Re: A Very Different Extruder July 19, 2021 01:55AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: A Very Different Extruder July 19, 2021 03:05PM |
Re: A Very Different Extruder July 19, 2021 04:33PM |
Re: A Very Different Extruder July 19, 2021 09:21PM |
Re: A Very Different Extruder July 19, 2021 09:32PM |
VDX
... there where/are some other versions too around -- it's an older principle, patented 1952 by a Mr. Uhing for moving spool-heads on horizontal axes ... but could be used for other tasks too
Especially this "scewed tap-rollers" were sometimes used for special high precision CNC-applications ...
Re: A Very Different Extruder July 20, 2021 03:07AM |
Re: A Very Different Extruder July 20, 2021 10:11AM |
Skrogh
What made you switch from the treaded sleeve to a single, sharpened concentric race? Ease of manufacturing? Is there a performance difference? Intuitively I'd excpect a lower gripping force, but also less grinding, compared to the threaded sleeve.
Re: A Very Different Extruder July 24, 2021 08:08AM |
Re: A Very Different Extruder July 24, 2021 05:34PM |
dekutree64
Brilliant design! Might actually be light enough to convert my SCARA printer to direct drive. I have a 50 gram round NEMA14 I could use. And TMC2209 drivers, so I can adjust the microsteps to whatever works best. I'd prefer to use non-canted axles so I can make the carrier out of aluminum, but would all three rollers need to be threaded then since the filament would be getting dragged axially across the smooth rollers, or do you think the friction would be negligible? It would be nice not to have to worry about the issue of cutting multiple thread starts into the filament.
Re: A Very Different Extruder July 25, 2021 07:33AM |
Re: A Very Different Extruder July 25, 2021 04:25PM |
dekutree64
Thanks, that confirms my thoughts. I probably could make a fixture to mill/drill the tilted axes on my 3DOF mini-mill, but I'd actually prefer the higher effective gear ratio since it should allow using even lighter motors. There is one seller for pancake NEMA11 on ebay, though it costs $25 with shipping, and has a 4mm shaft, which doesn't leave much meat after drilling a 2mm hole.
I'm also toying around with the idea of making one of these based on a small outrunner instead of NEMA stepper. I'm fairly sure it would be possible to rewind one as a stepper as long as it has an even number of stator arms. Resolution would be very coarse (for example the common 12 stator arms/14 rotor magnets would be 28 steps per revolution, or 12.86 degrees per step), so probably will need microstepping even with straight axles (if my calculations are correct, that would give 128 full steps per mm with 1.75mm filament and 10mm rollers with 1.25mm thread pitch). Both the roller carrier and hollow mounting structure between the motor and hotend could potentially be eliminated. But there's nowhere to mount the anti-torsion wheel without an equally heavy structure to reach around the motor, so it may be a no-go. Depends on if I can come up with some other anti-torsion technique.
Very Different Extruder Bill of Materials July 26, 2021 07:04PM |
Re: A Very Different Extruder July 27, 2021 08:58PM |
Re: A Very Different Extruder July 28, 2021 07:58AM |
Re: A Very Different Extruder July 28, 2021 12:03PM |
dekutree64
I've decided to go with the canted axle/sharpened bearing flange approach. I'm not sure my mill could handle boring out a 10mm steel screw, nor do I have an easy way to get it centered and vertical under the spindle, so I'm going to have to make some new fixturing regardless. And the bearing should be sharper and longer lasting.
I'm using a 4x8x3mm flange bearing because it's what I have on hand (along with a couple of 4x9x4mm without flange). And I think the 9.2mm flange diameter is good, because it gives exactly 0.1mm "extra" radius for penetration into the filament compared to the two idlers. It also makes grinding easier since you can just go until the edge is sharp, rather than having to reduce the diameter by a precise amount.
I made a 30 degree holder for my trusty DMT Dia-sharp stones out of a scrap of 2x4, with a little ledge glued along the edge to prevent the stone sliding down. Then hot glued the bearing to a 4mm rod, chucked it up in my mini-mill (a drill press would work just as well), applied some more hot glue, and went at it. I like to rub some water on the diamond stone for cooling and dust collection. Turn on the spindle and gently slide the stone back and forth against the bearing, while gradually changing Z position so you're not just running back and forth along the same line on the stone (spread out wear on the stone, and don't have to stop and clear away dust). Once the edge is sharp, repeat with finer diamond stones to polish. You really only need extra-extra-coarse and extra-extra-fine, but it's nice to have one more grit inbetween (I'd recommend fine).
Then take it out of the chuck, put some alcohol on your thumb and pick off the hot glue (hot glue releases with alcohol). Easy
Re: Very Different Extruder Bill of Materials July 28, 2021 09:35PM |
Re: A Very Different Extruder August 10, 2021 12:15AM |
Re: A Very Different Extruder August 10, 2021 08:03AM |
Re: A Very Different Extruder December 08, 2021 06:47PM |
Re: A Very Different Extruder January 23, 2022 01:04PM |
dlang
you mention a few posts back that you considered using a bldc, rather than re-wiring it, consider going with a smart controller like the odrive. It needs an encoder, but you don't need to go with a high resolution encoder like people normally do, as you note with 28 positions/rev you can get to 125 steps/mm, so a 7 ppr quad encoder setup (say with a copy photodiods) would be enough resolution, and the bldc will be very happy to spin faster, and to stop/reverse for pulling the filiment back.
a couple other youtube videos of folks doing similar things (but going with much smaller diameter, custom rollers) [www.youtube.com] [www.youtube.com]
Re: A Very Different Extruder January 23, 2022 06:07PM |
It's interesting that all of these have rollers that appear to be 20 or 30mm tall. If you play with 3 pencils, it becomes quickly apparent that there can be only ONE central point of contact between 3 canted rollers, which is what makes the roller positions and spacing so critical.
Any roller taller than that one point of contact is just wasted space and mass.
Re: A Very Different Extruder January 23, 2022 08:26PM |
dlang
The added length would give them room for the bearings and to get the bearings far enough away from the filament to hold them.
I could see tall skinny bearings being lighter than short fat ones (and lave less angular inertia)
you do get a little more than a single point of contact as the sharp edges of the rollers do bite in to the filament, but I agree it's not much more.
Re: A Very Different Extruder January 23, 2022 09:41PM |
Re: A Very Different Extruder January 24, 2022 09:21AM |
dlang
one bearing thick, but a largish bearing 10mm dia, x 4 mm tall is ~315mm^3
something 4mm dia and 25mm tall would be about the same volume (so similar mass, although bearings are not solid), but smaller diameter, so less angular momentum (i.e. easier to stop and reverse)
I am NOT saying that their design is better, just that it may not be as obviously worse as first glance would have it. I was just pointing out other similar ones, with the idea of cross pollinating ideas.
Your design looks easier to make the working end of.
I'm not thrilled about trying to drill through the center shaft of a stepper. I would just prefer to be able to use a BLDC with the solid pin replaced by a tube rather than trying to drill through the center shaft of a stepper (on many BLDC motors they are designed to be able to be pressed out and replaced)
Re: A Very Different Extruder February 09, 2022 05:27PM |
Re: A Very Different Extruder February 10, 2022 10:14AM |
dekutree64
Finally got around to finishing my poor man's schnekenstruder, and it actually works! At least mostly. For some reason it doesn't seem to be able to retract. Even with jerk/acceleration set very low, motor current set much too high for continuous running, and retraction distance 0.5mm, it still just makes a suffering noise and fails to rotate backward. But if I command it to rotate forward and backward from the move axis menu, it does it just fine. Takes no effort to do it by hand either, so it must be some sort of software issue.
The motor is NEMA14 pancake. I epoxied a 3D printed pneumatic fitting adapter to it for reverse bowden setup. The tube should also serve the purpose of the anti-torque wheel, although from the other thread it sounds like it isn't necessary anyway. I'm still using the bowden heatsink, so there is about a 15mm space between the rollers and where the filament goes into the 2mm heatsink hole. But I don't think it's enough to matter for PLA, which is all I plan to use on this machine.
I reworked the carrier for 4mm bearings. The cutter is 4x8x3mm flanged, sharpened on both sides (to sharpen the difficult side of the flange, I used the same angled block as in my previous post, but with a diamond grit dremel wheel protruding off the top edge). The passive rollers are 4x9x4mm. I just used regular m4x10mm screws and split lock washers instead of the fancy shoulder screws and bellevilles. I did have to file a bevel around the edge of one of the lock washers since it was near impossible to keep it from jamming the smaller diameter cutter bearing. The other two didn't need any custom work, although it can take a couple tries to get them screwed down in the right spot to not jam the bearings.
I currently have it mounted to the printer with screws, but I may change to magnets. Haven't tried unloading it yet...
Thank you rq3 for sharing this brilliant extruder design!
EDIT: Got the retraction issue sorted. Apparently any speed above 5mm/s results in missed steps. Acceleration does not seem to affect it, so I've gone back to the default 10000 and jerk set to 10. Not sure why speed would be such an issue though. Steps per mm is 288 with 0.9 degree full steps, so 5mm/s is only 1440 steps per second. And that's 216RPM, so I wouldn't think torque dropoff would be the problem, especially since motor current doesn't seem to affect it either. I'm currently running a conservative 150mA. The motor is rated for 500mA, but even 250 gets uncomfortably hot after running for half an hour. 200 may be ok, will need to do another half hour test.
I definitely need to upgrade to ABEC 5 bearings. These cheap ones are pretty floppy, giving it some backlash. I can hear it every time it reverses direction, and after printing a retraction test the filament looks pretty chewed up due to not following the spiral groove back. I think the screws and lock washers are fine though. As far as I can tell, the inner race of each bearing is firmly held in place.
Re: A Very Different Extruder February 11, 2022 12:03AM |
Re: A Very Different Extruder February 13, 2022 10:32PM |
Re: A Very Different Extruder February 14, 2022 12:29PM |
dekutree64
Ah, I'm glad I didn't bother with magnets yet then. I recommend using coarse thread screws if you're screwing into plastic. Fewer turns to take them in and out, and at least in my experience machine threads in plastic tend to wear out more quickly.
I look forward to the results with your NEMA 11. My guess is that it will be a bit underpowered. The NEMA 14 seems just right, with enough headroom that you can run cool without worrying about missing steps. Though with an aluminum carrier, a heat-tolerant mounting surface, and no bowden adapter epoxied to it like mine, the stepper should be fine running a little hot.
I still want to try the outrunner design I posted before as well, especially now that we know the anti-torque device is unnecessary. But I won't have a place to put the bowden adapter, so I may have to do it on my other printer. The design is a little mechanically iffy since it puts the extrusion force pulling upward on the roller screws, and pulling upward on the rotor so the shaft retainer clip will have to be shimmed just right so there's no wiggle room. But it should be about as lightweight as you can get.
Re: A Very Different Extruder February 14, 2022 03:34PM |
