New firmware 1.15 release candidate 3 August 21, 2016 02:57AM |
Re: New firmware 1.15 release candidate 3 August 21, 2016 07:09AM |
Re: New firmware 1.15 release candidate 3 August 21, 2016 07:28AM |
Re: New firmware 1.15 release candidate 3 August 21, 2016 09:46AM |
Re: New firmware 1.15 release candidate 3 August 21, 2016 11:30AM |
tomasf
Awesome. Good job!
How is the external SD card used? Like, how does paths to files on this card look? Does it get "mounted" somewhere in the file system?
Re: New firmware 1.15 release candidate 3 August 21, 2016 02:22PM |
Re: New firmware 1.15 release candidate 3 August 21, 2016 04:19PM |
Re: New firmware 1.15 release candidate 3 August 22, 2016 08:34AM |
Re: New firmware 1.15 release candidate 3 August 22, 2016 10:47AM |
unromeo21
Does the "increased PWM resolution" will help us in interfacing a Servo ?
Re: New firmware 1.15 release candidate 3 August 22, 2016 10:51AM |
Re: New firmware 1.15 release candidate 3 August 22, 2016 11:10AM |
dc42
- Bug fix: PID parameters entered using M301 had the I parameter doubled and the D parameter halved, and vice versa for PID parameters reported by M301
Important: if you are using M301 commands to set PID parameters in config.g, you will need to double the I term and halve the D term to take account of the bug fix.
Re: New firmware 1.15 release candidate 3 August 22, 2016 02:13PM |
PDBeal
dc42
Is this something that is an active bug in the older firmware versions <1.13, or is this a bug only in the 1.15+ versions? Trying to figure out if I need to re-evaluate my PID settings in the current machines despite the fact they look to be working well, or if this is only in the 1.15+ firmware.
Re: New firmware 1.15 release candidate 3 August 23, 2016 05:31PM |
Re: New firmware 1.15 release candidate 3 August 24, 2016 04:42AM |
Re: New firmware 1.15 release candidate 3 August 24, 2016 12:17PM |
Re: New firmware 1.15 release candidate 3 August 24, 2016 12:29PM |
n8bot
dc42, whenever you release a firmware update you tend to write a small blurb about it on the forums (here or duet3d). Would you mind putting those blurbs into a running text file and putting it in the release folder on your github? It can be hard to find all the posts to follow the chain of changes that have happened if you are a few firmware versions behind. Thanks again for everything.
Re: New firmware 1.15 release candidate 3 August 24, 2016 01:36PM |
Re: New firmware 1.15 release candidate 3 August 24, 2016 03:03PM |
dougal1957
I tend to agree that a running Change log would be a good idea.
Doug.
n8bot
Re: New firmware 1.15 release candidate 3 August 24, 2016 03:04PM |
minimum
I just ran into two issues after upgrade.
1. Web interface reported H1 heater fault, heater not responding to web interface controls or G-code controls.
I run a 12V module-type PSU on about 15VDC (cranked up the Vadjust) because my chinese (supposedly 12V) bed takes about an hour to get ~60C. With 15V, I'll get 90 to 100C which is OK with buildtak bed surface. New M303 auto-tuning seems to function just fine (heats up H1 ; have to keep P parameter really low: 0.1 in order not to overheat). Successful tuning did not "fix" the issue, had to revert to 1.14 for now until my 24V upgrade kit arrives.
2. While playing around with above, I noticed that after "soft" restart with M999 , H1 temp started to "creep up" slowly. Same as above, neither G-codes or web interface was able to switch off heater. PSU off-on worked until next soft reset.
PS: Forgot: Duet 0.85
Regards,
Mait.
Re: New firmware 1.15 release candidate 3 August 24, 2016 04:43PM |
Ok, I downloaded it a few days ago, and I think it was rc3 (can't check right now). Will download the final 1.15 and re-upgrade. Thanks for fast replyQuote
dc42
Mait, were you running one of the 1.15 release candidates, or the 1.15 release? Both those issues were reports in the release candidate, and both are believed fixed in the 1.15 release, which is available here [github.com].
Re: New firmware 1.15 release candidate 3 August 24, 2016 08:46PM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 01:54AM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 04:00AM |
Communication Error
An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again.
Error reason: Unknown request
Re: New firmware 1.15 release candidate 3 August 25, 2016 06:38AM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 08:24AM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 09:14AM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 09:20AM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 10:55AM |
Re: New firmware 1.15 release candidate 3 August 25, 2016 11:50AM |
minimum
1.15a:
Right after firmware upgrade (and reboot that follows), temperature creep still there.
Switching off and on seemed to do the trick until after some time got message "Error: heating fault on heater 1, temperature excursion too large".
After that of course heater at fault and unresponsive.
Tried once more off-on, now got temp creeping up again. I'm able to control heater but since I left my old pre-bugfix M301 PID setting, temp rise after setting a temperature is slow (but noticeable difference from "creep"). 10 minutes to 170C.
Changed the M301 PID settings (from M301 H1 P10 I0.10 D100 T0.50 to M301 H1 P10 I0.20 D50 T0.50). Second off-on killed the up-creep; heater at fault, no error messages in g-code console.
Re: New firmware 1.15 release candidate 3 August 25, 2016 01:00PM |
