Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 07, 2017 01:33AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 07, 2017 02:42AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 07, 2017 08:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 08, 2017 12:24AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2017 04:23PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 25, 2017 11:50PM |
[www.homedepot.com]Quote
tomytom99
While I'm waiting to get in contact with somebody from customer support to send me a new bed, are there any tricks I can do to fix this?
Unless you adhere a flat plate (Alum, steel) most pcb heatbeds I've seen are neither structural or flat.Quote
tomytom99
And what can I do to prevent this from happening in the future?
First usable print you want is that adjustable Z. Something similar to this. [www.thingiverse.com]Quote
tomytom99
And finally, my Z axis endstop is a pain to adjust. I just cannot get it to move loosely enough to make fine adjustments, since the mounting piece I have for it currently is tight even without the nut and bolt to clamp it down.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) May 23, 2017 01:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 03, 2017 10:30PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 05, 2017 11:21PM |
CharlieB
I am using the firmware from the Folger Tech Google drive.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 20, 2017 06:59PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) June 21, 2017 03:37AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 06, 2017 11:22AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 13, 2017 02:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 02, 2017 05:00AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 02, 2017 08:30AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 02, 2017 10:46AM |
CharlieB
The parts cooling fan never turns on.
I have experience with 3d printers I also own an Anet A8.
I am familiar with the slicer settings and with how to adjust the fan speeds in the slicer software.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 08, 2017 01:03PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 08, 2017 01:38PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 02, 2017 12:38AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 02, 2017 04:00PM |
OneSprague
I recently had to move from Marlin 1.0 to 1.1.6 as i mounted a BLTouch and the old Marlin did not have any of the features it needed. I used to get pretty good to great prints out of my 2020 but now not so much.
Two issues I am having:
1) it takes a LONG time for the bed to heat. It used to take a while, but now it's mind numbing how long it takes.
2) the thing is trying to print stupid fast. I have to run the feedrate clear down to 65% and even then the perimeter runs seem about how fast they used to print, but the skin fill is way too fast.
I had not changed anything in CuraEngine - I did go make a new Print setting and slowed things way down, but it is still running faster than it should.
Did I miss a couple settings somewhere? I tried to follow the old config as much as possible.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 28, 2018 07:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 28, 2018 09:17PM |
markag
I apologize if this has already been discussed...
I've added a bltouch to my 2020 i3 printer. I also have the full size LCD on the printer. I've noticed that if I run the printer untethered from a USB connection, my LCD flickers when the bltouch probe is extending or retracting, and the auto bed leveling doesn't work.
If I plug in the USB cord to my raspberry pi or PC, I don't have that issue.
I'm thinking thatthe power supply does not have enough current untethered to supply all the 5V items in on the board, and that is why this is happening.
Any recommendations on how to address this?
Thanks!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 28, 2018 09:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 28, 2018 11:14PM |
markag
I knew there had to be a solution. I wasn't sure if I could pull power from an external source, or if it had to come from the RAMPS board. I already have a hacked up cell phone charger from a different arduino project that I may look at using.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) April 03, 2018 07:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 09, 2019 03:25PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 24, 2019 12:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) July 02, 2020 05:13AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 24, 2020 08:54AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2020 10:50PM |
Admin Registered: 13 years ago Posts: 7,004 |
