Does the Duet support Gowoops 3D Printer Controller LCD?
Posted by dmiles
January 03, 2017 03:05PM
Apologize if this has been covered before, but I've searched high and low, and haven't been able to find any info on this anywhere. Basically looking to possibly buy a duet, but would like to know if it would support my existing touchscreen, Gowoops 3D Printer Controller LCD MKS TFT32 3.2'' LCD Display. I suspect the answer is no since this is an MKS device, but I know there is an interface board available for the Duet, and just wondering if that would make it work. Thanks.
Re: Does the Duet support Gowoops 3D Printer Controller LCD?
June 19, 2017 06:52AM
Did you mean something like this?
June 19, 2017 08:09AM
Yes, exactly! Is it plug and play, or would I need some type of adapter? Thanks!
June 19, 2017 08:28AM
This is custom firmware (not related to MKS) and it's work in progress: [github.com]
June 27, 2017 12:13PM
you beauty how hard is it to get it going i have a mks tft 32 bee following this topic
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
June 28, 2017 12:48PM
what jtag programmer your using?
up and running
July 07, 2017 08:08AM
ST-LINK v2 or Segger J-Link will work. Cheap clones are okay. On-board STM Discovery evaluation board debuggers are also okay, as well as J-Link OB.
Keep in mind that MKS-TFT has 5v UART while Duet boards have 3.3v UART. While it may work if connected as-is I recommend using level shifters between MKS-TFT and Duet board to avoid possible damage to Duet controller.
Also the firmware is in early alpha so it's not recommended for regular use, only for testing.
July 07, 2017 08:12AM
I'd like to know if someone is interested in having PanelDue fimware running on 2.4" Nextion LCD (with original factory firmware wiped out). These boards are dirt-cheap, for $16 (including delivery) you can have a print-server with sd-card, lcd and touchscreen. The only disadvantage is small screen size...
Edited 1 time(s). Last edit at 07/07/2017 08:12AM by rstepanov.
August 21, 2017 08:18AM
rstepanov
Will that work on the Duet v0.6?
September 06, 2017 04:49PM
Most likely answer is yes. Hovewer I only tested it with Duet 0.8.5 and Duet Ethernet. You are free to try it yourself smiling smiley
June 30, 2018 11:17AM
Please, help me. I put files inside but its not working. it's mirror image and lighter.
December 03, 2019 09:10AM
Hello,
I found your post about PanelDue firmware loaded onto a MKS TFT touchscreen, this is a very interesting project as we are all looking to get rid of MKS firmware as is useless and install a decent firmware on their panels as they are not bad at all.
I know is an old post but still interested in doing it. How i can flash the firmware in the panel? i am not an expert in this field.
I have duet panel and always update the firmware with Bossa program.
Any help would be great, Thank you!!
Best regards
