Re: P802M Prusa i3 Unofficial Support Thread January 18, 2016 04:37PM |
gwc2795
Scottjar
I've also had the same issue with 3d star on the melzi board. They've sent the firmware but the instructions are terrible. Read the reprap and repetier sites as you need to use the correct arduino IDE and board info to load it. If you can I've logged a dispute as I can't re-flash the board.
Any help would be good for me I really don't want to have to buy another board
Any ideas on how to solve the problem on the arduino IDE not connecting I've tried the usual moving com ports.
Have you ever been able to connect to the Melzi board?
Did you install the FTDI driver on the SD card that came with your printer?
Are you using a MAC?
Re: P802M Prusa i3 Unofficial Support Thread January 18, 2016 04:48PM |
plz delete double post January 18, 2016 05:12PM |
Re: P802M Prusa i3 Unofficial Support Thread January 18, 2016 05:12PM |
Re: P802M Prusa i3 Unofficial Support Thread January 18, 2016 06:24PM |
madias
Scott: Does the printer works offline?
If everything went wrong you can remove the board out of the printer and try a direct connection via a short USB cable without ANY peripheries connected. You should see it in your device manager. If not (or no LED flickering) the board (or some parts of it) is dead.
EDIT: Another reason could be a bricked FTDI. Google for it. As I can remember the win driver on my SD Card was the "evil one" and bricked temporary my FTDI
Re: P802M Prusa i3 Unofficial Support Thread January 19, 2016 06:15PM |
madias
Re: P802M Prusa i3 Unofficial Support Thread January 19, 2016 06:25PM |
Scottjar
madias
Hello this is the message that I'm getting in Arduino avrdude: stk500_getsync(): not in sync: resp=0x00 the PC can see it also it is showing as a fdti chip on the software on their site and has a number greater than 0000 it is 6001. Anymore help would be greatful
Re: P802M Prusa i3 Unofficial Support Thread January 19, 2016 06:30PM |
Just tired that as 115200 and hasn't worked thanksQuote
Gatchaman
Scottjar
madias
Make sure the com port and printer have the same baud speed set.
Re: P802M Prusa i3 Unofficial Support Thread January 19, 2016 06:35PM |
Scottjar
Gatchaman
Scottjar
madias
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 02:59AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 05:07AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 05:57AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 07:52AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:00AM |
but on the photo the upper plate looks thin, VERY thin.|
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:07AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:14AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:15AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:19AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:20AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:26AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 08:30AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 09:08AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 09:17AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 09:29AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 09:32AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 09:38AM |
Re: P802M Prusa i3 Unofficial Support Thread January 20, 2016 10:48AM |
Scottjar
Gatchaman
Scottjar
madias
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 02:43AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 03:46AM |
Re: P802M Prusa i3 Unofficial Support Thread January 21, 2016 03:51AM |
madias
Should work, but 4mm detecting distance is really less. For example: If you are using Blue Tape (1-2mm) you have only 2-3mm left to your metal plate (it works only with metal plates!)
I also bought this one:
[www.aliexpress.com] (8mm distance)
and even your suggested one:
The 8mm one is really bigger than the 4mm one...
But I didn't installed both of them yet.
