Z-axis assembly
Revision as of 05:59, 14 August 2015 by Qing (talk | contribs) (Created page with "{{Languages}} <center> Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly Connecting ...")
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heated bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Z-axis motor assembly
Need parts:
  • 2×NEMA17 stepper motor
  • 2×5*5 compling
Step 1
Insert motor shaft into compling and screw tighten.
Step 2
Insert stepper motor wires.Insert the motor wires from the bottom.
Step 3
Fixed the motor onto the acrylic frame.(M3*10 screws 8pcs, M3 gasket 8pcs),Please With the hex wrench to tighten the screws.
