Firmware update Issues for Hesine Printer, Anet A8-B March 18, 2016 10:23AM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B March 18, 2016 01:17PM |
Sethrocon
I've tried the "stock firmware" from the builder and the same problem happens with the LCD. I can connect to the printer with Repetier and use the printer just fine, but the LCD is locked up.
Re: Firmware update Issues for Hesine Printer, Anet A8-B March 18, 2016 02:04PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B March 18, 2016 03:10PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B March 18, 2016 07:54PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B May 02, 2016 06:37PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B May 17, 2016 10:43AM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B May 18, 2016 10:54PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B May 19, 2016 03:09AM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B June 04, 2016 08:00AM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B June 08, 2016 12:43PM |
dchapma1
I have the same printer and PCB labeled ANET V1.0, small, square PCB.
I have printed several items and I am seeing the bed temperature reading getting flaky.
The hot bed is warped - high in the center - ABS parts tend to pop off during printing.
I want to calibrate this thing but the M501 command does not report back the steps / distance - the M92 readings.
I am leery about uploading any firmware as I really don't know what I have here.
Any ideas on how to calibrate this printer without knowing the current M92 values?
Thanks
Re: Firmware update Issues for Hesine Printer, Anet A8-B June 11, 2016 04:53PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B July 07, 2016 06:37AM |
roginvs
Repetier for Zonestar P802M works perfect for my Anet A8-B (https://github.com/repetier/Repetier-Firmware/tree/master/boards/Zonestar%20P802M)
Re: Firmware update Issues for Hesine Printer, Anet A8-B July 07, 2016 08:09AM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B July 09, 2016 12:02AM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B July 09, 2016 02:45PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B July 09, 2016 02:55PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B September 01, 2016 07:14PM |
Re: Firmware update Issues for Hesine Printer, Anet A8-B November 04, 2016 12:36PM |
joeylevyusa
I have the same one. I havent done a firmware update yet, but it seems that we have a Melzi Clone. Here is the wiki: http://reprap.org/wiki/Melzi There are links to usable firmwares there.
Here is an example of the board: http://www.ebay.com/itm/301815767959 (mine is red)
I am thinking of trying to upgrade to Marlin or Repetier, and I will report back with my results when I do. Right now, my bed temperature sensor goes nuts and the system thinks the bed goes from 84c to 93c, then again 105c to 394c ( and errors out).
Re: Firmware update Issues for Hesine Printer, Anet A8-B November 04, 2016 06:23PM |
drephuz
joeylevyusa
I just posted something about this same damn issue! I also just emailed them about possible firmware
Re: Firmware update Issues for Hesine Printer, Anet A8-B November 10, 2016 12:07PM |
Supermec
drephuz
joeylevyusa
It's more likely that the temperature problem is an electronic one in the connections to the bed thermistor (including the soldered joints on the bed) rather than firmware. As I've said several times before in response to similar posts the Anet board is a proprietary board and you are unlikely to get any details from them or any firmware updates. Any firmware found floating around on the net is unlikely to suit the board. Once you have tried installing an unsuitable firmware then there is no way back to the original, and no printing until it's sorted.
My machine has operated faultlessly with the pre-installed firmware on an almost daily basis for the last two months. Firmware doesn't change itself and doesn't screw itself. Why is it that the minute something doesn't work users assume that it's a firmware fault rather than an electronic one.
Why is it
Re: Firmware update Issues for Hesine Printer, Anet A8-B December 19, 2016 10:46AM |
