RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 07, 2017 10:07AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 07, 2017 10:51AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 07, 2017 11:07AM |
David J
David,
A quick check - which version should I download for a Duet v0.6?
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 07, 2017 07:51PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 08, 2017 04:59AM |
joestefano
David, do I still use bossac to upgrade the Panel Due firmware?
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 09, 2017 07:56PM |
..Quote
dc42
David J
David,
RepRapFirmware-1.18.bin, iap.bin and DuetWebControl-1.15a.zip.
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 10, 2017 02:50AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 10, 2017 07:43AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 12, 2017 03:48PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 24, 2017 01:58PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 25, 2017 03:08AM |
DRTak
DC42. I have upgraded to the PanelDue firmware 1.16. When I hit the Print button nothing happens. I have back out to the main screen and find the CONTROL button. Find the SD card symbol. Then select file and print. Is this normal? Before with the other firmware, I would hit PRINT on the paneldue select file and print.
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released April 25, 2017 11:31PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 02, 2017 03:52AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 02, 2017 08:36AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 02, 2017 10:09AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 21, 2017 03:35PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 21, 2017 05:36PM |
3D-Print
I jsut updated by firmware from 1.12a-dc42 to 1.18.1 and now my PID setting are not working. I seems like my bed is using bang bang pulses vs. PID. Prior to the update, my SSR would flicker and maintain a very stable bed temp. Now it is either on or off and quite variable.
Here are my M301 codes from the config file:
M301 H0 P24 I0.80 D105 T0.50 S1.0 ; PID settings for Print Bed (-P means bang bang setting and not PID)
M301 H1 P08 I0.20 D109 T0.50 S1.0 ; PID settings for Heater 1 (Diamond HotEnd)
Did something change that I am missing or now need to do differently.
RepRapFirmware 1.15 release notes =================================== 1. If you are upgrading from a previous releases other than a 1.15 release candidate, then if you have any M301 commands in your config.g file, you should double the I parameters and halve the D parameters in those commands. This is because of a long-standing bug in previous releases of RepRapFirmware which has been corrected in this release. 2. This release includes a heater control auto tuning feature. See [duet3d.com] for how to use it. This feature is still somewhat experimental and will be refined in a future release. 3. The temperature monitoring is much more strict compared to previous releases, to better detect situations such as a thermistor or heater cartridge falling out of the heater block, which can pose a fire risk if not detected. If you have a paricularly strong or weak heater, you may get false alarms. The simplest way to avoid this is to run auto tuning so that the firmware can build a more accurate model of normal behaviour. 4. DuetWebControl-1.12.zip is by Christian Hammacher and is provided here for your convenence. His master repository is at [github.com].
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 21, 2017 11:20PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 24, 2017 08:26PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 25, 2017 07:24PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 31, 2017 12:43AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 31, 2017 01:59AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 31, 2017 08:55AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released May 31, 2017 06:28PM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released June 01, 2017 01:35AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released June 01, 2017 01:45AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released June 01, 2017 03:03PM |
PDBeal
Did you power cycle the duet after installing the new firmware? On all four of mine (duet 0.8.5) when I installed the new iap.bin and the 1.18.1 firmware I had to power cycle the boards before the DWC was able to connect. The reboot on the firmware upload wasn't sufficient for whatever reason.
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released June 04, 2017 10:33AM |
Gaou
PDBeal
yes i did . i had it on for more than an hour .
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released June 05, 2017 03:08AM |
Re: RepRapFirmware 1.18 and Panel Due firmware 1.16 released June 05, 2017 11:04AM |
