Re: newbee to platformio, need initial startup to configure for board only in imports file. December 30, 2022 09:51PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 12:37AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 01:31AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 01:34AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 01:49AM |
TMC UART moder set O O O M0 O O O M1 O=O O M2 O O MKS TMC2209, MKS TMC2225, MKS TMC2208 plug in to use UART mode directly
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 01:54AM |
[email protected]
YES!!!
"project init command" - I have no idea what that is. Is it a VSCode thing?
I took your ZIP file and unpacked it. I then took the ..\Marlin-2.1.1\Marlin\configuration.h file and modified it (the modified version is attached to my last post). I then opened a shell window, navigated to the directory ...\Marlin-2.1.1 and issued the platformio run -e mks_robin_nano_v3_1 command. No "project init command" involved.
I'm REALLY surprised that the touch screen worked. Usually there is a serial port that is used to communicate between the motherboard and the touch screen. As far as I can tell only the USB port is enabled. What touch screen do you have? How is it connected to the motherboard?
TFT35 that I cut the knob and pot off of so it would fit the existing window in the printers base, The versioi 1.2 board had a 40 pin ribbin cable to connct them, the newer board uses two 20 pin cables on normal header connectors.
"5 point bed leveling" - I don't think that is a Marlin thing. You'll have to read the docs as to what leveling options are available in Marlin.
That is one of the options for g29, but its a build time option, one of at least 6 ways to do it from what I've read.
I have now tried all 3 versions of the jumpers inside the driver sockets, with affecting the TMC COMMUNICATIONS ERROR at boot time. None of the three will run the motors properly. It turns out thaat I have 4 of the TMC2225's, aparently from the old board, and 5 of the TMC2209's that came with the new board kit. Supposedly interchangeable but the error at power up remains, X moves extremely slow but it the right directoin, Y moves fitfully stopping while x moves right. an Z tries to go around 10,000, stalling, and all will now generate a home error, please reset msg. So something is still fubar.
Do you have a bed leveling probe (such as a BLTouch)? Most of the advanced Marlin bed leveling options uses a matrix of probed points. Filling the matrix in manually is a real pain so a bed leveling probe is soon on the upgrade list.
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 02:03AM |
Dust
TMC COM error has many causes.
1) power, these drivers need 12/24v before or at same time as logic voltage. So powering the board just over USB will cause this error.
2) board pins are not set correctly
unforch its 2 am here, and all sockets are currently set for spi, I'll change them bsack to uart in the morning and report, right now all 5 are "error:low"
Thanks dust, back in the morning.
3) some tmc stepper driver have a jumper to set what pin is used for uart communications. Or the stepper driver uses a different pin than the motherboard is expecting (common issue if using miss matched brands of components)
You should send a M122 to the controller, it will tell you if it is all tmc stepper drivers of just 1.
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 02:31AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 11:59AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 01:33PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. December 31, 2022 08:53PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 03, 2023 01:02PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 03, 2023 01:05PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 03, 2023 04:43PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 03, 2023 10:09PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 03, 2023 11:32PM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 04, 2023 06:01AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 04, 2023 06:17AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 04, 2023 07:36AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 04, 2023 08:31AM |
Re: newbee to platformio, need initial startup to configure for board only in imports file. January 04, 2023 03:32PM |
