S3D Starting Code July 07, 2016 10:15AM |
Re: S3D Starting Code July 07, 2016 03:28PM |
Re: S3D Starting Code July 07, 2016 05:48PM |
Re: S3D Starting Code July 08, 2016 04:35AM |
joestefano
right after going thru the calibration process and setting G92 to Z0 I set the G31 in the config to what the M114 reads (1.85) Then I raise the heads a few mm and run G30 and the heads come down and touch the bed and Z reads 0 as it should. I then try a print file and the head prints in the air at the end of the print I home the heads and run G30 and the heads go to the level above the bed that it tried to print at and the M114 states that Z is at 0 and it is not.
Re: S3D Starting Code July 08, 2016 06:23AM |
Re: S3D Starting Code July 08, 2016 08:36AM |
Re: S3D Starting Code July 08, 2016 10:10AM |
Re: S3D Starting Code July 08, 2016 10:40AM |
Re: S3D Starting Code July 08, 2016 04:06PM |
joestefano
Update, After probing bed again the Z level seems to be correct at printing. My start code is now not working properly. It moves the heads to the purge bin then immediately moves back to the home position and heats then extrudes and begins the print. What would tell the head to move back to home from the bin?
Re: S3D Starting Code July 08, 2016 04:22PM |
Re: S3D Starting Code July 09, 2016 06:36AM |
Re: S3D Starting Code July 09, 2016 09:10AM |
Re: S3D Starting Code July 09, 2016 11:39AM |
Re: S3D Starting Code July 09, 2016 12:11PM |
Re: S3D Starting Code July 09, 2016 02:10PM |
Re: S3D Starting Code July 09, 2016 03:19PM |
joestefano
If my tools are numbered T0 & T1 should the tpost.g M116 be P0 & P1 or T0 & T1?
...RepRapFirmware version 1.04 and later supports an optional 'P' parameter that is used to specify a tool number. If this parameter is present, then the system only waits for temperatures associated with that tool to arrive at their set values. This is useful during tool changes, to wait for the new tool to heat up without necessarily waiting for the old one to cool down fully.
