WOW New Materials!? February 26, 2014 03:14AM |
Re: WOW New Materials!? February 26, 2014 09:11AM |
Re: WOW New Materials!? February 26, 2014 12:01PM |
I still struggle trying to figure out how carbon fiber infused filament would make it stronger. In order to be extruded at some always variable length/width/height the fibers would need to be extremely short. And being so short, you lose all the advantages of the long carbon crystaline structure that gives carbon fibers it's strength. You might as well mix in some charcoal dust...it'd be cheaper.Quote
tjb1
that sells PLA infused with carbor fiber and other specialty filaments.
Re: WOW New Materials!? February 26, 2014 12:26PM |
Admin Registered: 15 years ago Posts: 1,470 |
cdru
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: WOW New Materials!? February 26, 2014 12:44PM |
cdru
tjb1
Re: WOW New Materials!? February 26, 2014 12:46PM |
NewPerfection
cdru
That is true for filaments like what Proto-Pasta is making. In fact, Proto-Pasta even provides data that shows that their carbon-infused PLA is not as strong as plain PLA. It is, however, significantly stiffer.
The MakerForged printer claims to be different though, using continuous carbon fiber with a cutting blade which should make for extremely strong parts, at least in the fiber direction.
Re: WOW New Materials!? February 26, 2014 04:03PM |
Re: WOW New Materials!? February 27, 2014 07:03PM |
Re: WOW New Materials!? February 27, 2014 07:07PM |
Re: WOW New Materials!? February 27, 2014 07:18PM |
Re: WOW New Materials!? February 27, 2014 07:19PM |
Re: WOW New Materials!? February 27, 2014 07:26PM |
Re: WOW New Materials!? February 27, 2014 08:17PM |
Anonymous User
Re: WOW New Materials!? February 28, 2014 12:18AM |
Re: WOW New Materials!? February 28, 2014 12:22AM |
Re: WOW New Materials!? February 28, 2014 12:37AM |
Dirty Steve
sure, when it's layed up in a weave. This printing method is only as strong as it's fusable material.
Anonymous User
Re: WOW New Materials!? February 28, 2014 12:41AM |
Re: WOW New Materials!? February 28, 2014 01:57AM |
Re: WOW New Materials!? February 28, 2014 04:35AM |
Re: WOW New Materials!? February 28, 2014 05:42AM |
Re: WOW New Materials!? February 28, 2014 06:37AM |
Re: WOW New Materials!? February 28, 2014 06:52AM |
Re: WOW New Materials!? February 28, 2014 07:21AM |
Dirty Steve
carbon fiber in PLA wouldn't do much of anything for strength, carbon fiber strength is in the weave, not parallel threads of material.
Re: WOW New Materials!? February 28, 2014 09:08AM |
Re: WOW New Materials!? February 28, 2014 10:38AM |
cdru
Any discussion about higest strength, performance, etc is pointless unless what context it would be used and evaulated with is defined.Quote
kwikius
For highest performance unidirectional carbon is used.
Re: WOW New Materials!? February 28, 2014 02:39PM |
Re: WOW New Materials!? February 28, 2014 04:33PM |
mrPrik
so the resin coated fibre filament must be a 1:1 extrusion from the print head, with a cut made for each path drawn.
Re: WOW New Materials!? February 28, 2014 04:42PM |
Re: WOW New Materials!? February 28, 2014 05:16PM |
tmorris9
I wonder if it would be possible to print with UHMWPE
Re: WOW New Materials!? February 28, 2014 06:04PM |
