Mesh Bed Leveling - add points.
July 30, 2018 02:29PM
I have a cr-10s and would like to add 4 more points to my mesh bed leveling pattern.
However, I do not want to add them to the outside line but rather in select midpoints between the outer edge and center (see attached).
I know were to add the number of points per axis, but not where to set the positions for them.
Is this possible?
open | download - mesh_points.jpg (70.5 KB)
Re: Mesh Bed Leveling - add points.
July 31, 2018 01:51AM
So you don't want a square mesh? You want your mesh points staggered?
None of the mesh bed leveling systems accommodate that right now.
Is there a good reason to do that?
July 31, 2018 09:13AM
I thought the idea was to correct hills and valleys rather then just "tilt". There could be a hill or valley between the center and outer edge.
July 31, 2018 09:16PM
OMG... I am such an idiot.
I did not understand how the pattern changes if you just add more points via"GRID_MAX_POINTS_X" at line 986 (i think).
I upped mine to 5 and it does a great job.... my bed has never been leveler. smiling smiley
-OG-
August 03, 2018 01:04AM
UBL allows you to tilt the mesh. But there is seldom a reason to do that. The mesh bed leveling works very well.
The isn't any down side to using a 10 x 10 mesh instead of a 5 x 5 mesh. Depending on the peaks and valleys... You may get better results with more mesh points.
