G-code
Revision as of 05:21, 20 September 2017 by Dc42 (talk | contribs) (M305: Set thermistor and ADC parameters)
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications as well. See also on Wikipedia's G-code article.
There are a few different ways to prepare GCode for a printer. One method woull be to use a slicing program such as Slic3r, Skeinforge or Cura. These programs import a CAD model, slice it into layers, and output the GCode required to print each layer. Slicers are the easiest way to go from a 3D model to a printed part, however the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. This particular page is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
Unfortunately human nature being what it is, the best procedures aren't always followed, so some multiple uses of the same code exist. The rule which should be followed is that later appearances of a code on this page (later than the original use of a code), are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be preferred. Note that the key date is appearance here, not date of implementation.
Introduction
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0
G28
G1 F1500
G1 X2.0 Y2.0 F3000
G1 X3.0 Y3.0
Slicers will (optionally?) add GCode scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
Support Marlin RepRapFirmware Repetier Smoothie Klipper Prusa MK4duo MakerBot
Partial ??? Experimental deprecated ??? ??? Partial ???
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa
??? No ??? Yes ??? Yes automatic ???
Here means:
{{yes}}
The Gcode is fully supported by the firmware.
{{partial}} or {{experimental}}
There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
automatic
The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
{{no}}
The firmware does not support this Gcode.
deprecated
The firmware deprecated this Gcode. The firmware author(s) should amend the deprecated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter Meaning
Tnnn Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders.
U,V,W Additional axis coordinates (RepRapFirmware)
Hnnn Parameter - used for heater number in PID Tuning
Ennn Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume.
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment
N4 G92 E0*67
; So is this
N5 G28*22
Special fields
N: Line number
Yes Yes Yes ??? ??? ??? Yes ???
 ? Yes ??? Yes Yes Yes Yes ???
Example
N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
 ? Yes ??? Yes ??? No Yes ???
Example: *71
The firmware compares the checksum against a locally-computed value. If they differ, it requests a repeat transmission of the line.
Checking
Example
N123 [...G Code in here...] *71
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0;
   cs = cs ^ cmd[i];
Buffering
Yes Yes ??? ??? ??? ??? Yes ???
Yes ??? ??? Yes ??? Yes Yes ???
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue.
G-commands
G0 & G1: Move
Yes Yes Yes Yes ??? ??? Yes Yes
Yes Yes Yes Yes Yes Yes Yes ???
  • G0 : Rapid linear Move
  • G1 : Linear Move
Usage
Parameters
Not all parameters need to be used, but at least one has to be used
Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
Examples
G0 X12               ; move to 12mm on the X axis
G0 F1500             ; Set the feedrate to 1500mm/minute
G1 X90.6 Y13.8 E22.4 ; Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material
G1 F1500           ; Set feedrate to 1500mm/m
G1 X50 Y25.3 E22.4 ; Move and extrude
In the above example, we first set the feedrate to 1500mm/m, then move to 50mm on X and 25.3mm on Y while extruding 22.4mm of filament between the two points.
G1 F1500                 ; Feedrate 1500mm/m
G1 X50 Y25.3 E22.4 F3000 ; Accelerate to 3000mm/m
However, in the above example, we set a feedrate of 1500 mm/m, then do the same move, but accelerating to 3000 mm/m. Everything stays synchronized, so extrusion accelerates right along with X and Y movement.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in a way that ensures everything moves smoothly together and the right volume of material is extruded at all points.3
Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5).
G2 & G3: Controlled Arc Move
Yes1 No Yes Yes ??? ??? Yes ???
Yes Yes No No Yes Experimental No ???
Usage
Parameters
Examples
G2 X90.6 Y13.8 I5 J10 E22.4
(Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4
(Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
Pause the machine for a period of time.
Parameters
Pnnn Time to wait, in milliseconds
Snnn Time to wait, in seconds (Only on Repetier, Marlin, Smoothieware, and RepRapFirmware 1.16 and later)
Example
G4 P200
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G6: Direct Stepper Move
No Use G1 S2 No No ??? ??? No No
No No No No No No No ???
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
Parameters
Annn Stepper A position or angle
Bnnn Stepper B position or angle
Cnnn Stepper C position or angle
R Relative move flag
SCARA Examples
G6 A45     ; Move SCARA A stepper to the 45° position
G6 B20 R   ; Move SCARA B stepper 20° counter-clockwise
DELTA Example
G6 C10 R   ; Move DELTA C carriage up by 10mm
G10: Tool Offset
No Yes No No ??? ??? No ???
??? No No No Yes No No ???
Usage
G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn1
Parameters
Pnnn Tool number
Xnnn X offset
Ynnn Y offset
U,V,Wnnn U, V and W axis offsets5
Znnn Z offset2
Rnnn Standby temperature(s)
Snnn Active temperature(s)
Examples
G10 P2 X17.8 Y-19.3 Z0.0
(sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
G10 P1 R140 S205
(set standby and active temperatures3 for tool 1)
The precise meaning of the X, Y (and other offset) values is: with no offset this tool is at this position relative to where a tool with offset (0, 0, 0) would be. So if the tool is 10mm to the left of a zero-offset tool the X value would be -10, and so on.
See also M585.
Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
2It's usually a bad idea to put a non-zero Z value in as well unless the tools are loaded and unloaded by some sort of tool changer or are on indepedent carriages. When all the tools are in the machine at once they should all be set to the same Z height.
4The NIST G-code standard mentions an additional L parameter, which is ignored (except in smoothie). This command is subject to discussion.
5Tool offsets are applied after any X axis mapping has been performed. Therefore if for example you map X to U in your M563 command to create the tool, you should specify a U offset not an X offset. If you map X to both X and U, you can specify both offsets.
G10: Retract
Yes dc42,ch Yes: 0.92 Yes ??? ??? Yes ???
??? No No No No No No ???
Parameters
Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
Example
G10
Retracts filament according to settings of M207 (Marlin, RepRapFirmware) or according to the S value (Repetier).
RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent.
G11: Unretract
Parameters
Example
G11
Unretracts/recovers filament according to settings of M208 (Marlin, RepRapFirmware) or according to the S value (Repetier).
G12: Clean Tool
Yes: 1.1.0 via macro feature No No ??? ??? Yes ???
Usage
[P<0|1>] [S<count>] [T<count>]
G12 Pnnn Snnn Tnnn
Parameters
Pnnn1 Pattern style selection
Snnn Number of strokes (i.e. back-and-forth movements)
Tnnn Number of repetitions
Examples
G12 ; stroke pattern (default)
To generate a three triangle zig-zag pattern which will be stroked three times time use the following command. G12 P1 S3 T2 ; zig-zag pattern with 2 triangles
Notes
1In Marlin firmware and Derivatives Mk4duo this is implemented by hard-coded firmware behaviours As defined for variables NOZZLE_CLEAN_STROKES, NOZZLE_CLEAN_START_POINT, NOZZLE_CLEAN_END_POINT and NOZZLE_CLEAN_PARK.
With NOZZLE_CLEAN_PARK enabled, the nozzle will automatically return to the XYZ position after G12 is run.
More on this behaviour is documented inside of the code base.
G17..19: Plane Selection (CNC specific)
Yes:1.1.4 No ??? ??? ??? ??? No ???
Yes ??? ??? ??? Yes No ??? ???
  • G17 : XY (default)
  • G18 : ZX
  • G19 : YZ
This mode applies to G2/G3 arc moves. Normal arc moves are in the XY plane, and for most applications that's all you need. For CNC routing it can be useful to do small "digging" moves while making cuts, so to keep the G-code compact it uses G2/G3 arcs involving the Z plane.
These commands are supported in Marlin 1.1.4 and up with ARC_SUPPORT and CNC_WORKSPACE_PLANES enabled.
G20: Set Units to Inches
Yes Yes Yes Yes ??? ??? Yes ???
Yes Yes No Yes Yes No Yes ???
Example
G20
G21: Set Units to Millimeters
Example
G21
G22 & G23: Firmware controlled Retract/Precharge
No No No No ??? ??? No ???
Usage
G22 ; Retract
G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
G26: Mesh Validation Pattern
Yes: 1.1.0 No No No ??? ??? No No
Usage
G26 C P O2.25 ; Do a typical test sequence
The G26 Mesh Validation Pattern is designed to be used in conjunction with various Mesh Bed Leveling systems – those that adjust for an uneven —rather than just tilted— bed. The G26 command prints a single layer pattern over the entire print bed, giving a clear indication of how accurately every mesh point is defined. G26 can be used to determine which areas of the mesh are less-than-perfect and how much to adjust each mesh point.
G26 has large feature list, including a built-in test that extrudes material onto the bed. By default this is configured for PLA temperatures and a nozzle size of 0.4mm. (This will be adjustable in an upcoming version of Marlin.)
See the G26_Mesh_Validation_Tool.cpp file in the Marlin source code for full documentation of the G26 parameter list.
G28: Move to Origin (Home)
Yes Yes Yes Yes ??? ??? Yes1 Yes
Parameters
This command can be used without any additional parameters.
Examples
G28     ; Home all axes
G28 X Z ; Home the X and Z axes
When the firmware receives this command, it quickly moves the specified axes (or all axes if none are given) to the endstops, backs away from each endstop by a short distance, and slowly bumps the endstop again to increase positional accuracy. This process, known as "Homing", is required to determine the position of the print carriage(s). Some firmware may even forbid movement away from endstops and other operations until the axes have been homed.
The X, Y, and Z parameters act only as flags. Any coordinates given are ignored. For example, G28 Z10 results in the same behavior as G28 Z. Delta printers cannot home individual axes, but must always home all three towers, so the X Y Z parameters are simply ignored on these machines.
Marlin firmware (version 1.1.0 and up) provides an option called Z_SAFE_HOMING for printers that use a Z probe to home Z instead of an endstop. With this option, the XY axes are homed first, then the carriage moves to a position –usually the middle of the bed– where it can safely probe downward to home Z.
RepRapFirmware uses macro files to home either all axes or individual axes. If all axes are homed, the file homeall.g is processed. For individual axes the homex.g, homey.g, or homez.g file will be used. On Delta printers, G28 command will always home all three towers by processing the homedelta.g file, regardless of any X Y Z parameters.
Because the behavior of G28 is unspecified, it is recommended not to automatically include G28 in your ending GCode. On a Cartesian this will result in damaging the printed object. If you need to move the carriage at the completion of a print, use G0 or G1.
Notes
1 MK4duo has a B parameter that tells the printer to return to the coordinates it was at before homing.
G29: Detailed Z-Probe
Yes Yes, 1.17 and later Yes: 0.91.7 No, see G32 ??? ??? Yes ???
??? No No No Yes Yes No ???
This command uses a probe to measure the bed height at 3 or more points to determine its tilt and overall flatness. It then enables compensation so that the nozzle will remain parallel to the bed. The printer must be homed with G28 before using this command.
Each firmware behaves differently and depends on the type of bed leveling that's been configured. For example, Marlin 1.0.2 provides 3 different types of automatic bed leveling (probe required) and a manual bed leveling option. See your firmware's documentation for the specific options available.
Usage
G29
G29 Snnn
Parameters
Snnn Firmware-dependent behavior
Pfile.csv Optional file name for bed height map file (RepRapFirmware only)
Examples
G29    ; Probe the bed and enable compensation
G29 S2 ; Special operation - see below
G29 P1 ; UBL automated probe - see below
G29 Auto Bed Leveling (Marlin)
Marlin 1.0.2 and earlier provides three options for automatic bed leveling:
  • The 3-point method probes the bed at three points to produce a matrix, adjusting for a flat but tilted bed.
  • The planar grid method (non-Delta) probes a grid pattern to produce a matrix by the "least-squares" method, adjusting for a flat but tilted bed.
  • The bilinear grid method (Delta only) probes a grid pattern to produce a mesh, using bilinear interpolation to adjust for an uneven bed.
Marlin 1.1.0 and up allows the bilinear grid (i.e., "mesh") method to be used on all types of machines, not just deltas. This is the recommended leveling method going forward.
Also in Marlin 1.1.0 and up, the PROBE_MANUALLY option allows all forms of Auto Bed Leveling to be used without a probe. The procedure is similar to that of MESH_BED_LEVELING (see below). Begin the process with G29 to move the nozzle to the first point. Adjust the Z axis using G1 or your host software. Send G29 again to move to the next point and repeat until all points have been sampled.
Parameters
P Set the size of the grid that will be probed (P x P points). Not supported by non-linear delta printer bed leveling. Example: G29 P4
S Set the XY travel speed between probe points (in units/min)
D Dry-Run mode. Just evaluate the bed Topology - Don't apply or clean the rotation Matrix. Useful to check the topology after a first run of G29.
V Set the verbose level (0-4). Example: G29 V3
T Generate a Bed Topology Report. Example: G29 P5 T for a detailed report. This is useful for manual bed leveling and finding flaws in the bed (to assist with part placement). Not supported by non-linear delta printer bed leveling.
F Set the Front limit of the probing grid
B Set the Back limit of the probing grid
L Set the Left limit of the probing grid
R Set the Right limit of the probing grid
Global Parameters
E By default G29 will engage the Z probe, test the bed, then disengage. Include E or E1 to engage/disengage the Z probe for each sample. (This has no effect for fixed probes.)
G29 Unified Bed Leveling (Marlin)
Marlin firmware (version 1.1.0 and up) includes the AUTO_BED_LEVELING_UBL option for Unified Bed Leveling. UBL combines mesh leveling, tilted plane adjustment, 3-point leveling, and manual editing tools all together in a single package. To accomplish so much, UBL overloads `G29` with several new parameters and provides an additional G26 Mesh Tuning feature.
See the MarlinFW website for a dedicated Unified Bed Leveling page and complete documentation on `G29` for UBL and `G26` Mesh Validation.
G29 UBL Parameters (synopsis)
A     Activate   Activate the Unified Bed Leveling system. (i.e., M420 S1)
D     Disable    Disable the Unified Bed Leveling system. (i.e., M420 S0)
B#    Business   Do Manual Probing in 'Business Card' mode.
H#    Height     Height to raise the nozzle after each Manual Probe of the bed.
C     Continue   Continue, Constant, or Current Location, depending on Phase.
E     Every      Stow the probe after every sampled point.
F#    Fade       Fade leveling compensation gradually, until it ceases at the given height.
I#    Invalidate Invalidate a specified number of Mesh Points (X and Y).
J#    Grid       Do a grid (planar) leveling of the current Mesh using a grid with n points on a side.
K#    Kompare    Compare (diff) current Mesh with stored Mesh #, replacing current Mesh with the result.
L     Load       Load Mesh from the previously activated location in the EEPROM.
L#    Load       Load Mesh from the specified location in the EEPROM.
S     Store      Store the current Mesh in the Activated area of the EEPROM. Also save all settings.
S #   Store      Store the current Mesh at the specified area in EEPROM, set as the Activated area.
S -1  Store      Store the current Mesh as a print-out suitable to be fed back into the system.
O     Map        Display the Mesh Map Topology.
P0    Phase 0    Zero Mesh Data and turn off the Mesh Compensation System.
P1    Phase 1    Invalidate the Mesh and do Automatic Probing to generate new Mesh data.
P2    Phase 2    Probe unpopulated areas of the Mesh (those that couldn't be auto-probed).
P3    Phase 3    Fill unpopulated Mesh points with a fixed value. No 'C' for "smart fill" extrapolation.
P4    Phase 4    Fine tune the Mesh. ** Delta Mesh Compensation requires an LCD panel. **
P5    Phase 5    Find Mean Mesh Height and Standard Deviation.
P6    Phase 6    Shift Mesh height. All Mesh points are adjusted by the amount specified with 'C'.
Q     Test       Load specified Test Pattern to help check system operation.
R #   Repeat     Repeat the command the specified number of times. Default: grid points X * Y.
T     3-Point    Perform a 3-Point Bed Leveling on the current Mesh.
U     Unlevel    Perform a probe of the outer perimeter to assist in physically leveling the bed.
W     What?      Print a report of Unified Bed Leveling stored data.
X #              The X location for the command
Y #              The Y location for the command
Z     Zero       Do a single probe to set the Z Height of the nozzle.
Z #   Zero       Raise/lower the entire Mesh to conform with the specified difference (plus zprobe_zoffset).
G29 Manual Bed Leveling (Marlin)
Marlin firmware (version 1.0.2 and up) also provides a MESH_BED_LEVELING feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
Manual Bed Leveling Usage
G29 S1 ; Move to the first point and wait for a measurement
G29 S2 ; Store the current Z, move to the next point
G29 S3 Xn Yn Zn.nn ; Modify the Z height of a single point
Options for the S parameter
S0 Produces a mesh report
S1 Start probing mesh points
S2 Probe the next mesh point
S3 Xn Yn Zn.nn Manually modify a single point
S4 Zn.nn Set z offset. Positive away from bed, negative closer to bed.
G29 Auto Bed Leveling (Repetier-Firmware)
Repetier firmware since v0.91 supports G29 with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32 instead with firmware 0.92.8 and above.
S0 Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuing G29.
S1 Same as S0, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 Z to home to Z maximum position before issuing G29 Snnn for this to work correctly, or the printer height will be invalid.
S2 Same as S1, except new calculated Z height is also stored to EEPROM.
G29 Auto Bed Leveling (RepRapFirmware)
RepRapFirmware:
S0 (default if no S parameter) Probe the bed, save the height map in a file on the SD card, and activate bed compensation. The default folder for the height map file is /sys and the default file name is heightmap.csv.
S1 Load the height map from file and activate bed compensation. The default folder and filename as for S0.
S2 Clear bed height map
To define the grid, see M557.
G29.1: Set Z probe head offset
Example
G29.1 X30 Y20 Z0.5
G29.2: Set Z probe head offset calculated from toolhead position
Example
G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
Yes Yes Yes Yes ??? ??? Yes1 ???
??? No No No Yes Yes use G28 & G92 ???
Usage
Parameters
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Hnnn Height correction
Snnn Set parameter
Example
G30
Examples (RepRapFirmware)
G30                          ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
G30 S-1                      ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate.
G30 P0 X20 Y50 Z-99999       ; Probe the bed at X20 Y50 and save the XY coordinates and the height error as point 0
G30 P3 X180 Y180 Z-99999 S4  ; Probe the bed at X180 Y180, save the XY coordinates and the height error as point 3 and calculate 4-point compensation or calibration
G30 P3 X180 Y180 Z-99999 S-1 ; As previous example but just report the height errors
RepRapFirmware supports additional behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane or for performing delta printer calibration. If X, Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specifies that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. In version 1.09, the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
RepRapFirmware supports an optional H parameter, which is a height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z parameter of the G31 command in the config.g file. When you probe using G30 and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H parameter.
1MK4duo Firmware support an optional parameter for Autocalibration Delta.
Usage
G30 Xnnn Ynnn Znnn Annn E R I D T S U
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Annn A Autocalibration width nnn precision
E Adjust Endstop
R Adjust Endstop & Delta Radius
I Adjust Tower
D Adjust Diagonal Rod
T Adjust Tower Radius
Sn Stows the probe if 1 (default=1)
Un <bool> with a non-zero value will apply the result to current zprobe_zoffset
G31: Set or Report Current Probe status
No Yes Yes: 0.91.7 Yes ??? ??? No ???
Usage
Parameters
Pnnn Trigger value
Xnnn Probe X offset1
Ynnn Probe Y offset1
Znnn Trigger Z height
Cnnn Temperature coefficient2
Snnn Calibration temperature2
Tnnn (RepRapFirmware 1.17 and later) Z probe type to which these parameters apply, defaults to the current Z probe type as defined by M558 P parameter
Examples
G31 P500 Z2.6
G31 X16.0 Y1.5
In RepRapFirmware, separate G31 parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command, or use the T parameter.
In Repetier, G31 supports no parameters and simply prints the high/low status of the Z probe.
Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature. This facility is deprecated and likely to be removed in a future version of RepRapFirmware.
G31: Dock Z Probe sled
Yes No ??? No ??? ??? Yes ???
??? No No No No Yes No ???
No: See G29 Yes Yes: 0.92.8 Yes ??? ??? No ???
Usage
G32           ; Probe and calculate
G32 Snnn      ; Each firmware has its own parameters
G32 Snnn Pnnn ; Refer to their specific documentation
This command is implemented as a more sophisticated form of bed leveling (which uses a transformation matrix or motorized correction. Smoothieware uses this code instead of `G29`.
Each firmware behaves differently. For example, Repetier firmware allows for motorized rotation of the bed whilst ReprapFirmware probes the bed with a transformation matrix.
Probe and calculate in Reprapfirmware
This command probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
Parameters
Snnn Store transformation matrix after probing1
Examples
G32
G32 S2
RepRapFirmware executes macro file bed.g if present instead of using the M557 coordinates.
Notes
1Currently only Repetier firmware v0.92.8 and higher have working support for an optional Snnn parameter. The numeric value sets the behavior that occurs immediately after point probe and transformation matrix calculation. These are the values for Reprapfirmware:
S0 Default value. Transformation matrix is updated in RAM but is not stored to EEPROM. Z bed height not calculated.
S1 Transformation matrix is updated in RAM but is not stored to EEPROM. Printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 to home to Z maximum position before issuing G32 Snnn for this to work correctly, or the printer height will be invalid.
S2 Same as S1, except transformation matrix and Z max heights are also stored to EEPROM.
S3 Transformation matrix is stored to EEPROM. Z bed height not calculated.
Probe and calculate in Repetier firmware
This command probes the bed at 3 or more pre-defined points and implements bed leveling compensation by either moving the A axis during printing (as with regular bed leveling, G29) or by tilting the bed with motors.
Parameters
Snnn Bed leveling method
Pnnn Bed correction method
The values for Snnn and Pnnn are as follows:
S0 This method measures at the 3 probe points and creates a plane through these points. If you have a really planar bed this gives the optimum result. The 3 points must not be in one line and have a long distance to increase numerical stability.
S1 This measures a grid. Probe point 1 is the origin and points 2 and 3 span a grid. We measure BED_LEVELING_GRID_SIZE points in each direction and compute a regression plane through all points. This gives a good overall plane if you have small bumps measuring inaccuracies.
S2 Bending correcting 4 point measurement. This is for cantilevered beds that have the rotation axis not at the side but inside the bed. Here we can assume no bending on the axis and a symmetric bending to both sides of the axis. So probe points 2 and 3 build the symmetric axis and point 1 is mirrored to 1m across the axis. Using the symmetry we then remove the bending from 1 and use that as plane.
P0 Use a rotation matrix. This will make z axis go up/down while moving in x/y direction to compensate the tilt. For multiple extruders make sure the height match the tilt of the bed or one will scratch. This is the default.
P1 Motorized correction. This method needs a bed that is fixed on 3 points from which 2 have a motor to change the height. The positions are defined in firmware by BED_MOTOR_1_X, BED_MOTOR_1_Y, BED_MOTOR_2_X, BED_MOTOR_2_Y, BED_MOTOR_3_X, BED_MOTOR_3_Y Motor 2 and 3 are the one driven by motor driver 0 and 1. These can be extra motors like Felix Pro 1 uses them or a system with 3 z axis where motors can be controlled individually like the Sparkcube does. This method requires a Z max endstop.
G32: Undock Z Probe sled
G33: Firmware dependent
G33: Measure/List/Adjust Distortion Matrix (Repetier - Redeem)
No No Yes: v0.92.8 No ??? ??? No ???
Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
Parameters
L0 List distortion matrix in a report
R0 Reset distortion matrix
X[pos] Y[pos] Z[zCorrection] Set correction for nearest point
Examples
G33
G33 R0
When used with no parameters, G33 will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28 homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323.
G33: Delta Auto Calibration (Marlin 1.1.x)
Yes No No No ??? ??? No No
Performs a 1-4-7 point calibration of delta height (P1), endstops, delta radius (P2) and tower angle corrections (P>=3) by an iteration process based on the least squares method.
Usage
G33
G33 Pn T Cx.xx Fn Vn E
Parameters
Pn Number of probe points: n*n (n=1-7), when P is omitted the default set in Configuration.h is used
T Do not calibrate tower angle corrections (if used with P>=3); do not use the probe points near the towers, but the probe points opposite to the towers (if used with P=2); when T is omitted it defaults to T1
Cx.xx Force the iterations to stop when a standard deviation from the zero plane less then x.xx mm is achieved; when C is omitted the iterations go on until the best possible standard deviation is reached.
Fn Force to run at least n iterations (n=1-30) and take the best result
Vn Verbose level: (n=0-2) 0 = dry run without calibration; 1(default) = settings ; 2 = settings and probe results
E Engage the probe for each point, when E is omitted it defaults to E0
Examples
G33 : calibrates with the default settings.
G33 Auto Calibrate
Checking... AC
.Height:297.77    Ex:+0.00  Ey:+0.00  Ez:+0.00    Radius:100.00
.Tower angle :    Tx:+0.00  Ty:+0.00  Tz:+0.00
Iteration : 01                                    std dev:0.306
.Height:297.65    Ex:-0.15  Ey:-0.14  Ez:+0.00    Radius:100.77
.Tower angle :    Tx:-0.02  Ty:+0.11  Tz:+0.00
Iteration : 02                                    std dev:0.049
.Height:297.67    Ex:-0.12  Ey:-0.12  Ez:+0.00    Radius:100.87
.Tower angle :    Tx:-0.03  Ty:+0.20  Tz:+0.00
Iteration : 03                                    std dev:0.033
.Height:297.69    Ex:-0.10  Ey:-0.12  Ez:+0.00    Radius:100.91
.Tower angle :    Tx:-0.03  Ty:+0.25  Tz:+0.00
Iteration : 04                                    std dev:0.031
.Height:297.69    Ex:-0.07  Ey:-0.11  Ez:+0.00    Radius:100.92
.Tower angle :    Tx:-0.03  Ty:+0.30  Tz:+0.00
Calibration OK                                    rolling back.
Save with M500 and/or copy to Configuration.h
G33 P6 V0 : probes 36 points in dry run mode.
G33 Auto Calibrate
Checking... AC (DRY-RUN)
.      c:+0.03     x:+0.32   y:+0.34   z:+0.41
.                 yz:+0.37  zx:+0.32  xy:+0.17
End DRY-RUN                                       std dev:0.306
G33 P4 C0.05 T : probes 16 points and
                 stops when a standard deviation of 0.05mm is reached;
                 calibrates delta height, endstops and delta radius,
                 leaves the tower angle corrections unaltered.
G33 Auto Calibrate
Checking... AC
.Height:297.78    Ex:+0.00  Ey:+0.00  Ez:+0.00    Radius:100.00
Iteration : 01                                    std dev:0.317
.Height:297.65    Ex:-0.15  Ey:-0.16  Ez:+0.00    Radius:100.80
Iteration : 02                                    std dev:0.059
.Height:297.66    Ex:-0.17  Ey:-0.13  Ez:+0.00    Radius:100.91
Calibration OK                                    std dev:0.042
G33 P2 : probes center and tower positions and
         calibrates delta height, endstops and delta radius.
G33 Auto Calibrate
Checking... AC
Iteration : 01                                    std dev:0.374
.Height:297.68    Ex:-0.14  Ey:-0.15  Ez:+0.00    Radius:101.09
Iteration : 02                                    std dev:0.054
.Height:297.68    Ex:-0.14  Ey:-0.14  Ez:+0.00    Radius:101.23
Iteration : 03                                    std dev:0.007
.Height:297.69    Ex:-0.13  Ey:-0.14  Ez:+0.00    Radius:100.92
G33 P1 : probes the center and sets the delta height only.
G33 Auto Calibrate
Checking... AC
.Height:295.00
Calibration OK
.Height:297.78
note: Height = delta height; Ex, Ey, Ez = end-stop corrections; Radius = delta radius; Tx, Ty, Tz = tower angular corrections; c, x, y, z, yz, zx, xy = probe results at center, towers and opposite to towers; std dev = standard deviation of the probe results towards the zero plane.
Yes: 1.1.0 No ??? Yes ??? ??? No ???
Yes ??? ??? ??? ??? No ??? ???
??? No ??? ??? ??? ??? No ???
No No ??? No ??? ??? No ???
G40 turns off cutter compensation. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
G42: Move to Grid Point
Yes: 1.1.2 No No No ??? ??? No No
G42 does a fast move in XY to any of the intersection points in the bed calibration grid. This is useful during calibration to align the nozzle or probe.
Parameters
Inn Grid X index (zero-based). If omitted, the nearest latitude.
Jnn Grid Y index (zero-based). If omitted, the nearest longitude.
P Probe flag. Moves the probe to the grid point (instead of the nozzle).
Fnnn Feedrate (mm/m)
Example
G42 I3 J4 P F3000 ; Move the probe to grid coordinate 3, 4
G54..59: Coordinate System Select (CNC specific)
No No ??? Yes ??? ??? No ???
G60: save current position to slot
??? ??? ??? ??? ??? ??? Yes ???
Usage
G60 Snn
Parameters
Snn <nn> specifies memory slot # (0-based) to save into (default 0)
G61: Apply/restore saved coordinates to the active extruder.
Usage
G61 Xnnn Ynnn Znnn Ennn Fnnn Snn
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Ennn E coordinate
Fnnn F Set Feedrate
Snn S specifies memory slot # (0-based)
Example
G90
Yes Yes No Yes Yes Yes Yes ???
Example
G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83 to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91 command, as well as setting X, Y and Z.
G92: Set Position
Parameters
Xnnn new X axis position
Ynnn new Y axis position
Znnn new Z axis position
Ennn new extruder position
Example
G92 X10 E90
G92.x: Reset Coordinate System Offsets (CNC specific)
??? No ??? Yes ??? ??? No ???
  • G92.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
  • G92.2 - reset axis offsets to zero.
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1, G2, or G3 motion, and an F word on a line that does not have G1, G2, or G3 is ignored. Being in inverse time feed rate mode does not affect G0 (rapid move) motions.
No No Yes: 0.92 No ??? ??? No ???
Parameters
X Flag to set floor for X axis
Y Flag to set floor for Y axis
Z Flag to set floor for Z axis
Rnnn Radius to add
Examples
G100 X Y Z ; set floor for argument passed in. Number ignored and may be absent.
G100 R5    ; Add 5 to radius. Adjust to be above floor if necessary
G100 R0    ; Set radius based on current z measurement. Moves all axes to zero
No No No No ??? ??? No Yes
Example
G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No No Yes: 0.91 No ??? ??? No ???
G133: Measure steps to top
G161: Home axes to minimum
??? No No No No No Yes ???
Parameters
Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28, which decides on its own in which direction to search endstops.
G162: Home axes to maximum
Parameters
Example
G162 X Y Z F1800
M-commands
Yes Yes No No ??? ??? Yes ???
Yes No No Yes Yes No Yes ???
Parameters
Pnnn Time to wait, in milliseconds1
Snnn Time to wait, in seconds2
Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1, M112.
RepRapFirmware executes macro file stop.g before everything is turned off. Apart from that, RepRapFirmware (v1.09n-ch) accepts an extra 'H' parameter, whose value must be non-zero, to keep all heaters active. This is what Duet Web Control v1.07 sends to cancel a paused print.
Notes
1Not available in RepRapFirmware, but as a work-around G4 can be run before M0.
2Only available on Marlin.
M1: Sleep or Conditional stop
Yes No No No No No ??? ???
Example
M1
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g is run before all heaters and drives are turned off.
M2: Program End
No No No ??? ??? ??? No Yes
Yes No No No No No Yes ???
Example
M2
No Yes Yes Yes ??? ??? No ???
Parameters
Snnn Spindle RPM
Example
M3 S4000
RepRapFirmware interprets this code only if a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0..S255 to set laser intensity. Normally you use S255 to turn it on full power for moves. Laser will only fire during G1/G2/G3 moves and in laser mode (M452).
No No Yes No ??? ??? No ???
Yes No No No No No No ???
Example
M4 S4000
No No Yes Yes ??? ??? No ???
Example
M5
The spindle is turned off.
M6: Tool change
No No No ??? ??? ??? No ???
Example
M6
Yes No No No No No use M106 ???
Example
M7
Example
M8
Example
M9
M10: Vacuum On (CNC specific)
??? No No No No No use M106 ???
Example
M10
Example
M11
Yes No No Yes ??? ??? Yes ???
??? No No No No Yes (automatic) ???
Example
M17
call M84 Yes No Yes ??? ??? call M84 Yes
??? No No No No Yes use M2 ???
Parameters
This command can be used without any additional parameters.1
X X axis
Y Y axis
Z Z axis
E Extruder drive(s)2
Examples
M18
M18 X E0
Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? Yes No No No No Yes ???
Parameters
Snnn Output style1
Pnnn Directory to list2
Examples
M20
M20 S2 P/gcodes/subdir
ok
SQUARE.G
SQCOM.G
ZCARRI~2.GCO
CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list:
SQUARE.G
ZCARRI~2.GCO
End file list
ok
GCode files:
"Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23 command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. RepRapFirmware always returns long filenames in the case in which they are stored.
Notes
1If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir".
Example
M20 S2 P/gcodes
{"dir":"\/gcodes","files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"]}
2This parameter is only supported by RepRapFirmware and defaults to the 0:/gcodes directory, which is the directory that printable gcode files are normally stored in.
M21: Initialize SD card
Parameters
Pnnn SD card number (RepRapFirmware only, default 0)
Examples
M21
M21 P1
The specified SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Yes Yes Yes No ??? ??? Yes ???
Parameters
Examples
M22
M22 P1
The specified SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
Example
M23 filename.gco
M24: Start/resume SD print
??? Yes No No No Yes Yes ???
Example
M24
The machine prints from the file selected with the M23 command. If the print was previously paused with M25, printing is resumed from that point. To restart a file from the beginning, use M23 to reset it, then M24.
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g prior to resuming the print.
M25: Pause SD print
Example
M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g. This allows the head to be moved away from the print, filament to be retracted, etc.
M26: Set SD position
Yes Yes Yes aborts ??? ??? Yes ???
??? Yes No No No No No ???
Parameters
Snnn File position in bytes
Example
M26
M27: Report SD print status
Example
M27
Report SD print status.
Marlin and recent forks of RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
M28: Begin write to SD card
Example
M28 filename.gco
M29: Stop writing to SD card
Example
M29 filename.gco
Yes Yes No No No No No ???
Example
> M30 filename.gco
> filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
Yes No No No ??? ??? Yes ???
Example
M31
The response looks like:
 echo:54 min, 38 sec
Yes Yes No Yes ??? ??? No ???
Example
M32 filename.gco
It can be used when printing from SD card and does the same as M23 and M24.
Yes No No No ??? ??? No ???
M33: Stop and Close File and save restart.gcode
Stop the printing from SD and save all position in restart.gcode for restart printing in future
M35: Upload firmware NEXTION from SD
M36: Return file information
No Yes No No ??? ??? No No
Example
M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
M38 Compute SHA1 hash of target file
Used to compute a hash of a file on the SD card. Examples:
> M38 gcodes/myfile.g
> Cannot find file
> M38 www/reprap.htm
> 91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M40: Eject
See also M240 and M241 below.
M41: Loop
Support Marlin RepRapFirmware Repetier Smoothie Klipper Prusa MK4duo MakerBot
Example
M41
M42: Switch I/O pin
Yes Yes Yes No ??? ??? Yes No
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa
Parameters
Pnnn Pin number
Snnn Pin value
Example
M42 P7 S255
In RepRapFirmware, the S field may be in the range 0..1 or 0..255. The pin reference is an internal firmware reference named "digital pin", see Duet pinout. It maps on different connector pins depending the hardware. On Duet 0.6 and 0.8.5 hardware using pre-1.16 firmware, the supported pin numbers and their names on the expansion connector are:
Duet M42 P value to Expansion Port Pin Mapping
P Name Expansion Port Pin
16 TXD1 11
17 RXD1 12
18 TXD0 13
19 RXD0 14
20 TWD1 35
21 TWCK1 36
23 PA14 10
36 PC4 18
52 AD14 41
67 PB16 32
In firmware 1.16, the pin numbering has changed.
Duet 0.6 and 0.8.5 v1.16+ M42 P value to Expansion Port Pin Mapping
60 PA10/RXD0 14
61 PA11/TXD0 13
62 PA12/RXD1 12
63 PA13/TXD1 11
64 PA14/RTS1 10
65 PB12/TWD1 35
66 PB13/TWCK1 36
67 PB16/DAC1* 32
68 PB21/AD14 41
69 PC4 18
  • Also used as CS signal on external SD card socket
Duet WiFi v1.16+ M42 P value to Expansion Port Pin Mapping
P Signal Name Expansion Connector Label Expansion Pin
60 CS5 CS5 50
61 CS6 E3_STOP 9
62 CS7 E4_STOP 14
63 CS8 E5_STOP 19
See Using servos and controlling unused I/O pins for all pin definitions.
Pre-1.16 example:
M42 P20 S1 ;set the connector pin 35 to high.
See also M583.
Example
M43
M43: Pin report and debug
Usage
M43 En Pnnn Wn In
Parameters
En Enable / disable background endstop monitoring
Pnnn Pin to read or watch. If omitted, read/watch all pins
Wn bool watch pins -reporting changes- until reset, click, or M108
In bool Flag to ignore pin protection
Note
You must have PINS_DEBUGGING uncommented in your Configuration_adv.h file for M43 to work.
Parameters
Pnnn number of points
Xnnn position on the X axis
Ynnn position on the Y axis
Vnnn verbosity
E engage
Lnnn legs of travel
S schizoid
As with G29, the E flag causes the probe to stow after each probe.
The S flag will result is a random sized, 5 pointed star, being traced (X and Y axis) between each sample. Usually a user will get worse repeat-ability numbers with S specified because the X axis and Y axis movements will add to the machine's positioning errors.
M70: Display message
see M117 see M117 see M117 see M117 ??? ??? see M117 Yes
??? No No No No see M117 No ???
Example
M70 P200 Message
Instruct the machine to display a message on its interface LCD. P is the time to display message for.
M72: Play a tone or song
see M300 see M300 No No ??? ??? see M300 Yes
Example
M72 P2
M73: Set build percentage
Example
M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
??? Yes No No No No automatic ???
Examples
M80    ; Turn on the power supply
M80 S  ; Report power supply state (Marlin 1.1.1)
Notes
  • Marlin requires the POWER_SUPPLY configuration option to be set to a non-zero value to enable M80.
  • Some firmwares (e.g., Teacup) handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off.
M81: ATX Power Off
??? Yes No No No Yes automatic ???
Example
M81
For redeem, adding 'P' will quit the daemon (redeem). Adding parameter 'R' will restart the daemon.
Example
M82
Example
M83
M84: Stop idle hold
Parameters
Innn Reset flags1
Example
M84
On Marlin, Repetier and RepRapFirmware, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
M85: Set inactivity shutdown timer
Yes No Yes No ??? ??? Yes ???
Example
M85 S30
M92: Set axis_steps_per_unit
??? Yes No No No Yes No ???
Parameters
Xnnn Steps per unit for the X drive
Ynnn Steps per unit for the Y drive
Znnn Steps per unit for the Z drive
Ennn Steps per unit for the extruder drive(s)
Examples
M92 X87.489 Y87.489 Z87.489
M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500 in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
RepRapFirmware will report the current steps/mm if you send M92 without any parameters.
M93: Send axis_steps_per_unit
No Use M92 ??? No ??? ??? No ???
M98: Call Macro/Subprogram
Parameters
Pnnn Macro filename
Example
M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro, although RepRapFirmware explicitly supports this.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware as well.
Example
M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example
M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Example
M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
No 1.17c and later No No ??? ??? No ???
??? No Yes No No No Yes ???
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan: Turn extruder on (forward/filament in).
in RepRapFirmware: undo filament retraction. The length and speed are set by the M207 command. RepRapFirmware supports this command for compatibility with Simplify3D.
in other firmwares: Deprecated. Regarding filament retraction, see G10, G11, M207, M208, M227, M228, M229.
??? No Yes No No No No ???
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In RepRapFirmware: retract filament. The length and speed are set by the M207 command. RepRapFirmware supports this command for compatibility with Simplify3D.
Yes Yes Yes Yes ??? ??? Yes Yes
??? Yes Yes Yes Yes Yes Yes ???
Parameters
Snnn Target temperature
Example
M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example
M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100°C.
??? Yes No Yes No Yes Yes ???
Parameters
Rnnn Response sequence number1
Snnn Response type1
Examples
M105
M105 S2
ok T:201 B:117
M105 X0
Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2 is equivalent to M408 S0, and M105 S3 is equivalent to M408 S2. Usage of these forms of M105 is deprecated, please use M408 instead.
M106: Fan On
Parameters
Pnnn Fan number (optional, defaults to 0)2
Snnn Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))
Extra Parameters
Innn Invert signal, or disable fan1
Fnnn Set fan PWM frequency, in Hz1
Lnnn Set minimum fan speed (0 to 255 or 0.0 to 1.0)1
Bnnn Blip time - fan will be run at full PWM for this number of seconds when started from standstill1
Hnn:nn:nn... Select heaters monitored when in thermostatic mode1
Rnnn Restore fan speed to the value it has when the print was paused1
Tnnn Set thermostatic mode trigger temperature1
Example
M106 S127
M106 P1 I1 S87
M106 P1 T45 H1:2
M106 P2 B0.1 L0.05
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7.
Notes
2Marlin only supports fan 0, all values above 0 will be interpreted as 0
M106 in RepRapFirmware
If an S parameter is provided but no other parameter is present, then the speeds of the print cooling fans associated with the current tool will be set (see the F parameter in the M563 command). If no tool is active then the speed of Fan 0 will be set. Either way, the speed is remembered so that it can be recalled using the R2 parameter (see below).
If no S parameter is given but the R1 parameter is used, the fan speed when the print was last paused will be set. If the R2 parameter is used, then the speeds of the print cooling fans associated with the current tool will be set to the remembered value (see above).
The T and H parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H parameter is at or above the trigger temperature set by the T parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
The B parameter sets the time for which the fan will be operated at full PWM when started from cold, to allow low fan speeds t be used. A value of 0.1 seconds is usually sufficient.
The L parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
The I parameter causes the fan output signal to be inverted if its value is greater than zero. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero, the output is not inverted. If the I parameter is negative then in RRF 1.16 and later the fan is disabled, which frees up the pin for use as a general purpose I/O pin that can be controlled using M42.
M106 in Teacup Firmware
Example
M106 P2 S255
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104 is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106 initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
??? Yes Yes Yes Yes Yes No ???
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0 instead.
M108: Cancel Heating (Marlin)
Breaks out of an M109 or M190 wait-for-temperature loop, continuing the print job. Use this command with caution! If cold extrusion prevention is enabled (see M302) and the temperature is too low, this will start "printing" without extrusion. If cold extrusion prevention is disabled and the hot-end temperature is too low, the extruder may jam.
This command was introduced in Marlin 1.1.0. As with other emergency commands [e.g., M112] this requires the host to leave space in the command buffer, or the command won't be executed until later.
M108: Set Extruder Speed (BFB)
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? Yes No Yes Yes Yes not needed ???
Parameters
Example
M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), RepRapFirmware
Example
M109 S185
RepRapFirmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example
M109 S185 R240 ; set extruder temperature to 185 and wait for the temperature to be between 185 - 240.
M109 in MakerBot
Example
M109 S70 T0
M110: Set Current Line Number
Yes Yes Yes Yes ??? ??? Yes ???
??? No No Yes No Yes not needed ???
Parameters
Nnnn Line number
Example
M110 N123
M111: Set Debug Level
??? No No Yes No Yes Debug ???
Parameters
Pnnn Debug module1
Snnn Debug on/off
Examples
M111 S6
M111 P1 S1
Notes
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a list of modules, send M111 S1 P15.
M111 in Repetier
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112: Emergency Stop
??? No No Yes No Yes Yes ???
Example
M112
M113: Set Extruder PWM
No No No No ??? ??? No ???
??? No No Yes No No No ???
Example
M113
M113 S0.7
M114: Get Current Position
Example
M114
Parameters
Pnnn Electronics type1
Examples
M115
M115 P2
sample data from firmware:
Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0   Automatic board type selection if supported, or default if not
M115 P1   Duet 0.6
M115 P2   Duet 0.7
M115 P3   Duet 0.85
M116: Wait
No Yes Yes No ??? ??? No Yes
Parameters
Pnnn Tool number
Hnnn Heater number
Cnnn Chamber number
Examples
M116
M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109.
Notes
M117: Get Zero Position
No No No No ??? ??? No see M70
Example
M117
M117: Display Message
Yes Yes Yes Yes ??? ??? Yes No
Example
M117 Hello World
M118: Echo message on host
Yes:1.1.4 No No No ??? ??? No ???
??? No No No No No No ???
Use this code to print a visible message to the host console, preceded by 'echo:'.
Example
M118 Color changing to blue
M118: Negotiate Features
Example
M118 P42
M119: Get Endstop Status
Example
M119
In redeem, M119 can also be used to invert end stops.
Example
M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No Yes No Yes ??? ??? No ???
Example
M120
  1. Current feedrate, and
  1. Current feedrate
  2. Extruder positions
M121: Pop
Example
M121
M122: Diagnose
No Yes No No ??? ??? No ???
Example
M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Yes No No No ??? ??? Yes Yes
Example
M126 P500
M126 in MakerBot
Example
M126 T0
M127: Close Valve
Example
M127 P400
M127 in MakerBot
Example
M127 T0
M128: Extruder Pressure PWM
Example
M128 S255
M129: Extruder pressure off
Example
M129 P100
M130: Set PID P value
see M301 No No see M301 ??? ??? see M301 ???
??? No No No No see M301 Yes ???
Parameters
Pnnn heater number
Snnn proportional (Kp)
Example
M130 P0 S8.0  ; Sets heater 0 P factor to 8.0
M131: Set PID I value
Parameters
Pnnn heater number
Snnn integral (Ki)
Example
M131 P1 S0.5  ; Sets heater 1 I factor to 0.5
M132: Set PID D value
see M301 see M301 No See M301 ??? ??? see M301 Yes
Parameters
Pnnn heater number
Snnn derivative (Kd)
Example
M132 P0 S24  ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example
M132 X Y Z A B
M133: Set PID I limit value
see M301 No No No ??? ??? see M301 Yes
Parameters
Pnnn heater number
Snnn integral limit (Ki)
Example
M133 P1 S264  ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example
M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No see M500 No See M504 ??? ??? No Yes
Example
M134
M134 in MakerBot
Example
M134 T0 P500
M135: Set PID sample interval
No Yes No No ??? ??? No Yes
Parameters
Snnn Heat sample time in seconds
Example
M135 S300
M135 in MakerBot
Example
M135 T0
No see M301 No No ??? ??? No ???
??? No No No No No Debug ???
Example
M136 P1  ; print heater 0 PID parameters to host
??? Yes No Yes Yes Yes Yes ???
Parameters
Hnnn Heater number1
Example
M140 S55
RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected1:
M140 S-273.15
No Yes No No ??? ??? Yes ???
??? No No No Yes No uses M104 ???
Parameters
Hnnn Heater number1
Examples
M141 S30
M141 H0
Notes
M142: Holding Pressure
Example
M142 S1
M143: Maximum heater temperature
Parameters
H Heater number (RepRapFirmware 1.17 and later, default 1 which is normally the first hot end)
S Maximum temperature
Examples
M143 S275      ; set the maximum temperature of the hot-end to 275°C
M143 H0 S125   ; set the maximum bed temperature to 125C
The default maximum temperature for all heaters was 300°C prior to RepRapFirmware version 1.13, and 262°C from 1.13 onwards. From RepRapFirmware 1.17 onwards, the default maximum temperatures are 262C for extruders and 125C for the bed.
When the temperature of the heater exceeds this value, countermeasures will be taken.
M144: Bed Standby
Example
M144
M146: Set Chamber Humidity
Parameters
Example
M146 R60
M149: Set temperature units
Parameters
Example
M149 K
M150: Set display color
Parameters
Rnnn red
Unnn green
Bnnn blue
Example
M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
M155: Automatically send temperatures
Yes: 1.1.0 No Yes No ??? ??? Yes ???
Parameters
Snnn enable sending temperatures = 1, disable = 0
Example
M155 S1
Hosts normally monitor printer temperatures by sending M105 every x seconds. This not only adds traffic, but also only works while printer is not blocked by waiting commands. So frequency more depends on frequency you can send new commands and creates extra traffic. As a solution, firmware can be told to automatically send temperatures every second. This function is disabled by default for best compatibility with existing hosts. To indicate the availability of this function, M115 will add an extra line:
Cap:AUTOREPORT_TEMP:1
so hosts know about the presence of the function.
Example
M160 S4
M160 S4
G1 X70.6 E0:0:0:42.4
G1 E42.4:0:0:0
Yes: RC7 Use M567 Yes: 0.92 No ??? ??? No ???
Parameters
Snnn extruder number
Pnnn weight
See Repetier Color Mixing for more informations.
M164: Store weights
Yes: RC7 No Yes: 0.92 No ??? ??? No ???
Parameters
Snnn virtual extruder number
M165: Set multiple mix weights
Yes: RC7 No No: No ??? ??? No ???
Parameters A B C D H I
A[factor] Mix factor for extruder stepper 1
B[factor] Mix factor for extruder stepper 2
C[factor] Mix factor for extruder stepper 3
D[factor] Mix factor for extruder stepper 4
H[factor] Mix factor for extruder stepper 5
I[factor] Mix factor for extruder stepper 6
  • Set multiple mix factors for a mixing extruder.
  • Factors that are left out will be set to 0.
  • All factors together must add up to 1.0.
??? Yes No No Yes Yes See M116 ???
Parameters
Example
M190 S60
No 1.17 and later No No ??? ??? Yes ???
??? No No No Yes No No ???
Example
M191 P60
In MK4duo:
Parameters
Example
M191 S60
M200: Set filament diameter
Yes 1.19 and later Yes Yes ??? ??? Yes ???
RepRapFirmware:
Parameters
Daaa:bbb:ccc... Sets filament diameter to aaa for extruder 0, bbb for extruder 1 and so on. If any of aaa, bbb etc. are zero then volumetric extrusion is disabled for that extruder.
Daaa Sets filament diameter (or disables volumetric extrusion) for all extruders
Examples
M200 D0  ; disable volumetric extrusion on all extruders
M200 D1.75  ; set al extruder filament diameters to 1.75mm
M200 D1.75:3.0:1.75  ; set extruder 0 to 1.75mm, extruder 1 to 3.0mm and all remaining extruders to 1.75mm
Volumetric extrusion is an option you can set in some slicers whereby all extrusion amounts are specified in mm3 (cubic millimetres) of filament instead of mm of filament. This makes the gcode independent of the filament diameter, potentially allowing the same gcode to run on different printers. The purpose of the M200 command is to inform the firmware that the gcode input files have been sliced for volumetric extrusion, and to provide the filament diameter so that the firmware can adjust the requested extrusion amount accordingly.
Sending M200 without parameters reports the current volumetric extrusion state and (where appropriate) filament diameter for each extruder.
Note that if you use slicer-commanded retraction, the retraction amounts must be specified in mm3 too. If instead you use firmware retraction, then the firmware retraction amounts specified using the M207 command are still interpreted as mm.
Other firmwares:
M200 D0 or M200 D1.128 ; reset E multiplier to 1, since sqrt(1 / pi) * 2 = 1.128
Parameters
Xnnn Acceleration for X axis
Ynnn Acceleration for Y axis
Znnn Acceleration for Z axis
Ennn Acceleration for extruder drives
Example
M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
??? ??? No No No ??? No ???
Set max travel acceleration in units/s^2 for travel moves (M202 X1000 Y1000). Unused in Marlin!!
M203: Set maximum feedrate
Parameters
Xnnn Maximum feedrate for X axis
Ynnn Maximum feedrate for Y axis
Znnn Maximum feedrate for Z axis
Ennn Maximum feedrate for extruder drives
Example
M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203 Repetier
Set temperature monitor to Sx.
Yes 1.18 and later Yes Yes ??? ??? Yes ???
??? Yes No No No ??? No ???
Parameters (RepRapFimware)
Pnnn Acceleration for printing moves
Tnnn Acceleration for travel moves
Example
M204 P500 T2000
Use M201 to set per-axis accelerations and extruder accelerations. RepRapFirmware applies the M204 accelerations to the move as a whole, and also applies the limits set by M201 to each axis and extruder.
Other firmwares:
P = Printing moves
The command M204 P800 T3000 R9000 sets the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
Usage
M204 X[Kp] Y[Ki] Z[Kd]
M205: Advanced settings
Yes Use M566 Yes Yes ??? ??? Yes ???
Sprinter / Marlin
Minimum travel speed = S[printing] T[travel]
B[min segment time] X[max XY jerk] Z[max Z jerk] E[max E jerk]
Sprinter / Marlin Example
M205 X30 Z5 ; Set X/Y Jerk to 30mm/s, Z jerk to 5mm/s
Smoothieware uses a different algorithm: [1]
X[xy junction deviation] Z[z junction deviation] S[minimum planner speed].
Z junction deviation only applies to z only moves
0 disables junction deviation for Z
-1 uses global junction deviation
Smoothie example
M205 X0.05  ; set X/Y Junction Deviation
M205 Repetier
Output EEPROM settings.
M206: Offset axes
Yes Yes No Yes ??? ??? Yes ???
Parameters
Xnnn X axis offset
Ynnn Y axis offset
Znnn Z axis offset
Example
M206 X10.0 Y10.0 Z-0.4
M206 in Repetier: Set eeprom value
Example
M206 T3 P39 X19.9
Set Jerk to 19.9
Example
M207
M207: Set retract length
Parameters
Rnnn positive or negative additional length to un-retract, in mm (RepRapFirmware only)
Fnnn retraction feedrate, in mm/min
Tnnn feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)
Znnn additional zlift/hop
Example
M207 S4.0 F2400 Z0.075
Sets the retract length used by the G10 and G11 commands, stays in mm regardless of M200 setting
M208: Set axis max travel
Parameters
Snnn Whether to set the axis minimum1
Xnnn X axis limit
Ynnn Y axis limit
Znnn Z axis limit
Example
M208 X250 Y210 Z180
RepRapPro's version of Marlin uses M208 this way. Send M503 to see the current values. On Marlin, the value can be saved to EEPROM using the M500 command.
Notes
1With RepRapFirmware on a Cartesian printer, you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208 X200 Y200 Z90; set axis maxima
M208 X-5 Y0 Z0 S1 ; set axis minimum
M208: Set unretract length
Yes See M207 No Yes ??? ??? Yes ???
Parameters
Fnnn feedrate, in mm/sec
Yes No Yes No ??? ??? Yes No
Example
M209 S1
This boolean value S 1=true or 0=false enables automatic retract detect if the slicer did not support G10/G11: every normal extrude-only move will be classified as retract depending on the direction.
M210: Set homing feedrates
Example
M210 X1000 Y1500
No Use M564 No No ??? ??? No ???
Example
M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example
M211 X0 S1
Enables X min endstop
Example
M211
Yes* Use G31 No No ??? ??? Yes ???
Example
M212 Z-0.2
M218: Set Hotend Offset
Yes Use G10 No No ??? ??? Yes ???
Example
M218 T1 X50 Y0.5
Parameters
Snnn Speed factor override percentage (0..100 or higher)
Example
M220 S80
Parameters
Snnn Extrude factor override percentage (0..100 or higher), default 100%
Dnnn Extruder drive number (RepRapFirmware only), default 0
Example
M221 S70
M221 S95 D1
Sets extrude factor override percentage. In the case of RepRapFirmware, sets the extrusion factor percentage for the specified extruder drive only.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? No Yes No Yes No No ???
Example
M226
M226: Wait for pin state
Yes see M577 Yes No ??? ??? Yes ???
Parameters
Pnnn pin number
Snnn pin state
Example
M226 P2 S1
Example
M227 P1600 S1600
P and S are steps.
Example
M228
See also M227.
Example
M229 P1.0 S1.0
Example
M230 S1
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[RetractMove]
M240: Trigger camera
Example
M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? No No No No No Debug: Echo off ???
Example
M240
Echoing may be controlled in some firmwares with M111.
??? No No No No No Debug: Echo on ???
Example
M241
M245: Start cooler
Example
M245
M246: Stop cooler
Example
M246
M250: Set LCD contrast
Yes No No No ??? ??? Yes No
Example
M250 C20
Examples
M251 S0 ; Reset
M251 S1 ; Print
M251 S2 ; Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature.)
M260: i2c Send Data
Yes: 1.1.0 No No No ??? ??? Yes No
Buffer and send data over the i2c bus. Use A to set the address from 0-127. Add up to 32 bytes to the buffer with each B. Send and reset the buffer with S.
Examples
M260 A5 B65 S ; Send 'A' to Address 5 now
M260 A0       ; Set address to 0 (broadcast)
M260 B77  ; M
M260 B97  ; a
M260 B114 ; r
M260 B108 ; l
M260 B105 ; i
M260 B110 ; n
M260 S1   ; Send the current buffer
M261: i2c Request Data
Request data from an i2c slave device. This command simply relays the received data to the host.
Example
M261 A99 B5 ; Request 5 bytes from Address 99
Both M260 and M261 are commands demonstrating use of the i2c bus (TWIBus class) in Marlin Firmware. Developers and vendors can make Marlin an i2c master device by enabling EXPERIMENTAL_I2CBUS, and Marlin can act as a slave device by setting I2C_SLAVE_ADDRESS from 8-127. This class can be used to divide up processing responsibilities between multiple instances of Marlin running on multiple boards. For example, one board might control a Z axis with 4 independent steppers to create a self-leveling system, or a second board could drive the graphical display while the first board handles printing.
M280: Set servo position
Yes 1.16 and later Use M340 No ??? ??? Yes ???
??? No No No Yes Yes No ???
Set servo position absolute.
Parameters
Pnnn Servo index
Snnn Angle or microseconds
I1 Invert polarity (RepRapFirmware only)
Example
M280 P1 S50
Marlin and RepRapFirmware treat S values below 200 as angles, and 200 or greater as the pulse width in microseconds.
In RepRapFirmware, the servo index is the same as the pin number for the M42 command. See https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins for details.
RepRapFirmware supports the optional I1 parameter, which if present causes the polarity of the servo pulses to be inverted compared to normal for that output pin. The I parameter is not remembered between M280 commands (unlike the I parameter in M106 commands), so if you need inverted polarity then you must include I1 in every M280 command you send.
Duet 0.8.5 M280 P value to Expansion Port Pin Mapping
Use M307 H# A-1 C-1 D-1 before using these pins
3 PC23_PWML6 21
4 PC22_PWML5 22
5 PC21_PWML4 23
On the Duet 0.6, pin 18 is controlled by heater 2. On the 0.8.5, pin 18 is controlled by heater 6, but is also shared with fan1. In order to use this pin, the fan must be disabled (M106 P1 I-1). See Using servos and controlling unused I/O pins
M290: Baby stepping
No 1.18 and later No No ??? ??? No No
Parameters
Snnn Amount to baby step in mm. Positive values raise the head, negative values lower it.
Example
M290 S0.05
This command tells the printer to apply the specified additional offset to the Z coordinate for all future moves, and to apply the offset to moves that have already been queued if this case be done. Baby stepping is cumulative, for example after M290 S0.1 followed by M290 S-0.02, an offset of 0.08mm is used.
M290 with no parameters reports the accumulated baby stepping offset.
The baby stepping offset is reset to zero when the printer is homed or the bed is probed.
M291: Display message and optionally wait for response
No 1.19 and later No No ??? ??? No No
Parameters
P"message" The message to display, which must be enclosed in double quotation marks. If the message itself contains a double quotation mark, use two double quotation marks to represent it.
R"message" Optional title for the message box. Must be enclosed in double quotation marks too.
Sn Message box mode (defaults to 1)
Tn Timeout in seconds, only legal for S=0 and S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time out (it may still be cancelled by the user). In RepRapFirmware, the default timeout for messages that do not require acknowledgement is 10 seconds.
Zn 0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print head
Examples
M291 P"Please do something and press OK when done" S2
M291 P"This message will be closed after 10 seconds" T10
This command provides a more flexible alternative to M117, in particular messages that time out, messages that suspend execution until the user acknowledges them, and messages that allow the user to adjust the height of the print head before acknowledging them.
Allowed message box modes include:
0. No buttons are displayed (non-blocking)
1. Only "Close" is displayed (non-blocking)
2. Only "OK" is displayed (blocking, send M292 to resume the execution)
3. "OK" and "Cancel" are displayed  (blocking, send M292 to resume the execution or M292 P1 to cancel the operation in progress)
M292: Acknowledge message
Parameters
Pn Whether the current operation shall be cancelled. Only legal if M291 was called with S=3 (optional)
This command is sent by the user interface when the user acknowledges a message that was displayed because of a M291 command with parameter S=2 or S=3.
M300: Play beep sound
Yes Yes Yes No ??? ??? Yes Yes
Parameters
Snnn frequency in Hz
Pnnn duration in milliseconds
Example
M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
M301: Set PID parameters
??? Yes No No No Yes See M130-M133 ???
Parameters
Hnnn heater number (Smoothie uses 'S', Redeem uses 'E')
Pnnn proportional (Kp)
Innn integral (Ki)
Dnnn derivative (Kd)
Examples
M301 H1 P1 I2 D3 ; Marlin
M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42
M301 S0 P30 I10 D10 ; Smoothie
M301 E0 P30 I10 D10 ; Redeem (E = Extruder, -1=Bed, 0=E, 1=H, 2=A, 3=B, 4=C, default = 0)
Marlin
Hot end only; see M304 for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
  • H Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc.
  • P Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater).
  • I Integral value
  • D Derivative value
  • T Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID.
  • S PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
  • W Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing.
  • B PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0<code> is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?)
Example
M301 W125
Teacup
See <code>M130, M131, M132, M133 for Teacup's codes for setting the PID parameters.
M302: Allow cold extrudes
Yes Yes1 Yes: 0.92 No ??? ??? Yes ???
Parameters
Snnn Cold extrude minimum temperature
Pnnn Cold extrude allow state (RepRapFirmware)
Examples (RepRapFirmwre)
M302       ; Report current state
M302 P1    ; Allow cold extrusion
Examples (Others)
M302 S0    ; Allow extrusion at any temperature
M302 S170  ; Allow extrusion above 170
This tells the printer to allow movement of the extruder motor above a certain temperature, or if disabled, to allow extruder movement when the hotend is below a safe printing temperature.
Notes
1RepRapFirmware uses the P[0|1] parameter instead of S[temperature], and for M302 with no parameters it will report the current cold extrusion state.
M303: Run PID tuning
Yes 1.15 and later Yes Yes ??? ??? Yes ???
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
Example
M303 C8 S175
M303 E0 S190
In RepRapFirmware, this command computes the process model parameters (see M307), which are in turn used to calculate the PID constants. H is the heater number, P is the PWM to use (default 0.5), and S is the maximum allowable temperature (default 225). Tuning is performed asynchronously. Run M303 with no parameters to see the current tuning state or the last tuning result.
Example
M303 H1 P0.4 S240 ; tune heater 1 using 40% PWM, quit if temperature exceeds 240C
Notes
In Marlin Firmware you can add the U1 parameter to apply the PID results to current settings upon completion.
Yes Yes ??? see M301 ??? ??? Yes ???
Parameters
Innn integral (Ki)
Examples
M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
M304 P1 I2 D3 T0.7 B20 W127 ; RepRapFirmware
M304          ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bang control should be used instead of PID. In RepRapFirmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example
M304 H1 B4200 R4800 T100000
No Yes ??? Yes ??? ??? No ???
Parameters
Pnnn Heater number, or virtual heater number
S"name" Heater name (optional, RepRapFirmware only)
Tnnn (for thermistor sensors) Thermistor resistance at 25oC
T"c" (for MAX31856-based thermocouple sensors) The thermistor type letter, default K
Bnnn Beta value, or the reciprocal of the Steinhart-Hart thermistor model B coefficient
Cnnn Steinhart-Hart C coefficient (RepRapFirmware 1.17 and later), default 0
Rnnn Series resistor value
Lnnn ADC low offset correction, default 0
Hnnn ADC high offset correction, default 0
Xnnn Heater ADC channel, or thermocouple or PT100 or current loop adapter channel, defaults to the same value as the P parameter
Fnn (where nn is 50 or 60) If the sensor interface uses a MAX31856 thermocouple chip or MAX31865 PT100 chip, this is the local mains frequency. Readings will be timed to optimise rejection of interference at this frequency.
Example
M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. The example above tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
Example
M305 P1 T100000 R1000 B4200 H14 L-11 X2
The H correction affects the reading at high ADC input voltages, so it has the greatest effect at low temperatures. The L correction affects the reading at low input voltages, which correspond to high temperatures.
The X parameter tells the firmware to use the thermistor input corresponding to a different heating channel. RepRapFirmware also allow an external SPI thermocouple interface (such as the MAX31855) or PT100 interface (MAX31865) to be configured. MAX31855 thermocouple channels are numbered from 100, MAX31856 thermocouple channels are numbered from 150, PT100 channels from 200 and current loop channels from 300. Channel 1000 is the CPU temperature indication, 1001 is the temperature of the hottest stepper motor driver on the main board, and 1001 is the temperature of the hottest drivers on the expansion board.
In the above example, the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: Set home offset calculated from toolhead position
Support Marlin RepRapFirmware Repetier Smoothie Klipper Prusa MK4duo MakerBot
No No ??? Yes ??? ??? No ???
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa
Example
M306 Z0
Implemented in Smoothieware
M307: Set or report heating process parameters
No 1.15 and later No No ??? ??? No ???
Parameters
Hn Heater number (0 is usually the bed heater)
Annn gAin, expressed as ultimate temperature rise obtained in degC divided by the PWM fraction. For example, if G=180 then at 50% PWM the ultimate temperature rise would be 90C.
Cnnn dominant time Constant of the heating process in seconds
Dnnn Dead time in seconds
Two additional parameters help control the heating process
Bn selects Bang-bang control instead of PID if non-zero. Default at power-up is 0 for extruder heaters, 1 for the bed heater.
Snnn maximum PWM to be used used with this heater on a scale of 0 to 1. Default 1.0.
Examples
M307 H0 ; report the process parameters for heater 0
M307 H1 A346.2 C140 D5.3 B0 S0.8 ; set process parameters for heater 1, use PID, and limit heater 1 PWM to 80%
Each heater and its corresponding load may be approximated as a first order process with dead time, which is characterised by the gain, time constant and dead time parameters. The model can used to calculate optimum PID parameters (including using different values for the heating or cooling phase and the steady state phase), to better detect heater faults, and to calculate feed-forward terms to better respond to changes in the load. Normally these model parameters are found by auto tuning - see M303.
RepRapFirmware 1.16 and later allow the PID controller for a heater to be disabled by setting the A, C, and D parameters to -1. This frees up the corresponding heater control pin for use as a general purpose I/O pin.
M320: Activate autolevel (Repetier)
No No Yes No ??? ??? No ???
Usage
M320
M320 S1
Parameters
Snnn if greater than 0, activate and store persistently in EEPROM
Examples
M320    ; temporarily activate auto leveling
M320 S1 ; permanently activate auto leveling
Parameter Snnn is optional.
(Repetier only)
M321: Deactivate autolevel (Repetier)
Usage
M321
M321 S1
Parameters
Snnn if greater than 0, deactivate and store persistently in EEPROM
Examples
M321    ; temporarily deactivate auto leveling
M321 S1 ; permanently deactivate auto leveling
(Repetier only)
M322: Reset autolevel matrix (Repetier)
Usage
M322
M322 S1
Parameters
Snnn if greater than 0, also reset the matrix values saved EEPROM
Examples
M322    ; temporarily reset auto level matrix
M322 S1 ; permanently reset auto level matrix
(Repetier only)
M323: Distortion correction on/off (Repetier)
Usage
M323
M323 Snnn
M323 Snnn Pnnn
Parameters
Snnn 0 (disable correction) or 1 (enable correction)
Pnnn 1 (store correction state persistently in EEPROM)
Examples
M323       ; Show if distortion correction is enabled
M323 S0    ; Disable distortion correction temporarily
M323 S1 P1 ; Enable distortion correction permanently
(Repetier only) Controls distortion correction feature after having set it up using G33.
M340: Control the servos
M350: Set microstepping mode
Yes Yes Yes No ??? ??? Yes ???
??? No No No No Yes No ???
Sets microstepping mode.
Warning: Steps per unit remains unchanged; except that in RepRapFirmware the steps/mm will be adjusted automatically.
Usage
M350 Snn Xnn Ynn Znn Enn Bnn
Parameters
Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
Snn Set stepping mode for all drivers (not supported by RepRapFirmware)
Xnn Set stepping mode for the X axis
Ynn Set stepping mode for the Y axis
Znn Set stepping mode for the Z axis
Enn Set stepping mode for Extruder 0 (for RepRapFirmware use Enn:nn:nn etc. for multiple extruders)
Bnn Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)
Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)
Modes (nn)
1 = full step
2 = half step
4 = quarter step
8 = 1/8 step
16 = 1/16 step
64 = 1/64 step
128 = 1/128 step
256 = 1/256 step
Examples
M350 S16    ; reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware
M350 Z1     ; set the Z-axis' driver to use full steps
M350 E4 B4  ; set both extruders to use quarter steps - Marlin/Repetier
M350 E4:4:4 ; set extruders 0-2 to use quarter steps - RepRapFirmware
Yes No No No ??? ??? Yes ???
Example
M351
M355: Turn case lights on/off
Yes: 1.1.0 No Yes: 0.92.2 No ??? ??? No ???
??? No No No No No use M106 ???
Examples
M355 S1 ; Enable lights
M355 S0 ; Disable lights
M355    ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like:
Case lights on
Case lights off
No case lights
No No Yes: 0.92.2 No ??? ??? No ???
Target
Example
M360
Response
Config:Baudrate:250000
Config:InputBuffer:127
Config:NumExtruder:2
Config:MixingExtruder:0
Config:HeatedBed:0
Config:SDCard:1
Config:Fan:1
Config:LCD:1
Config:SoftwarePowerSwitch:1
Config:XHomeDir:-1
Config:YHomeDir:-1
Config:ZHomeDir:-1
Config:SupportG10G11:1
Config:CaseLights:0
Config:ZProbe:1
Config:Autolevel:0
Config:EEPROM:1
Config:PrintlineCache:24
Config:JerkXY:30.00
Config:JerkZ:0.30
Config:RetractionLength:3.00
Config:RetractionSpeed:40.00
Config:RetractionZLift:0.00
Config:XMin:0.00
Config:YMin:0.00
Config:ZMin:0.00
Config:XMax:250.00
Config:YMax:150.00
Config:ZMax:90.00
Config:XSize:250.00
Config:YSize:150.00
Config:ZSize:90.00
Config:XPrintAccel:250.00
Config:YPrintAccel:250.00
Config:ZPrintAccel:100.00
Config:XTravelAccel:250.00
Config:YTravelAccel:250.00
Config:ZTravelAccel:100.00
Config:PrinterType:Cartesian
Config:MaxBedTemp:120
Config:Extr.1:Jerk:50.00
Config:Extr.1:MaxSpeed:100.00
Config:Extr.1:Diameter:0.00
Config:Extr.1:MaxTemp:220
Config:Extr.2:Jerk:50.00
Config:Extr.2:MaxSpeed:100.00
Config:Extr.2:Diameter:0.00
Config:Extr.2:MaxTemp:220
Partial No No Yes ??? ??? Partial ???
??? No No No No ??? No ???
Experimental No No Yes ??? ??? Experimental ???
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500.
M365: SCARA scaling factor
M366: SCARA convert trim
No No No Yes ??? ??? No ???
No Use M557 No Yes ??? ??? No ???
Usage
M370
M370 X[divisions] Y[divisions]
M374: Save calibration grid
No 1.17 and later No Yes ??? ??? No ???
Saves the calibration grid.
Parameters
extension (Smoothieware only) Extension of the grid file
Pfilename (RepRapFirmware only) Name of the file to save to
Z (Smoothieware only) Also save the M206 Z homing offset into the grid file
Usage (Smoothieware)
M374
M374 <file extension> Z
Usage (RepRapFirmware)
M374
M374 PMyAlternateHeightMap.csv
In Smoothieware, without parameters this saves the grid into the default grid file that gets loaded at boot. The optional parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file.
In RepRapFirmware, this saves the grid parameters and height map into the specified file, or the default file heightmap.csv if no filename was specified. To load the height map automatically at startup, use command M375 in the config.g file.
Displays the bed level calibration matrix (Marlin), or loads the grid matrix file (Smoothieware and RepRapFirmware)
Parameters
Usage
M375
M375 [file extension] ; (Smoothieware only)
M375 PMyAlternateHeightMap.csv ; (RepRapFirmware only)
Without parameters loads default grid, and with specified extension or specified filename attempts to load the specified grid. If not available will not modify the current grid. In Smoothieware, if Z was saved with the grid file, it will load the saved Z with the grid.
M376: Set bed compensation taper
Parameters
Hnnn Height (mm) over which to taper off the bed compensation
Example
M376 H10
This command specifies that bed compensation should be tapered off over the specified height, so that no bed compensation is applied at and above that height. If H is zero or negative then no tapering is applied, so compensation is performed throughout the entire print.
If the firmware does not adjust the extrusion amount to compensate for the changing layer height while tapering is being applied, you will get under- or over-extrusion. Using a large taper height will reduce this effect. For example, if the taper height is 50 times the largest bed height error, then under- or over-extrusion will be limited to 2%.
M380: Activate solenoid
Yes No ??? No ??? ??? Yes ???
Example
M380
M381: Disable all solenoids
Example
M381
??? Yes No No Yes ??? use G4 ???
Example
M400
M401: Lower z-probe
Yes 1.17 and later ??? No ??? ??? Yes ???
Example
M401
Lower z-probe if present. In RepRapFirmware this runs macro file sys/deployprobe.g.
M402: Raise z-probe
Example
M402
Raise z-probe if present. In RepRapFirmware this runs macro file sys/retractprobe.g.
Yes Yes No No ??? ??? Yes ???
Parameters
Nnnn Filament width (in mm)
Dnnn Nozzle diameter (in mm)1
Examples
M404 N1.75
M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
Example
M405
M406: Filament Sensor off
Example
M406
Example
M407
Displays measured filament diameter. In RepRapFirmware, M407 does the same as M404.
Parameters
Snnn Response type
Rnnn Response sequence number
Example
M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
  • Type 0 is a short-form response, similar to the response used by older versions of the web interface.
  • Type 1 is like type 0 except that static values are also included.
  • Type 2 is similar to the response provided by the web server for Duet Web Control.
  • Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
  • Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
  • Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0],
 "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status:  I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file (i.e starting up), A=paused, D=pausing, R=resuming from a pause, B=busy (e.g. running a macro), F=performing firmware update
hstat:   status of the heaters, 0=off, 1=standby, 2=active, 3=heater fault. Heater 0 is normally the bed heater, heaters 1, 2.. are the extruder heaters.
pos:     the X, Y and Z (and U, V, W if present) axis positions of the current tool (if a tool is selected), or of the print head reference point if no tool is selected
efactor: the current extrusion factors (see M221 command), one value per extruder
tool:    the selected tool number. A negative number typically means no tool selected.
probe:   the Z-probe reading
fanPercent: the speeds of the controllable fans, in percent of maximum
fanRPM:  the print cooling fan RPM
homed:   the homed status of the X, Y and Z axes (and U, V, W if they exist), or towers on a delta. 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable.
timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read,
           the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress.
seq:     the sequence number of the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater than that.
resp:    the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
firmwareName: the name of the firmware, e.g. "RepRapFirmware", "Smoothieware" or "Repetier"
axes:    the number of axes
volumes: the number of SD card slots available
numTools:   the number of available tools numbered contiguously starting from 0
For a more detailed comparison of type 2 - 5, see RepRap_Firmware_Status_responses.
PanelDue currently uses only M408 S0 and M408 S1.
M420: Set RGB Colors as PWM (MachineKit)
??? No No No Yes ??? No ???
Usage: M420 R[Red PWM (0-255)] E[Green PWM (0-255)] B[Blue PWM (0-255)]
Example
M420 R255 E255 B255
Set the color of your RGB LEDs that are connected to PWM-enabled pins. Note, the Green color is controlled by the <code>E value instead of the G value due to the G code being a primary code that cannot be overridden.
In Marlin M420 is Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M420: Leveling On/Off/Fade (Marlin)
Enable/Disable Bed Leveling (using the current stored grid or mesh).
Usage
M420 S[bool] Z[float]
Examples
M420 S1  ; Enable compensation using current grid/mesh
M420 Z10 ; Gradually reduce compensation until Z=10
Marlin 1.1.0 adds the Z parameter to set the "fade" height. This requires the ENABLE_LEVELING_FADE_HEIGHT option.
When the Z fade height value is set non-zero, bed compensation will gradually reduce up to the given height, and cease completely above that height.
M421: Set a Mesh Bed Leveling Z coordinate
Yes No No No ??? ??? No No
No No No No No No No ???
Set a single Z coordinate in the Mesh, Bilinear or UBL Leveling grid. Requires MESH_BED_LEVELING or AUTO_BED_LEVELING_BILINEAR or AUTO_BED_LEVELING_UBL.
I & J are the index for the X and Y axis respectively.
Usage
M421 I[index] J[index] Z[float] to set an absolute value to a mesh point
or
M421 I[index] J[index] Q[float] to offset a mesh point by a specified value
M450: Report Printer Mode
Usage
M450
Example
> M450
> PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
PrinterMode:FFF
PrinterMode:Laser
PrinterMode:CNC
M451: Select FFF Printer Mode
Usage
M451
Example
> M451
> PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
Usage
M452
Example
> M452
> PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1 moves if laser was enabled or E is increasing. G0 moves should never enable the laser. M3/M5 can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
Usage
M453
Example
> M453
> PrinterMode:CNC
Switches to CNC mode. In this mode M3/M4/M5 control the pins defined for the milling device.
M460: Define temperature range for thermistor-controlled fan
No Use M106 Yes No ??? ??? No ???
Usage
M460 X[minTemp] Y[maxTemp]
Example
M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M500: Store parameters in EEPROM
Yes Yes Yes Yes ??? ??? Yes ???
Example
M500
Save current parameters to EEPROM.
M501: Read parameters from EEPROM
Yes Yes Yes ??? ??? ??? Yes ???
Parameters
Snnn Enable auto-save (only RepRapFirmware)
Example
M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
RepRapFirmware versions prior to 1.17 allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
In RepRapFirmware 1.17 and later, the parameters are saved in file sys/config-override.g on the SD card.
M502: Revert to the default "factory settings."
Example
M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500 if you want to do that.
M503: Print settings
Yes Yes ??? ??? ??? ??? Yes ???
Example
M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
RepRapFirmware outputs the content of the configuration file, but note that it may be truncated if it is too long.
M530: Enable printing mode
Support
