Re: 3dstuffmaker.com - opinions? November 24, 2013 10:34AM |
Re: 3dstuffmaker.com - opinions? November 24, 2013 06:31PM |
Re: 3dstuffmaker.com - opinions? November 24, 2013 11:23PM |
jeffegg2
Received the adapter tube. The 3mm x 2mm works for the 3mm to 1.75 conversion, but the hot end part is still 3mm. I have ordered some 3mm x 2mm brass tube to place into the hot end and see if that works out better. Some of the adapter photos show using the ptfe all the way to the tip. I can't see how the pla will melt using that method. I cut the ptfe where it enters the metal area, but now I get some jams...
I'll let you know how the brass adapter works out.
Re: 3dstuffmaker.com - opinions? November 25, 2013 05:26PM |
Re: 3dstuffmaker.com - opinions? November 26, 2013 09:35AM |
Re: 3dstuffmaker.com - opinions? November 26, 2013 03:47PM |
Re: 3dstuffmaker.com - opinions? November 29, 2013 12:16AM |
nechaus
Is that part warped ?
To me I got rid of most of that by doing this
- retraction needs to be on and fine tuned to your setup
- to hot, if the temp is to hot this can cause lots of ooze
-reduce extrusion mutiplier maybe .90 keep going lower untill you have it set right.
Do you have a fan blowing at ur prints ? If not try it out..
Re: 3dstuffmaker.com - opinions? April 07, 2014 04:02PM |
Re: 3dstuffmaker.com - opinions? April 07, 2014 08:15PM |
Re: 3dstuffmaker.com - opinions? April 08, 2014 08:43AM |
Re: 3dstuffmaker.com - opinions? April 08, 2014 10:04PM |
s10blazed
I've decided to ditch the stock hot end on this machine and follow your path by upgrading to a budaschnozzle.
I see that you used the stock electronics. Did you ever have to make any changes with the USB adapter? (Was it you that had the original firmware from 3DSM?)
Do you run the fan hard wired to 12v?
How about the carriage? I see you listed a few, but which one did you print? I've printed 2 so far. One doesn't fit the rails but matches where the belt attaches. The other fits the rails but the belt holes are way off. I think I could modify the 2nd one to fit the belt but was curious if you had an STL available that just fits.
Did you ever use the budaschnozzle with the stock extruder? I'd rather not move that weight to the carriage. (Plus I've put so much work into making it better I don't want to start over)
What is your average temperature setting? (It seems I need to put mine to 220+ to get flow on PLA others print at 190)
Finally, do you have any recent prints to show off? What speeds, etc? When I look at some of the previous prints you posted it gives me hope that this machine is salvageable.
Re: 3dstuffmaker.com - opinions? April 14, 2014 12:25PM |
Re: 3dstuffmaker.com - opinions? April 14, 2014 07:00PM |
Re: 3dstuffmaker.com - opinions? May 05, 2014 12:10PM |
Re: 3dstuffmaker.com - opinions? May 22, 2014 11:13AM |
Re: 3dstuffmaker.com - opinions? May 28, 2014 10:00AM |
Re: 3dstuffmaker.com - opinions? May 28, 2014 06:17PM |
Re: 3dstuffmaker.com - opinions? May 29, 2014 08:06AM |
Re: 3dstuffmaker.com - opinions? May 29, 2014 08:34AM |
Re: 3dstuffmaker.com - opinions? June 03, 2014 11:13AM |
Re: 3dstuffmaker.com - opinions? June 03, 2014 08:15PM |
Re: 3dstuffmaker.com - opinions? June 03, 2014 08:20PM |
Re: 3dstuffmaker.com - opinions? June 04, 2014 08:04AM |
Re: 3dstuffmaker.com - opinions? August 07, 2014 09:12AM |
Re: 3dstuffmaker.com - opinions? August 09, 2014 04:04PM |
Re: 3dstuffmaker.com - opinions? August 10, 2014 11:00AM |
Re: 3dstuffmaker.com - opinions? August 10, 2014 12:03PM |
Re: 3dstuffmaker.com - opinions? August 10, 2014 03:14PM |
Re: 3dstuffmaker.com - opinions? August 10, 2014 03:34PM |
Re: 3dstuffmaker.com - opinions? August 10, 2014 04:10PM |
