Possible Endstops Problem?
July 30, 2021 03:06AM
Hello I wonder if anyone can help me?
Ender 3 V2 and fitted an SKR 2 board/2209 steppers with TFT35 E3 v3 - BLTouch & Dual Z Axis (each on their own stepper)
2.0.9.1 Marlin compiled by myself.
The problem I'm having, is all the endstops seem to be getting ignored? A M119 shows they are working OK, but doing an 'Auto Home' results in all the axis grinding when they reach these points?, like it's trying to continue past the endstop marks? I have sensorless homing disabled.
Could someone maybe check my configs to see if I have missed something? I'm at my wits end!
One thing I did notice, is that with M119 command, it shows XYZ triggered when I test when pressing them, open when released, but it throws up a continuous error of 'Couldn't X:0 Y:0 Z:0'?
I'd be grateful for any help guys. Thank you.
open | download - Marlin.zip (83.7 KB)
Re: Possible Endstops Problem?
July 30, 2021 11:56AM
Did you install these jumpers by mistake? (the red empty squares)
July 30, 2021 05:34PM
Hi, thx for asking, but nope, I don't need Sensorless Homing, so never installed them. Been an absolute nightmare this board, from start to finish. sad smiley All else works fine on the printer, aka moving all axis, etc., but it will just not 'home'? If I move all axis manually to the very ends, then it will try to keep going, hence the juddering. It's like it knows nothing of the area whatsoever? This is third board, each and every one the same.
Edited 2 time(s). Last edit at 07/30/2021 05:37PM by Girl5.
July 30, 2021 10:57PM
try enabling #define ENDSTOP_NOISE_THRESHOLD 2
July 30, 2021 11:30PM
Board ripped out, had enough. Done with it. 1.4 Turbo on way back, hopefully that will cure problems.
August 01, 2021 02:30AM
Most likely you have nosy endstop wires, and changing the controller wont help at all.
August 02, 2021 05:11PM
All good now smiling smiley Back on 1.4 Turbo, and not a single problem, as it should be smiling smiley The SKR 2 is not fit for sale, regardless if I had noisy wires lol. This board is a 'nightmare' come true, at all levels!, in fact, I have 3 of these versions right here, none of which work properly, and all sent to me from BTT, free of charge, and they wish not to have them back winking smiley Avoid at all costs please. You have been warned.
Edited 3 time(s). Last edit at 08/02/2021 05:27PM by Girl5.
August 02, 2021 10:07PM
Considering they have stopped making the skr 1.3 and 1.4,,, not a lot of option
Also no one else is having endstop issues.
August 02, 2021 10:13PM
No one else, as in not reported? winking smiley
But that will be few and far between on this board, as it is non-existent everywhere, considering it has now been out there a while?
I'm not having 'endstop' issues either, since I went back to hardware that actually works smiling smiley Funny that?
Edited 1 time(s). Last edit at 08/02/2021 10:21PM by Girl5.
August 03, 2021 08:16AM
Girl5
I noted that in your firmware you have all end-stop switches are set to false
#define X_MIN_ENDSTOP_INVERTING false
when I setup for my end-stop switches these are simple switches with wires
#define X_MIN_ENDSTOP_INVERTING true
and filament run-out
#define FIL_RUNOUT_STATE HIGH // Pin state indicating that filament is NOT present using a lighted end-stop circuit board.
An my Z-Axis proximity sensor uses
#define Z_MIN_ENDSTOP_INVERTING false
I 'am curious what happens now with the original controller when you test an M119 is XYZ triggered or not.
August 04, 2021 06:13PM
Well I have to apologize. It's nothing to do with the SKR 2, in fact, I really do not know what it's to do with? I actually give up! Got me stumped? I have tried everything. Endstop Pullups/Downs disable/enable, endstop reverse/enable/disable, with probe, without, minimum Marlin config, enabling/disabling not a lot, running board with just steppers, it's all no go on the Ender 3 V2 here, and that is with the SKR 2 & 1.4 Turbo, each exactly the same? Replaced the stepper motors for brand new ones, exactly the same, replaced the stepper wires, replaced the endstops, exactly the same? G28 from a terminal, results in the bed moving forward till it reaches the end, but tries to keep on going with an awful grinding, and nothing else happens, so I have to pull the plug. Motors all correct, as I can move them in testing (an inch at a time), XYZ, but as soon as you let it go, all hell breaks loose? M119 tests OK for all connections.
I'm beginning to think the TFT35?, it's it's own system, so what else is there?
