Extruder with mk8 gear for e3d v6 hotend
Posted by siil
February 21, 2016 10:03AM
I am trying to continue building my p3steel, that I started to build 1,5 years ago.
I have assembled the frame and mounted the steppers for the xyz axis.
Altough I have read up on the subject I still can't decide what extruder should I use.
I have a original e3d 1,75mm hotend and a mk8 extruder gear.
What's the best current extruder design that uses mk8 gear and that fits the e3d hotend?
Re: Extruder with mk8 gear for e3d v6 hotend
February 21, 2016 09:02PM
Why not use a Wades style? So much easier to change filament and prime the hot-end by using the large gear.
I've used this design with a hexagon and there are also E3D files included:
[www.thingiverse.com]
Lots of options for cooling fans too.
Steve
My updated Instructable on our Prusa i3 Build
[www.instructables.com]
February 23, 2016 02:15AM
I decided to try this: [www.thingiverse.com] and that: [www.thingiverse.com]
This would have been another option: [www.thingiverse.com]
February 23, 2016 02:14PM
hello all
i have a prusa i3 hephestos Direct extruder for 1.75 mm filament with 0.4mm nozzle.
and i have a ed3 lite6 24v direct extruder is there a mount for this and not the bowden with servvo for auto bed
February 24, 2016 04:52PM
Hello,
In my opinion the Greg's wade extruder is the best option.
February 24, 2016 05:51PM
siil
This also the route I am taking. I had to replace parts in the kit so I researched and found this choice to be the most consistent of most.
February 27, 2016 06:56PM
what would i need to covert to this set up
March 03, 2016 06:28PM
Not sure what your budget is like but this may be another option since you already have a V6 [www.thingiverse.com]
March 04, 2016 12:54AM
i did look at that but need a mount to include a servo attachment for auto bed,i like the dondolo but cant print in abs or pet g
Anonymous User
March 04, 2016 12:31PM
I saw this servo and arm with a micro switch for "autobed". Really funny but, I think, totally useless for a sound and properly built cartesian machine. Plus it adds weight and certainly trouble.
