Extruder Motors will not move April 23, 2021 04:53PM |
Re: Extruder Motors will not move April 23, 2021 05:57PM |
Re: Extruder Motors will not move April 23, 2021 06:00PM |
Re: Extruder Motors will not move April 23, 2021 06:39PM |
Re: Extruder Motors will not move April 24, 2021 01:38PM |
Re: Extruder Motors will not move April 26, 2021 04:29PM |
MMcLure
OK - the most probable issue is a problem with the driver enable signal. You don't happen to have SOFTWARE_DRIVER_ENABLE turned on? That is known to cause problems and should only be turned on if the hardware does not have a physical enable pin for the drivers, which is definitely not the case for an SKR 1.4.
Re: Extruder Motors will not move April 27, 2021 12:59AM |
