Ribbed prints October 24, 2015 11:07AM |
Re: Ribbed prints October 24, 2015 01:27PM |
Re: Ribbed prints October 24, 2015 04:20PM |
Re: Ribbed prints October 25, 2015 04:31AM |
Re: Ribbed prints October 25, 2015 04:48AM |
Re: Ribbed prints October 25, 2015 02:36PM |
Re: Ribbed prints October 25, 2015 02:40PM |
Re: Ribbed prints October 25, 2015 03:11PM |
Re: Ribbed prints October 25, 2015 03:34PM |
Re: Ribbed prints October 25, 2015 03:39PM |
AudaciousTuddle
It sounds like something is wrong with your microstepping. If you take the number they gave you (94) and devide it by 16 (a very common microstepping multiplier), you get 5.875. This is really close to the value you found to work. You should make sure that you have the little tiny black jumpers installed underneath your driver board. You might have to do some googling to figure out which jumpers you should be using for your set up.
Using the number you found will work, and if it is working well I wouldn't even bother trying to fix the microstepping. But if you start to have more problems, I would try to get this issue worked out, after all your extruder has become 16x less precise.
Re: Ribbed prints October 25, 2015 03:48PM |
Re: Ribbed prints October 25, 2015 06:56PM |
Re: Ribbed prints October 26, 2015 03:05AM |
Re: Ribbed prints October 26, 2015 03:19AM |
Re: Ribbed prints October 26, 2015 04:58AM |
