Hi
I am trying to compile my marlin code so I can upload it to my printer and I keep getting an error.
The error I am getting is that it says that the 'DIGIPOT_MOTOR_CURRENT' was not declared in this scope.
This is in the Stepper.cpp tab of marlin
void Stepper::digipot_init() {
#if HAS_DIGIPOTSS
static const uint8_t digipot_motor_current[] = DIGIPOT_MOTOR_CURRENT;
SPI.begin();
SET_OUTPUT(DIGIPOTSS_PIN);
for (uint8_t i = 0; i < COUNT(digipot_motor_current); i++) {
//digitalPotWrite(digipot_ch, digipot_motor_current);
digipot_current(i, digipot_motor_current);
#elif HAS_MOTOR_CURRENT_PWM
#if PIN_EXISTS(MOTOR_CURRENT_PWM_XY)
SET_OUTPUT(MOTOR_CURRENT_PWM_XY_PIN);
#endif
#if PIN_EXISTS(MOTOR_CURRENT_PWM_Z)
SET_OUTPUT(MOTOR_CURRENT_PWM_Z_PIN);
#endif
#if PIN_EXISTS(MOTOR_CURRENT_PWM_E)
SET_OUTPUT(MOTOR_CURRENT_PWM_E_PIN);
#endif
refresh_motor_power();
// Set Timer5 to 31khz so the PWM of the motor power is as constant as possible. (removes a buzzing noise)
SET_CS5(PRESCALER_1);
#endif
Here is the error message.
Arduino: 1.6.13 (Windows 8.1), TD: 1.33, Board: "RAMBo"
sketch\stepper.cpp: In static member function 'static void Stepper::digipot_init()':
stepper.cpp:1483: error: 'DIGIPOT_MOTOR_CURRENT' was not declared in this scope
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I was wondering what I need to troubleshoot to get this working?
Let me know if you need more information.
Thanks
Tanner
