Octopi with duet 0.8.5 usb July 16, 2017 11:22AM |
Re: Octopi with duet 0.8.5 usb July 16, 2017 01:30PM |
Re: Octopi with duet 0.8.5 usb July 17, 2017 01:57AM |
Re: Octopi with duet 0.8.5 usb July 17, 2017 03:19PM |
Re: Octopi with duet 0.8.5 usb July 18, 2017 09:01AM |
Re: Octopi with duet 0.8.5 usb July 18, 2017 11:11AM |
ls /devwithout the Duet plugged in, and then with it plugged in, and see if something new has shown up. That's your USB device. If you don't see a change, OctoPrint will never find it.
Re: Octopi with duet 0.8.5 usb July 18, 2017 03:28PM |
Re: Octopi with duet 0.8.5 usb July 18, 2017 04:28PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 03:21AM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 08:50AM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 11:03AM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 12:26PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 01:46PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 02:39PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 04:07PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 04:37PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 04:56PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 05:35PM |
Re: Octopi with duet 0.8.5 usb July 19, 2017 06:07PM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 03:46AM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 04:11AM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 04:17AM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 10:36AM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 11:03AM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 04:04PM |
Napalm1432
YES YES that fixed it all
just a note for myself if i ever run into the same problem, when uploading the firmware with Bossa, do erase all and boot to flash
Re: Octopi with duet 0.8.5 usb July 20, 2017 04:17PM |
Napalm1432
It doesn't seem to initialize the sd card in octopi right now though, i'm looking for a fix now
Running an M20 from the octopi terminal does list the gcode files (only 1, the testprint.gcode)
Re: Octopi with duet 0.8.5 usb July 20, 2017 04:50PM |
Re: Octopi with duet 0.8.5 usb July 20, 2017 06:05PM |
dc42
If you do want to print and/or upload files over USB, make sure that the sender does not wait for an OK response after sending each line of gcode. Many USB host programs have this as an option. Last time I looked, Octoprint didn't, but someone did a patch for it.
Re: Octopi with duet 0.8.5 usb September 04, 2017 01:55PM |
Re: Octopi with duet 0.8.5 usb September 04, 2017 03:21PM |
