Vertical X Axis Standard
Revision as of 19:36, 12 December 2011 by North90ty (talk | contribs) (Standards compliant projects)
This is the spot for documentation of the standard configuration for vertical X axis assemblies. The original discussion about why we want such a thing is here. If you are a designer of an extruder, X carriage, X axis assembly, or whole bot that works with this standard, consider yourself and editor of this page.
!! There is a contest going on for those wishing to port existing designs or design new parts that fit the standard!! Vertical_X_Axis_Standard_Contest
Benefits
Benefits of a vertical X axis assembly on Mendel style bots include
1. A vertical x-axis should make head changes and hotend designs easier because the head can slide out unobstructed.
2. Should use less plastic (print faster) than a horizontal X axis assembly.
3. Should be stiffer than horizontal X axis configurations given the same amount of plastic.
4. Naturally lends itself to integrated X carriage/extruder designs as they are now both in the same plane.
5. ? :)
The Standard
The currently agreed upon standard is to space the two X smooth rods 70 mm center to center and the Z smooth and threaded rod 30 mm center to center. A diagram below explains the basic constraints. The Z rod spacing is identical to the Prusa and Mendel, so it is likely that X axis assemblies that conform to this standard could be used as replacements in those bots as well.
Current Projects W/ Vertical X Axis
These projects are not necessarily compliant with this standard. They may choose to work with the standard or not as they see fit.
This space will update as more projects adopt the standard. (Hopefully :)
X-carriage-struder Pending version 0.7
Test_Tube_Mendel Pending revision of X axis design
Action68's_vertical_x_axis_reprap A currently conceptual bot with a vertical X axis
PCB Mill mount for Vertical X axis by droftarts Vertical_x_for_Prusa_by_North90ty A complete and very easy to build design for a vertical x-axis
Feel free to add your project here if you have a design that is or will soon be compliant.
