checkout my new design for hotend
September 08, 2013 12:06PM
hello
finally.... =)
this is my new design for hotend
ill post specification soon
open | download - r3d-hotend.jpg (137.6 KB)
Re: checkout my new design for hotend
September 08, 2013 02:54PM
Looks nice. How does it perform, specifically with PLA?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
September 08, 2013 11:03PM
That looks sexy. Whats the max temp it can handle? In the market for a new hot end actually to replace my buschado or however you spell it and want to go higher temps for nylon and such.
September 08, 2013 11:41PM
The beige thing looks like it's made from plastic so I would guess no nylon. For that I think you would need an all-metal hot end.
And I guess you meant Budaschnozzle? winking smiley
September 08, 2013 11:52PM
Yes. LOL. Maybe its just a model part and hes planning on making it in metal? One can hope, right?
As long as the PEEK portion can be kept below 240*C, it would work for higher temp plastics like nylon. I'm guessing that is the reason for the heat sink portion.
September 09, 2013 10:41AM
HI guys
thank you for the comments .
the idea is hotend without an active cooling (fan) and very low frication
the thing is to direct the heating exactly where it should go and stay there .
the nuzzle just slide in without screwing in order to make more contact with the block
the block made from alum' 6062
the heatsink act like a thermal barrier and helps to keep the peek cooler (6062 alum )
in the middle of peek i have a small theflon tube and the upper screw made from SS
for example with my delta design i can print on 185 deg' and the speed is on 100mm/sec with 600 mm theflon tube and direct drive ans no missing step and no oozing
i can print with 300 deg no problem and with no cooling .spinning smiley sticking its tongue out
guys ,,,,check out the videos
[www.facebook.com]
and this is my old design for the hotend no cooling needed
[www.facebook.com]
love this video ....hot smiley
elidor
September 09, 2013 10:48AM
interesting design!
more info. videos will be more appreciated.
September 09, 2013 03:47PM
hi
sure no problem ..
September 13, 2013 05:34AM
Hello to all
here is a first video fot the R3D hotend on my twister .
my setup is direct drive extruder with 600 mm theflon tube , 72oz stepper motor
speed - 150 -180 mm/sec
temp - 195
no licking at all and very little oozing
[www.facebook.com]
elidor
revision3d
September 16, 2013 11:29AM
will this be open sourced? i'm interested on its design smoking smiley
September 22, 2013 03:31AM
Hi
Yes , soon ill post on wiki .
September 22, 2013 03:40AM
can you do a print with a lot more infill?
September 22, 2013 04:11AM
Hi
what do you mean with a lot more infill ??
i guess you do that with other hotend as well .
