HICTOP Prusa I3 now working great : my configuraton.h file April 24, 2016 12:30PM |
// Default AXIS STEPS, MAX_FEEDRATE, ACCELERATION settings // Default AXIS STEP Settings (motor steps) X, Y, Z, E // 1a) default axis steps per unit for Ultimaker steps/mm ={8.7402,78.7402,200.0*8/3,760*1.1} // 1b) default axis steps per unit for HIC i3 steps/mm ={80,80,2560,94.4962144}, OEM z-axis threaded rods =8mm wide x 1.25mm pitch //#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2560,94.4962144} // original default for HIC i3, (steps/mm) #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2559,98.6} // CL: default steps for _my_ HIC i3, you may need to change the Z and/or E for your machine // Default MAXIMUM FEEDRATES (motor speeds) X, Y, Z, E - GLOBAL for printing and non-printing //#define DEFAULT_MAX_FEEDRATE {200,200,5,17} // (mm/sec) default for Makerbot i3 //#define DEFAULT_MAX_FEEDRATE {500,500,5,25} // (mm/sec) default for HIC i3 #define DEFAULT_MAX_FEEDRATE {120,120,3,25} // (mm/sec) CL: default for _my_ HIC i3 max feedrate rated at ~120mm/sec // Default MAXIMUM ACCELERATION (motor) X, Y, Z, E=(extrusion only) - max start speeds for accelerated moves // NOTE: value stored in DEFAULT_ACCELERATION if lower, will limit these MAX rates //#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // (mm/sec^2) default for HIC i3 - X, Y, Z, E(moves) maximum start speed for accelerated moves #define DEFAULT_MAX_ACCELERATION {1200,1200,50,10000} // (mm/sec^2) CL: for _my_ HIC i3 - X, Y, Z, E(moves) maximum start speed for accelerated moves // E default values are good for Skeinforge 40+, for older versions raise them a lot. // Default misc. ACCELERATIONS //#define DEFAULT_ACCELERATION 500 // (mm/sec^2) default for Makerbot i3 - X, Y, Z and E max acceleration for printing moves //#define DEFAULT_ACCELERATION 3000 // (mm/sec^2) default for HIC i3 - X, Y, Z and E max acceleration for printing moves #define DEFAULT_ACCELERATION 1200 // (mm/sec^2 ) CL: for _my_ HIC i3 - X, Y, Z and E max acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // (mm/sec^2) E acceleration for retracts (fliament purge and feed) #define DEFAULT_TRAVEL_ACCELERATION 1200 // (mm/sec^2) X, Y, Z acceleration for travel (non-printing) moves // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) // default jerk values for HIC i3 ={20.0, 0.4, 5.0} (mm/sec) #define DEFAULT_XYJERK 2.0 // CL: For HIC i3, was =20, (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: HICTOP Prusa I3 now working great : my configuraton.h file May 31, 2016 09:51PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file June 02, 2016 05:04PM |
GeorgeL16
Re: HICTOP Prusa I3 now working great : my configuraton.h file June 03, 2016 10:04AM |
eried
GeorgeL16
What that does in the hictop? I made my own configuration too, the only problem I am getting is with the bridges, for example if I print a 1x1 cm cube the top layer starts very crappy, stringy (so I use 3 layers) but besides that, it is working nicely.
I designed some enhancements for the printer: [www.thingiverse.com]
Re: HICTOP Prusa I3 now working great : my configuraton.h file June 06, 2016 11:21AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file June 06, 2016 02:43PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file June 12, 2016 09:02AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file June 13, 2016 07:16AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file July 08, 2016 02:54PM |
// Reprap link here for PID tuning: "http://reprap.org/wiki/PID_Tuning" // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it // CL: HICTOP i3 (China), post post PID tuning #define DEFAULT_Kp 11.95 #define DEFAULT_Ki 0.49 #define DEFAULT_Kd 72.55 // Ultimaker (was default) #define DEFAULT_Kp 22.2 #define DEFAULT_Ki 1.08 #define DEFAULT_Kd 114
Re: HICTOP Prusa I3 now working great : my configuraton.h file August 07, 2016 12:40AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file August 08, 2016 10:10AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file August 25, 2016 04:58PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file August 26, 2016 08:27AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file August 26, 2016 08:31AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file October 10, 2016 11:08PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file October 22, 2016 12:59AM |
Arduino: 1.6.12 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" In file included from sketch\MarlinConfig.h:39:0, from C:\Users\Andrew\Desktop\Marlin-RC\Marlin\Marlin.ino:37: SanityCheck.h:44: error: #error "You are using an old Configuration.h file, update it before building Marlin." #error "You are using an old Configuration.h file, update it before building Marlin." ^ SanityCheck.h:219: error: #error "You must set DISPLAY_CHARSET_HD44780 to JAPANESE, WESTERN or CYRILLIC for your LCD controller." #error "You must set DISPLAY_CHARSET_HD44780 to JAPANESE, WESTERN or CYRILLIC for your LCD controller." ^ In file included from sketch\MarlinConfig.h:39:0, from C:\Users\Andrew\Desktop\Marlin-RC\Marlin\Marlin.ino:37: SanityCheck.h:355: error: #error "Z_MIN_PROBE_REPEATABILITY_TEST requires a probe! Define a Z Servo, Z_PROBE_ALLEN_KEY, Z_PROBE_SLED, or FIX_MOUNTED_PROBE." #error "Z_MIN_PROBE_REPEATABILITY_TEST requires a probe! Define a Z Servo, Z_PROBE_ALLEN_KEY, Z_PROBE_SLED, or FIX_MOUNTED_PROBE." ^ SanityCheck.h:635: error: #error "You must enable USE_XMIN_PLUG or USE_XMAX_PLUG" #error "You must enable USE_XMIN_PLUG or USE_XMAX_PLUG" ^ SanityCheck.h:689: error: #error "LANGUAGE_INCLUDE has been replaced by LCD_LANGUAGE. Please update your configuration." #error "LANGUAGE_INCLUDE has been replaced by LCD_LANGUAGE. Please update your configuration." ^ exit status 1 #error "You are using an old Configuration.h file, update it before building Marlin." This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
Re: HICTOP Prusa I3 now working great : my configuraton.h file November 01, 2016 05:26PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file November 01, 2016 05:55PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file November 01, 2016 09:08PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file November 02, 2016 12:10AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file January 10, 2017 12:56AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file January 10, 2017 06:52AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file January 18, 2017 07:38PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file January 19, 2017 05:14PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file January 26, 2017 07:40AM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file February 19, 2017 02:52PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file March 20, 2017 09:54PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file December 16, 2017 03:52PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file January 15, 2018 05:55PM |
Re: HICTOP Prusa I3 now working great : my configuraton.h file April 04, 2019 05:15AM |
