 of them now, and I need to replace the carriages. Looking at this to replace them all, as I have no access to a CNC or someone who can do it for me. As for not being able to move it, it's just a matter of turning the current up on the stepper driver.
Re: Migbot Prusa i3 Unofficial Support Thread January 15, 2016 04:23AM |
kissfan4
I NEED HELP!!!! OK so i started having issues with my migbot prusa i3. I thought the power supply that came with my kit had just crapped out, so i ordered a replacement, when it came in i hooked it up and in the process of heating everything to do a test print the LED on the power supply started to blink. Unhooked everything and found it to only happen while trying to heat the bed. I figured it was the bed that went bad so i ordered a new bed, it came in yesterday so i hooked it up and tried again. Same damn thing, unhooked the bed thermister and the LED did not blink, so i swapped out the thermister with a new one and when trying to heat the bed the LED blinks. So there is obviously something wrong with the board. So my question is, is there a way around this? If not, am i better off trying to order a replacement MKS Base v1.3? or getting an Arduino? If my best bet is the Arduino, where do i get all of the electronics to go with it to ensure my printer will run correctly? Still kind of new to the electronics side of the printers. Thanks in advance for any help.
Re: Migbot Prusa i3 Unofficial Support Thread January 15, 2016 05:55AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 15, 2016 07:40AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 03:37PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 03:41PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 04:42PM |
Ax
Can't help with tge Windows issue, but seems the polarity fir the steppers is wrong, hence when homing it goes the wrong way. Either turn the plugs the other way or change the firmware. I'll get you the exact bit to change when I get home.
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 05:06PM |
AccidentalWisdom
Ax
Thank you for the reaponse, AX. Do you mean that you think I might have the Y Stepper cable plugged into the X slot and the X Stepper cable plugged into the Y slot on the MKS Base? I did try to switch those earlier, and got the same grinding, only in the opposite direction. I'll provide any info you need if you can direct me where to get it for you.
I played with moving each axis manually by going to Prepare > Move Axis. If I manually set (with my hands) where 0.00 is on each axis, I can get to +200.0 on the X and Y axis perfectly. However, if I go above +26.0 on the Z axis, it grinds toward the top. I assume that is just because that axis could be hypothetically never-ending? Unlike the X and Y that cap at +200.00?
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 05:15PM |
Sort of, you have them plugged into the wrong ports on the board, make sure they're plugged into the minus X and minus Y, I have a feeling you've plugged them into the positive X and Y.. Sorry wasn't concentrating much above, no firmware jigging needed,.
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 05:23PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 05:44PM |
AccidentalWisdom
Entirely possible, haha. I will check that when I get home tonight. Thanks for your help, I will post back either way in 4 hours or so.
Anyone else have an idea why Cura can't establish a connection with the printer?
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 05:59PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 06:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 06:09PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 06:25PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 07:16PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 07:21PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 16, 2016 09:45PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 12:06AM |
Ax
Bit of research regarding the Windows Driver, you can get the latest drivers from here You can try that as it will probably be more up to date. If that doesn't work, try this one. Tbh having both won't hurt.
I don't run Windows, I'm a Linux user and all this works out of the box but the above should work.
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 05:33AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 05:35AM |
AccidentalWisdom
So I just checked and the problem was that the X and Y Limit Switch plugs were reversed - X was in Y and Y was in X. I had checked only the Motor plugs earlier, not the Limit Switch plugs. After I made this change and rewired everything for a bit more order, the Auto Home process ran successfully.Thank you, AX!
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 03:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 03:24PM |
Wes78
Heres a few pictures of the mount i made to hold the E3d
I made the mods to it just need to print it out and do a test fit, I have about 25 hours of printing lined up before i can get to it tho, so itll be a bit
[www.dropbox.com]
[www.dropbox.com]
[www.dropbox.com]
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 03:34PM |
Ax
Wes78
[www.dropbox.com]
[www.dropbox.com]
[www.dropbox.com]
Looks good, don't know why I didn't raise mine up higher.. you considered turning the layer fan 90 degrees and adding a second fan for even cooling?
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 08:25PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 09:57PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 10:24PM |
Putzer
AccidentalWisdom
What version of Windows?
Had trouble installing on Win 10.
Am using on Win 7.
Win 10 has driver install issues. There is a work around but am too lazy to do it.
Re: Migbot Prusa i3 Unofficial Support Thread January 17, 2016 10:28PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 10:48AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 18, 2016 11:00AM |
spinracing
Heya all,
Have a few pics of the larger bed I made up, with the much stiffer carriage.
Also a quick end stop for the y axis, as the switch being on the carriage, it never seemed to have the right distance. SO I measured, and whipped up a quick block with a hole and zip tied it to my Y axis Motor.
Y Axis End stop. Dropbox
Original Table, "Large size" of the electron Migbot.
The number one problem... when the auto leveler tries to run it goes off the back of the table. SO you cant use it all. Dropbox
This is the size difference between tables. The new table is around .5 inches longer on the near end. And as you can see a few inches longer on the far end. Allowing the autolevel sensor to function, AND to be able to use all of the available table. (250mm by 200mm usable print area now) Dropbox
End view of the table and carriage. The table was 5/8 T-6 6061. Milled out to the channel to keep rigidity lengthwise. Carriage was 1/2 inch, but I machined it down a decent amount. It is also 6061. Dropbox
Two pics of the carriage.
I left the thicker edges not only for rigidity, but if I decided to go with larger rails, and or a second bearing on the right side, I wanted to have material to mount wherever needed.
Also the original plan was to add a ballscrew, but I think I will go to a much larger y axis travel so may so something different (but still ballscrew)
Dropbox
Dropbox
