FoldaRap
Revision as of 16:46, 29 July 2012 by Spiritdude (talk | contribs) (History)
FoldaRap Documentation
FoldaRap
a folding reprap
RepRap
In my obsession dreaming of a folding RepRap, I finally started to make one, and now (after 5-7 months of development) I'm able to travel with it around the town/country/world :) (adventures pictured on flickr / youtube / ustream)
Specifications
  • Printed Parts: ???
  • Non-Printed Parts: ???
  • Material Cost: ???
  • Cost: ??? (assembled)
  • Printing Size: 5.5"x5.5"x5.5" or 14cm x 14cm x 14cm
  • Precision: ??? (position), ??? (printing)
  • Speed: ??? (position), ??? (printing)
Special Features
  • Foldable
  • Based on 20x20mm aluminium extrusion (with 6mm slot)
  • Easy to build, with few tools (the printed parts are based on a 20mm grid (for overall aesthetic and mostly to ease the design), are generally 4mm thick, and fit the beams in a way you have nothing to measure during the assembly
  • 1.75mm Direct Driven Bowden Extruder ; fixed on the x-axis for less hysteresis and higher z-print
  • Peltier Heatbed (fast heat-up)
  • Big Blue Power Switch (my preferred detail ^^)
  • Print volume 140 x 140 x 140 mm (or ~2840 cm^3)
  • Footprint : 208 x 348 mm / Total volume : 335 x 348 x 318 mm (+21mm with the handle) / Folded and slided : about 335 x 376 (+21mm with the handle) x 98 mm / 3-4kg
R&D
Fold-a-slot
Direct link to the little crowd-funding campaign here : http://www.ulule.com/foldarap/ (EN) / http://fr.ulule.com/foldarap/ (FR)
See also the sub-forum :
To do
  • *in progress* make an extruder-idler for standards 623 and 624 bearings (may try to integrate the ron's compact extruder idler and/or ezmobius's one at the same time)
  • *in progress* make an extruder-idler for mini-hyena to allow different combination of drive-gear
V01 (beta)
Huxley size
Mendel size
From the VertX to a whole printer, it's the next big project I started to dream of, some months ago, because I want to have a folding RepRap for travels/exhibitions/conferences that only need to be plugged to print (even if the Huxley is already not bad for that).
  • Foldable (first inspiration came from a folding ladder that my father have, then the Bonsai_RepStrap, this thread where Mendel90 first appeared, and from my Pocket Engraver structure)
  • Few threaded rods (I first thought about aluminium extrusion, but finally I'll assemble printed parts to make the frame, which is also good for replication/changes/scaling)
  • Easily scalable (can be 300x300x300 or 50x50x50, as we want).
  • Sells Mendel style Z-axis (one motor as I like to be able to manually tweak the Z)
More Inspiration
Some details that I found interesting or related or want to integrate to this idea of a foldable machine...
External links, media/press, etc.
I like feedback from the community, but a little attention from a blog or other people is always good :)
  1. hackaday mention a neat folding reprap, in their article about the many choices of repraps to build
  2. twittpic of Korben at the NuitDuHack2012
  3. Paradoxe temporel [20] and [21] also during the NDH2012
  4. From a little post in the GOALL, to Lorraine numérique / e-alsace
  5. Dans-ce-pot
  6. Retour sur la nuit du hack 2012
  7. B3dge
  8. 3ders.org
  9. demonter.net
  10. Mobile Solar Powered 3D Printer Project on Appropedia (a solar powered foldarap ? :))
  11. Faveoly
  12. 3druck
  13. Bundlr
  14. Personnal Factory and several other tumblrs
  15. Fabbaloo
  16. 3dprinter
  17. imastresd
  18. nirvasite
  19. Ponoko
  20. Makezine
  21. genomicon
  22. dailygeekshow
History
  • 2011/11: started to design a folding Mendel, then a folding Huxley
  • 2012/01: starting to design the Fold-a-slot (actual FoldaRap)
  • 2012/05/24: First Print !!
  • 2012/06/23: First known user build started by Spacexula :)
  • 2012/06/28: beginning of the crowdfunding campaign
  • 2012/07: 2-3 more people are starting to build one
  • 2012/07/10: the crowdfunding campaign reached 100% ! (30 days lasting)
