Cura settings April 05, 2017 02:24PM |
Re: Cura settings April 05, 2017 03:23PM |
Re: Cura settings April 05, 2017 03:29PM |
Re: Cura settings April 05, 2017 04:09PM |
Re: Cura settings April 05, 2017 05:22PM |
obewan
If the flow rate in cura is set at 100% then the over extrusion is to do with the extruder steps/mm set in your firmware.
Best way to check is Mark the filament 50 mm above where it enters the hotend, then heat the hot end to working temp and tell the printer to extrude 50 mm,
the previous mark you made should be just entering the hot end.Adjust the extruders steps/mm to compensate for any error.
Re: Cura settings April 05, 2017 06:39PM |
Re: Cura settings April 06, 2017 02:59AM |
Re: Cura settings April 06, 2017 06:59AM |
Re: Cura settings April 06, 2017 03:17PM |
Re: Cura settings April 07, 2017 12:18AM |
Re: Cura settings April 07, 2017 01:37AM |
Re: Cura settings April 07, 2017 04:48AM |
Re: Cura settings April 07, 2017 05:36AM |
Re: Cura settings April 07, 2017 03:33PM |
Re: Cura settings April 07, 2017 04:38PM |
Re: Cura settings April 07, 2017 08:55PM |
Re: Cura settings April 08, 2017 12:15AM |
Re: Cura settings April 08, 2017 04:05AM |
Re: Cura settings April 08, 2017 03:01PM |
Re: Cura settings April 08, 2017 05:40PM |
Re: Cura settings April 09, 2017 12:42PM |
Re: Cura settings April 10, 2017 11:13AM |
Re: Cura settings April 10, 2017 01:01PM |
Re: Cura settings April 10, 2017 02:34PM |
Re: Cura settings April 11, 2017 02:05AM |
Re: Cura settings April 11, 2017 12:04PM |
Re: Cura settings April 12, 2017 08:17AM |
Re: Cura settings April 12, 2017 12:12PM |
Re: Cura settings April 12, 2017 12:59PM |
Re: Cura settings April 12, 2017 03:40PM |
