My endstops do not work? (RADDS + Kossel Delta) December 17, 2017 03:23PM |
; Endstops M211 X1 Y1 Z1 S1 ; enables endstops XYZ max M574 X2 Y2 Z2 S1 ; all endstops at high end, active high M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds P4 for Z Probe, P0 for none G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height M557 R116 S20 ; Define mesh grid
Re: My endstops do not work? (RADDS + Kossel Delta) December 17, 2017 04:35PM |
Re: My endstops do not work? (RADDS + Kossel Delta) December 17, 2017 08:59PM |
Re: My endstops do not work? (RADDS + Kossel Delta) December 18, 2017 02:25AM |
It now homes correctly. Do you know if there's any way to have Marlin-Style delta homing, where it homes each tower individually in the first pass, then doing all of them at once in the second? Also, does this mean I should put my Z-Probe in the Z Max slot then, or am I just unable to use one at all now?
M558 P0 X0 Y0 Z1 H5 F120 T6000 ;
Re: My endstops do not work? (RADDS + Kossel Delta) December 18, 2017 05:06AM |
Re: My endstops do not work? (RADDS + Kossel Delta) December 18, 2017 11:04PM |
Re: My endstops do not work? (RADDS + Kossel Delta) December 19, 2017 03:19AM |
@o lampe Unusual that it would be in the PWM header instead of just having it done though endstop pins, but I suppose that does free things up for printers that actually do use min and max endstops. I guess I have more soldering to do. It's a good thing I think this hobby is fun.
