Replacing controller for Delta with Duet November 29, 2016 02:45PM |
Re: Replacing controller for Delta with Duet November 29, 2016 03:58PM |
Re: Replacing controller for Delta with Duet November 29, 2016 05:31PM |
Re: Replacing controller for Delta with Duet December 02, 2016 10:13AM |
Re: Replacing controller for Delta with Duet December 06, 2016 08:56AM |
Re: Replacing controller for Delta with Duet December 06, 2016 09:07AM |
Re: Replacing controller for Delta with Duet December 07, 2016 09:21AM |
Re: Replacing controller for Delta with Duet December 07, 2016 03:51PM |
Treito
Many thanks.
These are the settings I can read so far. I think the first values are the important ones. But I have to finish my CoreXY first before I change the Delta. Somehow I should be able to print the new parts.
Re: Replacing controller for Delta with Duet December 08, 2016 02:17AM |
Re: Replacing controller for Delta with Duet December 08, 2016 02:21AM |
Kurzaa
I am confused, are you trying to convert your Micromake from the existing 8-bit controller to a Duet board or are you trying to configure your 8-bit board for z-probing and improve the connectors?
