pellet extruder?? April 23, 2015 07:21PM |
Re: pellet extruder?? April 23, 2015 08:09PM |
Re: pellet extruder?? April 23, 2015 09:07PM |
Re: pellet extruder?? April 23, 2015 09:37PM |
Re: pellet extruder?? April 23, 2015 09:57PM |
Re: pellet extruder?? April 23, 2015 11:23PM |
senior_eduardo
frankvdh
The pellets being used in that example were 25Euro for 1.2kg
Bologna. There's obviously a HUGE cost advantage in printing pellets. They're not turning pellets into filament for free. I can get PLA for <$5/lbs.
Re: pellet extruder?? April 23, 2015 11:35PM |
Re: pellet extruder?? April 24, 2015 02:48AM |
Re: pellet extruder?? April 25, 2015 11:33AM |
Re: pellet extruder?? May 02, 2015 07:08PM |
Re: pellet extruder?? June 19, 2015 04:06PM |
Re: pellet extruder?? August 26, 2015 02:21PM |
Re: pellet extruder?? August 26, 2015 04:20PM |
senior_eduardo
I don't see a 3/8" auger bit on a .4mm nozzle achieving retraction on par with a standard filament extruder. All the development in the world won't change that. I tend to believe that something this simple hasn't been done yet because it's impossible.
Re: pellet extruder?? August 28, 2015 03:40PM |
thetazzbot
senior_eduardo
2008 - printing 3d objects from plastic line is impossible!
Re: pellet extruder?? November 21, 2015 10:01AM |
Re: pellet extruder?? November 21, 2015 01:50PM |
Re: pellet extruder?? November 21, 2015 02:17PM |
Re: pellet extruder?? November 21, 2015 04:04PM |
Re: pellet extruder?? November 21, 2015 05:36PM |
biskero
Much less control of changes in print volume than a normal extruder.
- not sure what you mean, pls explain
Re: pellet extruder?? November 21, 2015 05:50PM |
Re: pellet extruder?? November 23, 2015 11:32AM |
Re: pellet extruder?? November 23, 2015 11:42AM |
Re: pellet extruder?? November 27, 2015 08:58AM |
Re: pellet extruder?? December 04, 2015 11:10PM |
biskero
Ciao,
here more videos from those guys.
The results seems decent.
About your point:
1 - weight, it depends on implementation, pellets holder should not be on the extruder
2 - retraction is a problem
3 - not sure what you mean, pls explain
4 - since my print job is huge, filaments are an issue, that's why want to try pellets, you fill 3 or 4kg and forget it
My extruder design is 180mm height including motor and btw my printer is huge, 1200x600x600mm with dual extruder at the moment.
Will be all stainless steel including nozzles. Will try to post some pictures next week when I get the steel pieces.
Here is a design:
Alessandro
Re: pellet extruder?? December 05, 2015 04:27AM |
Re: pellet extruder?? December 05, 2015 10:01AM |
Re: pellet extruder?? December 05, 2015 10:12AM |
Re: pellet extruder?? December 05, 2015 12:07PM |
Re: pellet extruder?? December 07, 2015 12:14AM |
