Fisher Fan
Posted by DADIY
Fisher Fan
December 10, 2015 08:00AM
Does anyone know of any good sources for the Fisher fan, it seems 19v fan blowers are a little uncommon.
Re: Fisher Fan
December 10, 2015 10:11AM
Yep. You don't have a lot of choice.
Re: Fisher Fan
December 24, 2015 09:14PM
There are two pins that are located in far right side of the expansion pins. It supplies 5V DC.
Pin 1 is +5V, Pin 2 is ground. Backside of the board has all the pin information.
Last two pins near the board mounting hole at bottom right corner.
Re: Fisher Fan
December 25, 2015 01:46AM
You could use a 12V regulator to run a 12V fan instead. Or you could convert to 24V using a 24V 5A PSU such as this one [m.ebay.co.uk]
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
Re: Fisher Fan
December 25, 2015 02:36AM
I agree. That seems the best route. Converting 19v to 12v is cheap and would take the load off the duet too.
Edited 1 time(s). Last edit at 12/25/2015 02:46AM by DADIY.
