Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 05:27AM |
Re: Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 07:48AM |
Re: Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 08:31AM |
Re: Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 08:42AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 10:50AM |
Dust
If your updating a real mk3, then you need to use motherboard BOARD_EINSY_RAMBO
It not a ramps anymore.... so there is no need to edit pins_Ramps.h
Most of the config settings in prusa firmware have been consolidated into 1_75mm_MK3-EINSy10a-E3Dv6full.h
Dust
Not sure the pinda v2 probe is supported in marlin... or the fancy auto skew calibration.
Prusa firmware is quite customized for the prusa printers... its marlins weird uncle.
You can't just compare config files that easily.
Re: Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 11:45AM |
Re: Installing Marlin firmware for Prusa (i3 MK3) September 13, 2019 09:27PM |
Re: Installing Marlin firmware for Prusa (i3 MK3) September 16, 2019 02:37AM |
dc42
Is there a design tool + slicer combination that can generate G5 commands, without the model being quantized into flat facets or straight line segments at some point and then back again? If there is, then I'll implement G5 commands in RepRapFirmware. If not, it seems pointless to me.
Re: Installing Marlin firmware for Prusa (i3 MK3) September 16, 2019 06:52AM |
Starliner
About that it's dog chasing his own tail! We need to find a way out from this loop and overcome STL format, because not everyone is stuck to printing some pointless action figure (for example) and FDM printing today is choked by poor software. Moreover vector based printing has proven to produce a better print results, producing so mush less hardware vibration (especially on low end machines like Prusa.)
Re: Installing Marlin firmware for Prusa (i3 MK3) September 16, 2019 08:30AM |
Dust
Citations needed.
It not choaked as far as I'm aware, especially on 32 bit machines. Unless you silly and create stl's with far to many polygons. That is user error.
"Moreover vector based printing has proven to produce a better print results" where ? citations and examples?
"Especially on low end machines like Prusa" since none of these printers use vectors at all, how can you make this claim?
Dust
The hard part will be extracting the real G5 code from marlin and adding it into prusa firmware...
Re: Installing Marlin firmware for Prusa (i3 MK3) February 18, 2020 12:51PM |
Re: Installing Marlin firmware for Prusa (i3 MK3) February 18, 2020 01:37PM |
Re: Installing Marlin firmware for Prusa (i3 MK3) February 18, 2020 03:41PM |
