[SOLVED] Marlin: Filament Runout Sensor Ignored May 06, 2024 02:57PM |
Re: Marlin: Filament Runout Sensor Ignored May 06, 2024 07:06PM |
#define FILAMENT_RUNOUT_SENSOR #if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FIL_RUNOUT_ENABLED_DEFAULT true // Enable the sensor on startup. Override with M412 followed by M500. #define NUM_RUNOUT_SENSORS 1 // Number of sensors, up to one per extruder. Define a FIL_RUNOUT#_PIN for each. #define FIL_RUNOUT_PIN 19 // Hictop, instead of pins_RAMPS.h Y-MAX #define FAN1_PIN 7 // Hictop, instead of pins_RAMPS.h #define FIL_RUNOUT_STATE LOW // Pin state indicating that filament is NOT present. #define FIL_RUNOUT_PULLUP // Use internal pullup for filament runout pins. #define FILAMENT_RUNOUT_SCRIPT "M600" #ifdef FILAMENT_RUNOUT_DISTANCE_MM #endif #endif
Re: Marlin: Filament Runout Sensor Ignored May 06, 2024 07:54PM |
Re: Marlin: Filament Runout Sensor Ignored May 06, 2024 08:19PM |
Re: Marlin: Filament Runout Sensor Ignored May 06, 2024 10:23PM |
Roberts_Clif
I would never stop a started print either.
Re: Marlin: Filament Runout Sensor Ignored May 07, 2024 10:14AM |
Re: Marlin: Filament Runout Sensor Ignored May 07, 2024 08:03PM |
Re: [SOLVED] Marlin: Filament Runout Sensor Ignored May 08, 2024 09:18AM |
