DIGIPOT_MOTOR_CURRENT Compiling error June 10, 2018 06:34PM |
void Stepper::digipot_init() { #if HAS_DIGIPOTSS static const uint8_t digipot_motor_current[] = DIGIPOT_MOTOR_CURRENT; SPI.begin(); SET_OUTPUT(DIGIPOTSS_PIN); for (uint8_t i = 0; i < COUNT(digipot_motor_current); i++) { //digitalPotWrite(digipot_ch, digipot_motor_current); digipot_current(i, digipot_motor_current); } #elif HAS_MOTOR_CURRENT_PWM #if PIN_EXISTS(MOTOR_CURRENT_PWM_XY) SET_OUTPUT(MOTOR_CURRENT_PWM_XY_PIN); #endif #if PIN_EXISTS(MOTOR_CURRENT_PWM_Z) SET_OUTPUT(MOTOR_CURRENT_PWM_Z_PIN); #endif #if PIN_EXISTS(MOTOR_CURRENT_PWM_E) SET_OUTPUT(MOTOR_CURRENT_PWM_E_PIN); #endif refresh_motor_power(); // Set Timer5 to 31khz so the PWM of the motor power is as constant as possible. (removes a buzzing noise) SET_CS5(PRESCALER_1); #endifHere is the error message.
Arduino: 1.6.13 (Windows 8.1), TD: 1.33, Board: "RAMBo" sketch\stepper.cpp: In static member function 'static void Stepper::digipot_init()': stepper.cpp:1483: error: 'DIGIPOT_MOTOR_CURRENT' was not declared in this scope static const uint8_t digipot_motor_current[] = DIGIPOT_MOTOR_CURRENT; ^ exit status 1 'DIGIPOT_MOTOR_CURRENT' was not declared in this scope This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.I was wondering what I need to troubleshoot to get this working?
Re: DIGIPOT_MOTOR_CURRENT Compiling error June 11, 2018 12:04AM |
Admin Registered: 13 years ago Posts: 7,012 |
