Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 15, 2015 06:43PM |
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 16, 2015 03:28AM |
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 16, 2015 05:20AM |
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 17, 2015 10:24PM |
J-Max
If it's loud, you probably need to setup your stepper driver output current properly.
If a stepper motor is running hot very fast, the current it gets is probably unapropriate.
Check connexions too, cheap Dupont connectors can be loose.
Last : be kind with your printer, Folger's uses cheap everything, especialy weird motors.
Don't ask it to perform as better printer does. Upgrade extruder+hotend as soon as possible.
++JM
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 22, 2015 12:38PM |
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 24, 2015 09:29AM |
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 24, 2015 12:32PM |
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 24, 2015 06:35PM |
igel
I have been having the same problem with the x axis it makes a grinding sound when running even though i tried lowering the current.
Re: Folger Tech 2020 Prusa i3 x-axis very loud; x motor very hot November 24, 2015 11:53PM |
