Please help us test RRF 1.17 and DWC 1.14 release candidates December 21, 2016 12:56PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 21, 2016 08:59PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 22, 2016 02:51AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 22, 2016 03:22AM |
Darathy
ok since i updated to 1.17RC3 my X axis reversed itself. What was the Code that reversed it in my config file?
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 22, 2016 07:02AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 22, 2016 09:51AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 22, 2016 10:24AM |
lolocaledo
Hello,
I'm going to test it this weekend.
Can you give me information to use G29 instead G30 for grid bed compensation feature ?
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 22, 2016 01:25PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 23, 2016 11:49AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 23, 2016 08:13PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 03:12AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 04:26AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 07:03AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 08:34AM |
; Pause macro file G1 E-4 F2500 ; retract 4mm G91 ; relative moves G1 Z5 F5000 ; raise nozzle 2mm G90 ; absolute moves G1 X0 Y200 F5000 ; move head out of the way of the print
; Resume macro file G1 R1 Z2 ; move to 2mm above resume point G1 R1 ; lower nozzle to resume point G1 E4 F2500 ; undo the retraction
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 10:56AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 11:45AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 12:46PM |
Darathy
If i hit Pause now it will retract it abaut ~250mm instead of 4mm which is Written in the Pause.g:
And if i press resume it will only move 4mm and not the ~250 it retracted from the Pause button:
Any changes i need to make other then the ones stated on the github?
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 01:01PM |
dc42
Regardless of firmware version, you should always use M83 at the start of macro files that do relative extruder moves, such as your pause.g and resume.g, to ensure that extrusion is relative.
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 24, 2016 01:26PM |
Darathy
dc42
Yes putting M83 in the macro files solved the problem. And Under machine properties theres a button "Download Hightmap" which doesnt seem to do anything when i press it. Neither in chrome or firefox.
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 25, 2016 06:32AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 25, 2016 06:49AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 26, 2016 02:27AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 26, 2016 02:49AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 26, 2016 08:39AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 26, 2016 05:20PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 26, 2016 07:21PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 31, 2016 08:25AM |
I have an Ormerod 1 with a V06 Duet circuit boardQuote
dc42
Dave, thanks for your feedback. I have tried to cover the firmware update process for the wired Duets at [duet3d.com]. Let me know if you think something is missing.
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 31, 2016 08:36AM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates December 31, 2016 01:14PM |
Re: Please help us test RRF 1.17 and DWC 1.14 release candidates January 02, 2017 02:14PM |
dc42
Hi Duet and Duet WiFi users,
I have just released firmware 1.17RC3 for Duet WiFi at [github.com] and for Duet 0.6/0.8.5 at [github.com]. As usual with git, to download the files you find there you must follow the link to the file and then press the Raw button.
Chrishamm has made a Duet Web Control 1.14 beta release available and I have included it in the above locations. Please upgrade the main firmware first, then check the version number in DWC to make sure the upgrade was successful, and only then upgrade Duet Web Control.
This is your last chance to report new bugs before I do the 1.17 release. So if you have a working 3D printer running RepRapFirmware and can spare a little time, please try out the new RepRapFirmware and Duet Web Control and let us know of any new problems you find (or that there are no problems). Please visit [github.com] and scroll down to and read the upgrade notes before you install the new firmware.
For those of you using the new G29 grid bed compensation feature, Duet Web Control now gives you a visual representation of the height map. Thanks to Chrishamm for his hard work on this. Here is an example which shows quite clearly the Y axis twist on my Ormerod.
