3DP 18 Hictop Pls Help May 02, 2017 12:13PM |
Re: 3DP 18 Hictop Pls Help May 03, 2017 01:14AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: 3DP 18 Hictop Pls Help May 03, 2017 09:18AM |
Re: 3DP 18 Hictop Pls Help June 27, 2017 12:16PM |
Re: 3DP 18 Hictop Pls Help June 27, 2017 12:53PM |
Roberts_Clif
The y end stop switch appears not switching, Had the same problem, made a Y end stop Stepper mount.
[attachment 95640 y_motor_end_stop.stl]
To temporally fix tape something ridged to the edge of the Stepper motor to extend the Stepper motor edge over, Not far as it will get into the way of the Belt.
If you reach under the bed an manually push the end stop switch does it stop then.
if not then.
It could be a bad connection to the end stop switch and it is not switching at all. You can do a continuity check with a meter across the Connector.
Re: 3DP 18 Hictop Pls Help June 27, 2017 04:50PM |
Re: 3DP 18 Hictop Pls Help June 28, 2017 08:58AM |
Re: 3DP 18 Hictop Pls Help June 28, 2017 08:58PM |
Re: 3DP 18 Hictop Pls Help June 29, 2017 04:43AM |
Re: 3DP 18 Hictop Pls Help June 29, 2017 07:33PM |
Bee69
The easy way I found was to push the bed home (when the printer is off) and look why ite missing the switch. then move the switch so it comes in contact with the bed. I found a STL file on Thingiverseand printed it out. but you can drill some holes in a bit of scrap metal or plastic and make your own. If you've got an old print thats no good cut it up and make one.
