Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 05:28AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 05:41AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:11AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:15AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:19AM |
ErikL
I'm trying to pring my first object in PETG but for some reason I have layer adhesion problems. Could this be because of printing too cold?
I tried increasing the temperature to 245°C already but while printing the printer reads 216°/245°. It looks like it's not getting hot enough.
Any idea why it's not going to 245 while printing?
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:50AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:53AM |
I used PTFE tape, but kapton tape will probably be better. After I did this my printer was able to better maintain temperature.Quote
ErikL
And what kind of insulation should I add?
Were you guys required to do this too? Or is it just my printer not being able to keep temperature high enough...
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:54AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:55AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:57AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 07:00AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 07:08AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 07:27AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 07:36AM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 10:05AM |
madias
Good news for printing flexible filaments
The simplest idea was really the best, just an additional guide for the filament prevents loops around the filament gear
Tested with 30m/s working good! More speed give bad results with "soft PLA" even with 230 degrees. But 30ms/s more than the recommended speed.
I have attached a 123D design file and also a STL file for that part.
For myself I used PETG for higher temperature resistance, feel free to experiment.
You also must drill the filament hole a bit (M3-M4, so 3-4mm)
regards Matthias
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 10:45AM |
woutwoot
That kapton tape is there to attach the thermistor. Yes, I'd try adding a few extra layers.Quote
ErikL
There already was kapton tape arround the hot end when I bought this printer so I need to add more layers?
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 10:54AM |
ErikL
woutwoot
ErikL
I tried extra layers of kapton tape on the hot end but I don't see a significant difference with it... Maybe I had to tape them with some air between, for added insulation .. I just taped them tight so it won't fall off...
But maybe I should try something like this (printed in PETG instead of ABS?) -> [www.thingiverse.com]
Looking at the pictures it seems like it's going to direct the wind more to the object and not so directly to the hot end...
Maybe this is a better solution than extra layers of kapton tape on the hot end?
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 12:30PM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 06:19PM |
Re: P802M Prusa i3 Unofficial Support Thread January 23, 2016 07:15PM |
Re: P802M Prusa i3 Unofficial Support Thread January 24, 2016 05:25AM |
Re: P802M Prusa i3 Unofficial Support Thread January 25, 2016 08:14AM |
Re: P802M Prusa i3 Unofficial Support Thread January 25, 2016 10:33AM |
Re: P802M Prusa i3 Unofficial Support Thread January 25, 2016 10:49AM |
Re: P802M Prusa i3 Unofficial Support Thread January 25, 2016 11:12AM |
ystem.IO.Ports.SerialErrorReceivedEventArgs"
P802M Prusa i3 Unofficial Support Thread January 25, 2016 05:13PM |
Re: P802M Prusa i3 Unofficial Support Thread January 25, 2016 05:44PM |
Re: P802M Prusa i3 Unofficial Support Thread January 26, 2016 10:03AM |
Re: P802M Prusa i3 Unofficial Support Thread January 26, 2016 06:18PM |
ErikL
Anyone tried these ? [pinshape.com]
Wondering if it's worth something or just better don't try
Re: P802M Prusa i3 Unofficial Support Thread January 26, 2016 06:25PM |
madias
ok. I'm done with my experiences with the melzi board. Neither firmware I installed is better than the original installed one and for this I do not have the source code. I have my ramps 1.4 on my desk with minimum connections (not to a real printer) and I'll invest my time for it (nearly configurated the firmware from zero). Remember: You can never install a secondary extruder on melzi, it`s not possible, if one stepper burned out, you can trash the whole board. So some calculations:
Melzi board: 4 Euro
Arduino Mega Clone 6 Euro
5 pcs DRV8825: 7 Euro
So you can get a far better RAMPS 1.4 based system for 17 Euros. So my suggestion: Save your time, use the melzi until it will burn out and have a RAMPS system in reserve.
@ dedi... : Did you try the gcode example shipped on the sd card? there are massive mismatches with the x-axis (if not all axis)
@ dsol: Sorry, I haven't got the baudrate problem. Maybe a driver issue? Remember that on this melzi board there is a FAKE FTDI. About the Z-axis steps: 1600 is correct. What I've done before upload any firmware, I've done a backup of all eeprom settings and compared them after flashing a new one. Not every entry was the same, so I edited them manually.
Even if you won't got in driver hell, they are less functional than the original one. You got the problem with the z-axis, I got the problem with the hotend temp...so:
I think there are many printer variations out here with minimal changes, but this minimal things prevent us "working on the same horse"
