*solved* A Blender made 125 tooth pulley won't be sliced correctly sad smiley
Posted by roland
December 03, 2012 05:03PM
time is pressing.. and i won't get my big pulley-mould printed.
with some try and error it worked with a 112 pulley:
but the 125 pulley that i made exactly like the smaler one is only sliced into big "black" discs:
It is a perfect manifold (strg+shift+alt+M no longer yields any verts)
and i simply don't know what else i can try :'(
my blend file: pulley125b.rar
the stl export of the 125 tooth pulley mould: pulley125b.stl
the gcode file: pulley125b_export.zip
i don't know why slic3r says "The model has overlapping or self-intersecting facets."
dasRoland.de
Ideas welcome :-/
Slicing D:\reprap\pulley\pulley125b.stl
Slicing:  Slic3r/slic3r.exe $s --load Slic3r/config.ini --output $o
=> Processing input file D:\reprap\pulley\pulley125b.stl
=> Processing triangulated mesh
The model has overlapping or self-intersecting facets. I tried to repair it, however you might want to check the results or repair the input file and retry.
=> Generating perimeters
=> Detecting solid surfaces
=> Preparing infill surfaces
=> Cleaning up
=> Detect bridges
=> Cleaning up the perimeters
=> Generating horizontal shells
=> Combining infill
=> Infilling layers
=> Generating skirt
=> Exporting GCODE to D:\reprap\pulley\pulley125b_export.gcode
Done. Process took 1 minutes and 51.406 seconds
Filament required: 49248.1mm (348.1cm3)
49247.13568 mm of filament used in this print
the print goes from 12.739000 mm to 227.379000 mm in X
and is 214.640000 mm wide
the print goes from 12.604000 mm to 227.384000 mm in Y
and is 214.780000 mm wide
the print goes from 0.400000 mm to 22.000000 mm in Z
and is 21.600000 mm high
Estimated duration (pessimistic):  55 layers, 09:10:15
Edited 1 time(s). Last edit at 12/03/2012 06:58PM by roland.
open | download - pulley125.JPG (49 KB)
open | download - pulley112.JPG (49.7 KB)
open | download - pulley112gcode.JPG (52.2 KB)
open | download - pulley125gcode.JPG (151.8 KB)
open | download - nice pulley 112.JPG (253.1 KB)
Re: A Blender made 125 tooth pulley won't be sliced correctly sad smiley
December 03, 2012 06:30PM
okay, the 112 pulley does not have these "intersecting faces":
Slicing D:\reprap\pulley\pulley112.stl
=> Processing input file D:\reprap\pulley\pulley112.stl
=> Cleaning up
=> Detect bridges
=> Combining infill
=> Infilling layers
=> Generating skirt
=> Exporting GCODE to D:\reprap\pulley\pulley112_export.gcode
Done. Process took 5 minutes and 21.547 seconds
Filament required: 11125.1mm (78.6cm3)
11124.07823 mm of filament used in this print
the print goes from 22.780000 mm to 217.210000 mm in X
and is 194.430000 mm wide
the print goes from 22.782000 mm to 217.212000 mm in Y
Estimated duration (pessimistic):  55 layers, 03:49:08
some more hours of frustrating blender-work tomorrow..
*good night and good luck*
solved :-)
December 03, 2012 06:57PM
Okay, i had to "normals - recalculate outside".
So always show the normals before exporting to stl:
open | download - normals.JPG (99.7 KB)
Re: *solved* A Blender made 125 tooth pulley won't be sliced correctly sad smiley
December 11, 2012 03:17PM
glad you got it. what's the pulley for?
January 22, 2013 05:54AM
I usually use cloud.netfabb.com to check my STL exports.
It's a beautiful design btw! What technique did you use?
