Partially heated bed June 11, 2018 03:24AM |
Re: Partially heated bed June 11, 2018 03:48AM |
Re: Partially heated bed June 11, 2018 03:53AM |
Re: Partially heated bed June 11, 2018 04:03AM |
Re: Partially heated bed June 11, 2018 06:30AM |
chriske
So I need to add G-code in the slicer to determine what section(s) of the bed needs to be warmed up...correct..?
Re: Partially heated bed June 12, 2018 10:55AM |
Re: Partially heated bed June 12, 2018 01:36PM |
Re: Partially heated bed July 18, 2018 01:26AM |
Re: Partially heated bed July 18, 2018 03:55PM |
xrodney
How about printing multiple objects sequentially, wouldn't just scanning for 1st layer reveal the position (print bounds) of the just 1st object?
Re: Partially heated bed July 19, 2018 02:09AM |
Re: Partially heated bed July 19, 2018 05:31AM |
o_lampe
A good bed usually has a good heat spreader. ( per definion ) That's why multiple heat zones don't make much sense to me.
You could use a separated heat spreader per heating zone, then put a glass plate above. But would that really safe some energy?
o_lampe
A glass plate needs higher temps, AFAIK.
