Hi all
Yes, I do know the connections that are used in the DuetWifi board for the touch, however, on the Duet 2 Maestro board, you connect directly to the header Z probe, has this now been implemented on the DueteWifi as well? if you use an expansion board with the DueteWiFi it uses the expansion header, so where then do you connect a BLTouch too?
Thanks
