Status of TMC5160 support April 02, 2019 04:34PM |
Re: Status of TMC5160 support April 02, 2019 08:30PM |
Re: Status of TMC5160 support April 03, 2019 05:19AM |
/** * TMC2130, TMC2160, TMC2660, TMC5130, and TMC5160 only * Use StallGuard2 to sense an obstacle and trigger an endstop. * Connect the stepper driver's DIAG1 pin to the X/Y endstop pin. * X, Y, and Z homing will always be done in spreadCycle mode. * * X/Y/Z_STALL_SENSITIVITY is used for tuning the trigger sensitivity. * Higher values make the system LESS sensitive. * Lower value make the system MORE sensitive. * Too low values can lead to false positives, while too high values will collide the axis without triggering. * It is advised to set X/Y/Z_HOME_BUMP_MM to 0. * M914 X/Y/Z to live tune the setting */ //#define SENSORLESS_HOMING // TMC2130 only(bolding mine)
Re: Status of TMC5160 support April 03, 2019 01:34PM |
Re: Status of TMC5160 support April 03, 2019 01:45PM |
